Break Of Journey Using Smartcard
Joshua_Harman
2 Feb 2021
Recently I travelled from Southampton Central To
Eastleigh Using a ticket
Loaded onto my ITSO Smartcard and I Exited the train at
Southampton Airport Parkway and touched the card out using the
smartcard validator and the validator on the platform rejected
and came up with an error message Saying "No Valid Ticket"
When I completed my journey at Eastleigh and touched out I got
The Usual "Journey Completed, Touch Out Sucsess" Message with green
lights,and so I presume that the touch card system (I presume the same will happen with
all ITSO Smartcards) is only programmed for the specified amount of validations
(2 For A Single Ticket, 4 For A Return Ticket)
Is a break of journey permitted with a smartcard? has anyone else had
this issue? What would happen at a gated station?
Next Time I travel to work ill see if I can try it again and see if The error message comes up with a specific code.
alistairlees
29 Dec 2016
Break of journey is determined by the ticket, not the medium on which the ticket is carried. I expect you will be absolutely fine. The issue is with gate coding, not smart cards themselves (ie the same issue could happen with a paper ticket).
Joshua_Harman
2 Feb 2021
I'm pretty sure I was allowed to break my journey at that point, it was a normal Super Off Peak Return from Southampton To Eastleigh, On the outbound Journey I Wouldn't be able to try it with a paper ticket as this happened with a freestanding "We Trust You" Validator
At some point I'll have to try it with a break of journey at a gated station with actual entry gates not just an un-manned station in the middle of nowhere like this,
lkpridgeon
Verified Rep - FastJP
30 Jan 2019
Micheldever Station / Saxilby
For a break of journey using SWR's smartcard there's no need to touch for break of journey at stations that don't have barriers. Generally speaking it's hit and miss as to whether it actually works at the gate but gatestaff don't know how to deal with/check smartcards so just wave you through.
Super off peak tickets may be flagged as invalid by those readers from experience but will still be marked as validated where applicable.
Joshua_Harman
2 Feb 2021
I've Been Waved Through Many Times, I Always Keep The Receipt For The Purchase Tho, Even Tho It Dosent Have All The Details Of The Ticket It Has Served Me Useful Before When Being Questioned About The Ticket On My Smartcard
riceuten
23 May 2018
Both FCC and GTR really struggled with this concept. Numerous gateline staff have told me - even recently - that "break of journey is not allowed"...for a season ticket. That's kind of the whole point with season tickets, but, hey ? Both Smartcards and paper tickets were regularly rejected when I used to break a journey to Huntingdon and St Neots, and inevitably, I would get stuck behind some scratter who had jumped the gates at Biggleswade and was being fined. All because the gates wouldn't recognise the tickets.
Wallsendmag
11 Dec 2014
Wallsend or somewhere in GB
The issus is (was) with the logic on Cubic gates. A recent update should have fixed it though. Our S&B gates don't suffer the same problem.
Haywain
3 Feb 2013
I think very few people would consider break of journey to be “the whole point of season tickets”, given that it also applies to the majority of single/return tickets as well.
Hadders
27 Apr 2011
Forget break of journey, it would be useful if the gates at King's Cross could be correctly programmed to recognise that the return portion of Off Peak Day Returns/Day Travelcards between Stevenage and London are valid in the evening peak. E-tickets work ok but not paper ones.
Haywain
3 Feb 2013
I’m afraid that’s a limitation of the Cubic gate logic that we cannot resolve.
