1st Gen DMU's, brake vans in multi formations.
hexagon789
2 Sep 2016
The 70's on the SCR could produce unbelievable combinations. 120+122, 101+100, most unusual i saw was 103 3 car plus a 105 101 100 forming a 6 car
There's a good picture on Flickr of a 3-car unit formed of three different classes in three different liveries! (Rail Blue, Blue/Grey and SPT)
theblackwatch
15 Feb 2006
Lovely shot; there seemed to be quite a few ad-hoc lash-ups in the late-1980s to early 1990s due to delays in new DMUs entering service and a need to keep services running with what ever was available.
That's right, and lots of units moved away from areas where they had operated for many years, and split from their usual formations. For example, Class 108s 53637/638, which had been part of 4-car (later reduced to 3-car) sets in Yorkshire/North East for all their lives found themselves split and sent to the West Country and paired up with 101 vehicles in 2-car sets. Calder Valley (Class 110) centre cars moved to Scotland, Class 119s ended up at Heaton, etc. It's probably that period which fired my interest in such units which has continued to this day.
Taunton
1 Aug 2013
The scenes in the 1980s "To the Manor Born" TV series at the station were filmed at Maiden Newton, on the Westbury to Weymouth line. Unless it had a very train-buff director, it will have been the WR who decided which dmu to send out for the filming, and they chose one of the first Met-Cam units (Class 101 for those of a more recent origin!) transferred there from the North-East. It even doesn't have any destination blind fitted yet.
hexagon789
2 Sep 2016
Quite a few 120s seem to run with 101 centre cars in the mid/late-1980s on ScR, there was also one with an all Blue 104 trailer but I've never found a photo.
Taunton
1 Aug 2013
The Swindon 120s (and the Gloucester RCW 119s built to the same diagrams) were notably inefficient in their interior layout. The motor composite had an oversize first class saloon with 6 rows of seats, a tiny 2-bay standard class saloon-ette, and an oversize luggage compartment, while in the trailer a buffet took the space of two bays. Given they were used on services with little or no actual revenue first class demand, few parcels or luggage etc, and the buffet in my experience was never, ever staffed since the day they were built. That the motor composite at one end seated just 16 standard passengers and the motor second at the other seated 68 shows the disparity. When used as a 2-car power twin without the trailer, as on Taunton to Barnstaple, it gave less standard class seats than one car of a WR suburban unit.
Putting a Met-Cam 101 trailer in the set gave some more seats. Were the Scottish cars declassified by the 1980s?
hexagon789
2 Sep 2016
And augmentation with Cravens 105s occurred even on the Inverness-Aberdeen which runs through some sparse country though there are a few sizeable places en route but if 120 capacity was insufficient on that lone I can well imagine the issues on the busier WR routes.
Late-1970s, some point between the 1976-77 and 1980 timetables.
They were by 1978.
Probably 1977 then; 1976-77 has first class on some DMU routes such as Glasgow-Ayrshire but 1980-81 has all DMU services as Second Only.
Sprinter107
26 Mar 2019
Werent Met Camm centre cars used in place of some of the original cars due to asbestos ? For me there would be no competition, I would always sit in one of the 120 cars instead of the more austere 101 car.
delt1c
4 Apr 2008
And what about the DMBF cars allocated to Inverness for the Aberdeen service. The standard class are in of 3 (I think) DMBC waws converted to additional guard space for the fish then carried.
davetheguard
10 Apr 2013
I can assure you that it wasn't oversized when the 119s were used on the Reading to Gatwick Airport route. Even after the former buffet area had been removed and replaced with wooden shelving for luggage, the guard's van floor was often completely covered with cases; all kept secure within the lockable metal cage provided for when the Guard was elsewhere checking tickets.
MarlowDonkey
4 Apr 2013
Not too sure about this. The Driving trailers(often referred to as Drive End Trailers) were certainly in use in the WR London Division in the 70's. Mainly on the branches, including 2 on Greenford, coupled to a bubble car. Much cheaper to attach one of these than another powered unit.
Whilst some of these may have been withdrawn earlier that was probably due to Beeching's cull of branch/rural routes which led to many DMU withdrawals
They were also used to strengthen doubled up 3 car formations to seven cars. The two morning through trains from Bourne End to Paddington were regulars for this. You never saw a four car formation, so presumably they either stayed as 7 car all day or dropped the trailer if they split.
Taunton
1 Aug 2013
WR London division did seem to make use of some (not all) of their allocated Pressed Steel 122 driving trailers on the branches, which don't seem to have significant gradients, but elsewhere the equivalent Gloucester RCW 121 driving trailers delivered with the other single cars just seemed unused - in fact, if you ever saw one in use, you are better than me.
Separately, while looking for an illustration of one just now, I cam across the first photo I have seen in 55 years of the oddball lashup the WR was forced to do in the 1960s on former its Southern WofE lines, as I described above, to put one vehicle in each train with toilets on the replacing dmus, by exchanging the centre cars of the 116 Suburban 508xx 3-car units with the centre of the 120 Cross-Country 515xx sets. Here it is https://rcts.zenfolio.com/diesel/br/dmu-1xx/122/ha0fc2cc3#ha0fc32b6 , not the main focus of the photo but the 3-car set on the right, on the main line at Axminster, at least all still in common green livery. That's a suburban power car at the far end, with the Cross-Country car in the middle, distinguishable here by the different window pattern.
Western 52
19 Jun 2020
Burry Port
I found this shot I took of a 3-car DMU set with all 3 cars having a brakevan! This is Canton set C396 leaving Barry Island on 1st September 1990 forming the 1704 to Bargoed. The motor vehicles are class 116 MBS 51133 and 51136 and the trailer is class 108 TBS 59248. From memory, this set ran like this for a while, and I rode to work on it a few times. The guard had plenty of choice on this set! At this time, there were a number of mixed class sets in South Wales as the DMUs worked out their final days. This was the only set with 3 brake cars though.C396 at Barry Island.jpg
Cowley
15 Apr 2016
Devon
I found this shot I took of a 3-car DMU set with all 3 cars having a brakevan! This is Canton set C396 leaving Barry Island on 1st September 1990 forming the 1704 to Bargoed. The motor vehicles are class 116 MBS 51133 and 51136 and the trailer is class 108 TBS 59248. From memory, this set ran like this for a while, and I rode to work on it a few times. The guard had plenty of choice on this set! At this time, there were a number of mixed class sets in South Wales as the DMUs worked out their final days. This was the only set with 3 brake cars though.View attachment 86895
That’s really good. I love the mismatch of the heights on the blue and grey between the two types.
Taunton
1 Aug 2013
The paint mismatch was the second thing I noticed, after both the West Midlands and the Welsh Dragon local service logos being applied on the same car.
Both the car types were designed at Derby, at effectively the same time, presumably in the same drawing office, and the paint difference just accentuates the windowline difference. One wonders why they did not use a common bottom windowline. Even the van windows are different sizes, which could readily be the same. This having happened, one then wonders why the blue/grey livery was not standardised for depth. The top of the grey is the same, the bottom on the suburban cars would need to be deepened, not much, for consistency, as the low density car livery has to be under the larger windows.
theblackwatch
15 Feb 2006
They did, certainly on the 101s, and I think other classes, at Doncaster! The grey was always deeper, so it was roughly the same level as other units such as 108s, on Doncaster repaints. It was higher on those dealt with at Swindon - not sure about other works. Swindon also had smaller BR arrows. It seems that perhaps each works had its own spec rather than there being a standard policy?
Taunton
1 Aug 2013
My comment was not so much about the painting as the design standard (although anything but standard it seems) of the windows and their various lower windowlines. Which must have led to much duplicate stocking cost of spares in the stores.
Separately, it's a good photograph for detail of past times, beyond the bizarre formation. The bracketed signals are typical Western Region from Reading signal works. The signalbox doesn't look very GWR though, with not a lot of windows around the end. The two power cars are from the separate batch of about a dozen built for and kept for many years in the Bristol area, which will surely have been old 1960s friends of mine on Taunton to Minehead (for some reason the Minehead line was always run with Bristol units, while Taunton to Barnstaple, departing from the next bay alongside, was always run with Laira units).
AndyW33
12 Aug 2013
I do wonder. but don't have any inside knowledge, if there was some commonality between the body components of the 116/117/118/121/122 DMU family and those of the Mk1 non-corridor coaches, which at least look to have similar widow sizes.
hexagon789
2 Sep 2016
A nice set and a great shot; the guard would go in the rear van depending on direction. That was usually the arrangement unless specified otherwise in the Sectional appendix.
I think the Cravens units were supposed to be the most similar to Mk1 coaches, windows in particular
Sprinter107
26 Mar 2019
The suburban dmus always seemed to have a slightly more slab sided profile than a mark 1 coach I always thought.
Merle Haggard
20 Oct 2019
Northampton
Thing is, of course, although we describe these as "suburban", BRWR didn't, they were just non-corridor, in the same way as branch lines and main line stopping trains had been the preserve of non-corridor hauled stock for generations.
That's a valid point - compartment stock was certainly used on the LM over comparatively long distances in steam days, although not always for the whole train.
However, the trusty Ian Allan ABCs did show them as, for example, '(3 Suburban)' in the class headings, so that's probably why it is used. What isn't clear is whether this was based on a B.R. document or Ian Allan's own idea.
Gloster
4 Sep 2020
Up the creek
Many, probably most, of the signal boxes of the South Wales lines were built by signalling contractors to their own designs or variations of them. After the grouping some were replaced or Great Westernised, but many remained little changed until closure. Unless I am mixing things up, the box visible is the former Barry Island West, which had previously been on the Cardiff Railway at Nantgarw and was only erected at Barry Island in 1929.
delt1c
4 Apr 2008
Fantastic shot, saw 3 cars with 2 Brakes but never a 3 with Brakes, was this one of the gangwayed 116's?
The MetCam 101s look to have a similar window depth to the so-called Mk1 Pullmans produced by the same company. I wonder if there were other similarities.
Taunton
1 Aug 2013
As I understand it ...
The WR used the Derby suburban design drawings quite extensively, except for their own Swindon-design class 120. It's a bit difficult keeping up with the TOPS class numbers, as they are in anything but construction order, but whatever. The 116 were the original Derby suburban cars for the WR, in fact just a variation on the first steel cars, the 50000 Class 114, same body construction and length but with suburban layout and doors etc. Derby ran two production lines side by side through the dmu build era, the short frame, alloy body, low density cars, and the long frame, steel body, high (normally) density ones. Both types had the same cab ends (fibreglass, I believe). Later the cab changed a bit with the repositioning of the destination, and the high level 4-character indicator.
When it came to dieselising the WR London services, Derby was fully occupied, so Swindon sent the Derby drawings to Pressed Steel in Glasgow for the 117s. Pressed Steel had not done dmus before, although they did quite a lot of Mk 1 hauled stock and vans, and so Swindon guided them. They had nicer interiors, including toilets in the trailers. Then again another 15 sets were needed at Plymouth, and the diagrams were sent again to Birmingham RCW, the 118s, the same ones presumably as they are notably difficult to tell apart, and quite different to anything else BRCW did.
The single cars (and their associated driving trailers) were the 122s by Gloucester RCW, these came first, done alongside the comparable Gloucester Cross-Country 119s (which themselves were built from the Swindon Cross-Country 120 drawings, with the Derby cab); Gloucester had been a longstanding Swindon subcontractor, and indeed had built the later GWR single railcars in 1940. However they were a suburban interior. Goodness knows why it was thought that a service that only ran to a single car needed maximum density seating. The 121s came later, from Pressed Steel, and again were just a permutation of previous drawings. It's a strange point that the only dmus on the WR, coming from multiple builders, which did not have the Derby front were the Class 120 units built by Swindon themselves. Nor would the WR have any truck with low density, lightweight cars.
