Autumn refresh for GWR Class 165/166 Turbos
I believe Chilterns 165 fleet has a modern design.
All 165s only have the universal toilet as they were only built with one toilet in each unit. The 166s had two toilets, hence retention of the original cubicle in one coach in each unit.
From a personal point of view though, I would like to see the back of them altogether - the sink design was poor and often allowed water to dribble onto the floor, and the narrow wooden door was equally of poor design - somehow a train newer than the 158 fleet seemed to have something with the quality and narrowness
Yes, just a simple raised lip on the length of the sink unit would have prevented a lot of water going on the floor. The metal sink insert that came later didn't really help.
REVUpminster
3 Jan 2021
Paignton
Rear coach of 166218 didn't look that bad to me. Exmouth- Paignton needs the 2+3 seating. All the 166's have been used down here and always used on the school run when they carry 150-200 schoolchildren to Torre.
Parallel
9 Dec 2013
If there is still a functioning Universal Access Toilet on board, would it not make sense just to remove the other one during the refresh? They could replace it with bicycle space.
The accessible toilets are also not known for their reliability due to the tanks filling up, or running out of water, or the sliding doors developing a fault - Though definitely more reliable of the two. It’s not uncommon to find both toilets out of service on the Cardiff to Portsmouth or Gloucester to Weymouth runs.
physics34
1 Dec 2013
Please no. The more loos on a train the better.
Why the hell are there seats facing the toilet entrance like that!
Lack of modesty and thought in these designs
387star
Indeed I agree
Also the single seats along the side of the large toilet are very crampt and were probably imposed to maintain a certain number of seats. Laughably they are reservable as are the middle seats of a row of three.
Four extra seats…
But wasn’t really needed to have 2 pairs facing toilet door, could have been row of single seats facing away on opposite side to toilet.
Because of the huge duct at skirting board height, which prevents wheelchairs from getting anywhere near side wall, would have been easy to do single seat with screen at side for wheelchair bay (effectively in the position of seats 2-4 of 2+3, and still leave wide gangway)
pompeyfan
24 Jan 2012
What is the fuel range on a turbo. I believe SWR diesels are around 1500-1600 miles.
skyhigh
14 Sep 2014
The small toilets have fallen to issues beyond GWRs control. The only company that made the parts for them (and before anyone moans about it and blames GWR, they didn't select the toilet design 30years ago, not their fault BR only asked one company to build parts for it) went bust last year, and so once a toilet fails, if the part isn't in stock, it's unrepairable indefinitely.
Northern are suffering from the same problem on some 158s (mostly in the small toilets on ex-Scotrail stock).
Mike Machin
19 Aug 2017
As I stated in my earlier post, I have stopped using the train entirely between the Solent area and Bristol/Cradiff as the on-board conditions are completely unacceptable in just about every way imaginable. Simply installing new seats and carpets won't make the least bit of difference, the 166 fleet is outdated and completely clapped-out.
With much of their work now being on long-distance inter-regional express services, which also carry a large number of short-distance commuters, surely replacing them with a further brach of Class 195s would be the answer for this type of service, quiet, relaxing, good acceleration, efficient air-conditioning and configured to offer a good compromise suitable for both long and short-distance travellers. I was very impressed with these units.
Problem is that obtaining new diesel units now is not a good move given the need to eliminate diesel traction soon. Using 165s/166s now and hoping the technology moves on in the next ten years is preferable to locking in diesel use for the next 35 years.
1 Sep 2018
Malvern to Minffordd
We must not forget the one, and only so far, refurbishment of 166205, which has quite comfortable standard class seating and ex-HST Leather First Class seats - but I doubt they would be fitted as they've all gone through the Newport Shredder.
Agreed.
There is however no reason, other than cost, why you couldn't refurbish a 166 to look like a 195 inside, and to fit the Chiltern air cooling system which is highly reliable (and also fitted to the GWR 165s?)
Utterly idiotic that all those perfectly acceptable Grammer IC3000s and fancy 1st seats got binned when they could have been fitted to these units and made something really nice like a doors-at-thirds Inverness 158
Edit: this is 166205? It's new cushions on the existing seat frames that look like the HST ones, though flat cloth in Standard. Fair chance the refresh will look like this I reckon.
Interior views of First and Standard in 166205, Wikimedia Commons
166205 subsequently had the flat cloth replaced by the standard GWR pile moquette.
I agree that binning the HST standard class seats does seem like an example of profligate waste.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
Agreed.
205s First Class seats were the same FC seats as before, just recovered to match the then HST First Class of the time. Whether or not they’ll continue with leather in the FC section or the FC section at all remains to be seen, they may chose to match the IET FC or bin it off altogether, as the only Turbo FC route now is the North Downs.
Indeed - both in standard and first class. Those IC3000s could have been used in a lot of other fleets. Perhaps the biggest waste of all were the ones fitted to the 425 & TCs, the last of which where completed in 2015 and the first stood down in 2017. A lot of wastage there!
REVUpminster
3 Jan 2021
Paignton
I thought the 166s were destined in the future for Exeter to replace the 150s while Bristol gets the 165s extended with extra coaches from the redundant electrostar fleet.
Devon and Cornwall always gets the castoffs.
fgwrich
15 Apr 2009
But at least you’ve got the better quality castoffs (short formed HST sets, 150s and 158s that have all been recently refurbished). On the side of that, I really hope the “165 extra coaches + Hybrid Drive” idea is dead. So far other projects which have messed around with EMUs have not exactly proven successful (230 / 769) and the Turbo’s really need replacing with something more suitable, than being re-engineered further and mucked around with. They’re sluggish and bad enough in their current formation as it stands.
I'm sure Northern's passengers would snap them up, give or take the aircon issue. They are much better than what many people are putting up with, e.g. ageing 150s.
FGW_DID
23 Jun 2011
81E
For operational & planning purposes the 16x fleet have a 1200 mile fuel range. However recently it was noted that some diagrams were a bit more “fuel thirsty” than their allotted fuel miles, especially if they involved a lot of branch line running so the depot, as a bit of a safety blanket, work to a 1000 mile limit.
Kite159
27 Jan 2014
West of Andover
And even the 165s won't be around for long on the North Downs route as they are meant to be replaced by the 769s at some point in the future.
I reckon the FC areas on the 166s will go, with the same sort of seats as being fitted to the rest of the train
More likely they'll just disable the sliding doors and keep the seats as Northern have on the 319s/769s.
superalbs
3 Jul 2014
Exeter
Which fleet is this sorry?
RailWonderer
25 Jul 2018
All around the network
Same goes for some of the lines in and out of Bristol, anything less than 3 car 166s and they are sardines in the school hours.
When the class 172s for Chiltern and LM were ordered nearly a decade ago we were all saying that pure diesel orders would decline but with electrification pushed back and trains ageing wholesale, it was obvious that Sprinters, Pacers and now some Turbos were not going to be replaced by EMUs. The case in a few years time will be the same. Much of the West of England will never be viable to electrify so at best we see bi-modes maybe with battery technology. Having used them frequently enough (even if it was a few years ago) the turbos do not have 10 years left in them. Mechanically they are not in the best state after intensive Thames Valley working for 25 years.
cactustwirly
10 Apr 2013
The 150s are staying, the extra 165s are for extra services around Bristol I thought. Anyway it makes sense for Bristol to keep the 166s and Exeter to get 165s if they are getting some at all.
Worth mentioning it's only the 15 or so 3 cars that are being freed up. The 2 cars are staying at Reading for the foreseeable future.
While you are right, it could be the 195s from Northern or 196s from West Midlands which replace the diesel trains in the South West in due course once their routes are electrified. However, to consider that is somewhat speculative. What is important at the moment is getting the Turbos fit for the next ten years.
