TravelDream
- Joined
- 7 Aug 2016
- Messages
- 675
So, you're heading back from Stateside across the Atlantic. The beast from the east has increased head winds along the way. You get on to the ATIS and it tells you there are reports of strong wind shear in the whole region. As you fly down country to join a stack at your preferred London airport, your captain tots up the figures and arrives at the decision that the margin has gone and that you won't have enough fuel to land safely.
Naturally the captain puts out an urgency call and declares a 'Pan' for a fuel emergency which usually prompts ATC to move the aircraft up the landing queue considerably.
Whilst starting their decent, another run on the figures leaves the pilots thinking that they might not have enough fuel to do that, so they divert to the next nearest airport. This time probably calling a distress or 'Mayday' for being fuel critical. Wind shear is an issue because a go-around is quite normal, but you don't have the fuel for that.
On the ground, the diversionary airport might declare a 'Full Emergency' for its emergency response. A Full Emergency by definition is: "an aircraft approaching the airport is, or is suspected to be, in such trouble that there is imminent danger of an accident."
Not every one wants to hear that on a flight do they? Let's be honest, if this doesn't work out, you won't be making it to the diversionary airport. A field on the approach is more likely.
Over to you! What do you tell the punters sat in the back or What do you want to hear?
A few points:
You have a tailwind when flying from the US to Europe when at altitude. Short-term forecasts are pretty accurate nowadays as well.
ATIS is an weather report for a specific aerodrome, not a regional one. To listen to weather reports for a region in flight, pilots use VOLMET. Though this is increasingly being displaced by SATCOM data links.
Modern aircraft have computer which continually work out fuel. If wind shear is expected at the destination/ alternate, a much earlier diversion might be appropriate. Reykjavik/ Shannon/ the Azores are all much closer to the US and can be used dependent on track.
If you are expected to land below reserve fuel, you declare an emergency. That's a mayday call. A pan call is never made for fuel. If you are going to land close to, but above, reserves, you declare minimum fuel.
It's very unsafe, but you would have enough fuel in the reserve fuel to go around and then do another approach. It would be almost on fumes though.
I think you are talking about something very different to everyone else. In the situation you describe, a crash landing is not expected. In your situation, I would expect no communications from the cockpit or cabin crew until after the plane landed.
I, and I think most others, are talking about a serious situation in flight where an emergency landing is going to take place and even a crash-landing/ditching is possible. I'm thinking something like double engine failure, under-carriage failure, electronics system failure etc. In those situations you could have 12 hours plus (e.g. under-carriage failure) between problem identification and landing.
I don't know how to make it more clear. Airline procedures and policies require crew to brief passengers in those situations.
Would I rather be briefed how to take the brace position before landing or die from blunt force trauma from my head slamming into the seat in front of me?
Would I rather be briefed on the correct use of flotation devices before landing or die from inflating my life vest in the cabin and being forced into the top of the cabin and due from drowning?
I'll let you answer them.
