Actually I find the absence of continually scrolling displays and interminable auto announcements and positive.
Maybe, but not if you were a passenger with extra accessibility needs or a tourist.
Funny, I've never a problem working out which stop I'm at, even on my very first trips to London.Maybe, but not if you were a passenger with extra accessibility needs or a tourist.
Only ever saw them in a magazine, not real life but yes, it was the blue one.
Flickriver: Photoset '1986 Tube Stock' by Fortune13
Flickriver - view images as a 'river of photos' and more...www.flickriver.com
Out of interest, is the 1973 stock physically able to fit down the Bakerloo (car length longer than the 1972 stock)?
I wouldn't be surprised to see some 1973 stuff move over onto the Bakerloo when the new Inspiro starts rolling on the Piccadilly.
The 95 stock on the Northern Line has similar length carriages as the 72 stock, and that copes with the sharp bends, such as at Embankment. I imagine the work needed on the Bakerloo to make the 73 stock fit would be significant, and not worth it for their short lifeThe 73 Stock was designed specifically for the Picc, and although it's not massively restricted in where it can go, I think there's issues involved in redeploying it, as the Yerkes-era tube lines have some tight spots in them. I suspect it wouldn't be entirely straightforward, for stock that might be in better condition but is barely any newer. Infrastructure works, training etc might all be too expensive and complicated to be worthwhile.
I find the current interchanges OK. Do you know what they have in mind?Some quite major works including new interchanges, lifts and an entrance. The works will sever the Aldwych branch from the rest of the network.
Years ago there were plans to replace the 1995 tube stock on the Northern line and the 1996 tube stock on the Jubilee line. The 1995 tube stock was meant to go the Bakerloo line while the 1996 tube stock was going to go to the Piccadilly line.The 95 stock on the Northern Line has similar length carriages as the 72 stock, and that copes with the sharp bends, such as at Embankment. I imagine the work needed on the Bakerloo to make the 73 stock fit would be significant, and not worth it for their short life
I don't remember reading that anywhere, and it would be made extra complicated by the Alstom PFI agreement for the 95 stock, with them maintaining the trains as wellYears ago there were plans to replace the 1995 tube stock on the Northern line and the 1996 tube stock on the Jubilee line. The 1995 tube stock was meant to go the Bakerloo line while the 1996 tube stock was going to go to the Piccadilly line.
It was back in 2012 when this was proposed.Really not convinced there's much truth in it.
It was one of the Rail magazines.Got a source? I'm a seasoned Tube-watcher and I've never come across it anywhere. For starters there's far too many 95s for the Bakerloo and not enough 96s for the Picc, and although they look similar, they're completely incompatible with each other.
No it won'tSome transverse seating will be lost when the wheelchair spaces are fitted.
ThanksNo it won't
Wheelchair spaces are going in the special trailer.
No it won't
Around 2011-13 TfL were looking at how they could get more trains to support the Northern Line Extension and the Jubilee Line Upgrade (33tph)Got a source? I'm a seasoned Tube-watcher and I've never come across it anywhere. For starters there's far too many 95s for the Bakerloo and not enough 96s for the Picc, and although they look similar, they're completely incompatible with each other.
The special trailer is the trailer of the 3 car unit, special in many ways;Sorry - what's the "special trailer"?
I seem to remember that all 4 "end" units have transverse seats - ie the ones at each end of the block of 4 and at each end of the block of 3? Is that wrong? Or is the "special" trailer the "inside" (ie non-driving-compartment) one at the end of the block of 3? I guess that one, conceptually, doesn't fit the pattern of the others, which are either an end unit with a compartment, or just an inside trailer. Is that's what's meant by special? If so, maybe I'm misrememebring it as having transverse seats. I'll have to find time for a nip down below to have a look...
Wasn't one of the other suggestions to split the Northern Line, buy new NTfL trains for one branch, and use the 95s to improve the other branch and Jubilee? The 95s and 96s aren't the same, but clearly relatedAround 2011-13 TfL were looking at how they could get more trains to support the Northern Line Extension and the Jubilee Line Upgrade (33tph)
New 95/96 compatible stock was eventually seen as probably too expensive. At the same time the new deep level tube line was also being seriously talked about, the view being that the Piccadilly and Bakerloo lines both needed new stock as soon as possible after 2020.
So you had paper exercises conducted (e.g. 95 stock cascade to Bakerloo) trying to see if you could solve both problems at once by putting the new deep level stock on e.g. one branch of the Northern line first.
I don't think anything was seriously proposed but there was lots of speculation from people who like counting things to see how they hypothetically work.
As it turns out, the Jubilee Line has managed without extra sets by upgrading the turnback at West Hampstead and some other tweaks, whilst the Northern line extension will be managed by ...er... some kind of dark magic arithmetic.
Having the displays help those hard of hearing. The Bakerloo announcements are also way too quiet, I struggle to hear them - they should try to upgrade them to a newer version like what they have on the Victoria Line.
Sorry, what do A and D mean here?The special trailer is the trailer of the 3 car unit, special in many ways;
It's neither A nor D.
It has two sets of separate braking systems, one per bogie.
Includes the cross over for control within the trailer, so it presents A and D at the relevant ends, rather than at the A-D interface of normal trailers, usually the A end of the D.
Is electrically both A and D while being neither A or D.
But... 1972TS 3 car units are (used to be) special in their own way in that they could technically be A or D at their full cab end, depending on which way they're coupled, but that's thanks to the unique way that control wiring is done on the 1972TS (And 1967TS). That's not the case any more now that all the four car units have only got Emergency Couplers at the A end.
