Alstom celebrating 20 years anniversary of Voyager's introduction
Stephen Lee
7 Jul 2019
RailBusiness Daily, Alstom’s Voyager Fleet celebrate 20 years of Inter-City service in UK
For Alstom, they deserve to celebrate this day, but for passengers, I don't think there is a value to celebrate especially those who usually take XC due to reduction of capacity unless they acquire Class 221s from AWC and 222s from EMR-IC, what do you think?
Bayum
21 Mar 2008
I think they’re right to celebrate. Though the 220/1s were rubbished by passengers, in some cases rightly, they’ve served their purpose and become the backbone of the country. The improvements to the 222s showed an understanding of how to improve the product and what good maintenance does for the fleet.
Just a shame DaFT stipulated what they did.
They were a good first go at a high speed underfloor engined DEMU, and the 80x takes the concept and makes it rather better.
Celebrate, but also move on.
That said, the main complaints tend to be about legroom and overcrowding - both can be solved by running longer trains and a less tight seating arrangement (as the 222s already have). I don't think they are as hated on the WCML where they have the all-tables Coach D and mostly run as 10-car double sets.
Voyagers were transformational in their day, and it was a great pity the e-Voyager was not progressed by Bombardier to make them into bi-modes.
As a WCML user they are the mainstay of Chester/North Wales services and performed well before services were hit by Covid restrictions.
They also worked well on Birmingham-Scotland WCML services and on the many weekend diversions during WCRM (including on the Chiltern route).
It remains to be seen if the (non-tilt) Hitachi 805s on order will match their journey times times on the WCML.
They probably won't, but the discrepancy will be a few minutes, but meanwhile they are more fuel-efficient, less noisy/rattly, have better aircon, have a reliable reservation display system, don't burn diesel under the wires, are more spacious etc. Tilt was all very well but resulted in a very tight body profile. Also the bogs don't stink.
The 80x is altogether a much better train - but being about 20 years newer this should be expected.
What was the first service that was worked by a Voyager?
If I recall rightly there was a Reading-Brum via Oxford shuttle as the first thing they worked. I went down to have a ride on it when I was still a student (2001 ish). I remember they took off like a plane, throwing you back in your seat a bit - sadly the software and/or driving style was later modified for a bit less acceleration. After that they went on existing XC services as double sets. And then later (2005 ish?) came Operation Pumpkin*, something which XC has never really recovered from.
* Operation Princess, the major frequency upgrade which came with a capacity reduction, which was never going to work and did the railway's reputation no good at all, with serious overcrowding from pretty much day one.
hexagon789
2 Sep 2016
Virgin XC and Arriva XC did of course both change the seating. Virgin removed a few seats to increase luggage space within two years of introduction as I recall, AXC later tightened the pitch and inserted more seats.
I don't think a perfect balance can be struck really.
I've never actually seen a copy of the 'Operation Princess' timetable. I know XC cut a number of the lesser used extensions to the likes of Brighton and a more frequent service to Guildford etc but how different was the timetable, I don't recall ever finding a decent description of the changes anywhere.
Try September 2002.
It never lived up to its billing. The grandiose plans for it kept on getting watered down. September 2002 should have been the first stage, with further improvements in 2003, but the introduction didn't work and consequently, I don't think the full aspiration is documented anywhere. From then on, the retraction of the network to core routes was all about bringing stability to the operation.
Part of the problem is that the layout is really inefficient, with there only being seats in about 2/3 of each vehicle. So despite the layout being quite tight, the number of seats is very low.
It'd have worked if they had been 7-car units. The problem was that you can't put a swanky new timetable in place while reducing the overall capacity from what operated before. It was a massive embarrassment.
While you are right, many of the intended services used infrastructure (eg Reading platforms 3 and 7) that wasn't capable of holding longer trains, so the services wouldn't have worked.
hexagon789
2 Sep 2016
Or if there had been about twice as many units perhaps! ;)
Try September 2002.
Well even just the implemented timetable that collapsed so spectacularly.
Would I be looking at the winter 2002 timetable or the summer 2003 one? Something like that?
62 max as built, reduced to 60 for additional luggage space. Increased to 66 by AXC.
Even 66 is ridiculously low for the length of vehicle.
47444
10 Aug 2019
.. it was a great pity the e-Voyager was not progressed by Bombardier to make them into bi-modes.
I don't think it was a choice Bombardier made - DfT wouldn't pay the price Bombardier wanted for the conversion.
Yes, winter 2002 (although there were still some HSTs operational) with highlights like hourly calls at Solihull, four trains a day to Brighton, trains every two hours at Liverpool, five trains a day to Penzance...
I used to travel a fair amount between Reading and Leeds at that time and I remember getting a brand new one on that route. It was all quite exciting !
They've certainly shifted a lot of people in their time.
Indeed, if all services through the core were double sets it'd have worked fine give or take the Reading platform issue noted.
Given that the high density GWR layout (which is a similar idea in terms of the layout, actually with more legroom, and also a 23m vehicle) manages 84 in a full length vehicle or 72 with accessible bog and wheelchair space, it's truly appalling.
RailWonderer
25 Jul 2018
All around the network
A bit of an exaggeration, but I will agree that the vestibule areas are too long, and the cycle space is larger than it needs to be, and the first class coach only uses half the coach for seats. Several people can stand inside the overly large cycle area. Then the legroom area is so tight that I always gun for the airline seats at the end of the coach, as some of those have nicer legroom. I agree, they are inefficiently laid out, but I've always liked the large windows and the squidgy Alstom seats similar to the 390s and 458s, and the tilt for the 221s.
If I was commuting on the Reading-Brum or around the Leeds area I don't think I'd like them as much though. It's been a great 20 years, looking forward to another 10-15.
Is there any plans to replace these?
Well Avanti are replacing theirs with the Hitachi class 805 and 807 units they have on order. But it seems almost inevitable that their 20 Super Voyagers will then be cascaded to XC; the DfT underwrote the lease for 30 years I believe, so they'll be paying for them either way.
185
29 Aug 2010
Good train. Shame about the pollution they kick out - New Street copes well with 158s, 170s etc but one of them parks up.. god it's horrid.
hexagon789
2 Sep 2016
Thank you, now I know what to look for I may have more success in finding the relevant timetable!
Double and splitting or just specific services purely running on the 'core'?
I mean it's got to be just about the worst. The over provision of accessible toilets for one, really eats the space. On the Meridians the same design of intermediate cars seated 70 with the standard toilet, reduced to 68 to increase luggage space.
Not a huge difference but if the fleet was increased to all 5-car and only the end vehicles had accessible toilets it would add up.
Or maybe even if they were all 5-car, even though a small improvement, would’ve been something.
I think there was an early plan to extend 38 sets to 5-car but that obviously never came to fruition.
Immediate? None I'm aware of.
Probably looking at some plans being drawn up in the next 10 years though, what with the various targets on cutting diesel use.
Probably those very beefy lorry engines they have! ;)
TT-ONR-NRN
30 Dec 2016
Farnham
And rightly so they should celebrate. While less popular with your traditional rail enthusiasts who turn their noses up at anything without a loco on the front ;) their levels of reliability put 175/180, CAFs, 80x and IC225s to shame.
10 Jan 2018
The introduction of both Class 220 Voyager and Class 221 Super Voyagers back in the early 2000s was under Virgin Trains as part of ‘Operation Princess’ - that is when the new Voyagers were introduced with fewer carriages than their predecessors (Class 47 + Mk2 carriages and HSTs) but also increased the service frequency.
A four-car Voyager may be a lot shorter than a Class 47 with a rake of six or seven Mk2 coaches, but some XC services have seen a nine-car set (4-car Class 220 or 221 + 5-Car Class 221) which is actually longer than loco-hauled predecessors.
I remember when the Voyagers first came out in the early 2000s when I did trainspotting at Glasgow Central and they were operated by Virgin Cross Country at the time.
Mikey C
11 Feb 2013
Still feels very strange to see the Alstom name in front of these!
Mechanically they've certainly been a success when you compare them to the rival Class 180 made by, ahem, Alstom... I assume Alstom won't be celebrating their 20th anniversary :D
hexagon789
2 Sep 2016
But even a double Voyager (in original configuration) seats less than either a 47+Mk2 or a 2+7 HST.
43096
23 Nov 2015
Although the underfloor bits of a Voyager are “proper Alstom” as they use the Onix traction system.
Shame they didn’t do the same for the 180s. But that was for the Western and the Western wanted hydraulics…
jopsuk
13 May 2008
appreciate the bay at Reading was (is) a restriction, but it would not have been beyond the wit of man to sort that had longer trains been desired. But the concept was shorter, faster, more frequent services.
And yes, the DFT killing the e-Voyager was a massive mis-step in my view and it should be re-invigorated, using the the 222s as well. Find a few spare QSk19 and make them 8 car units for XC and 7 car units for Scotrail, all with two pantograph coaches. Strip the 221s of all tilt kit and new lightweight 220 style bogies. A fantasy, yes. But it makes sense, no?
Maybe even retractable 3rd rail shoes for the XC units...
Unfortunately, at this point I would imagine they're too old (and non-standard) for it to be economically viable.
Failed Unit
26 Jan 2009
Central Belt
I don’t recall at some of the other ends of the route but I do recall them ORCATs raiding scotrail with 1 train every 2 hours to Dundee.
if I recall the have lots of disabled toilets as they were supposed to be 3 classes. Never got off the drawing board (thank goodnes)
