Charged Heathrow Express when using TFL Rail
kingston
15 Feb 2016
I travelled recently on the 05:02 TfL Rail service Paddington to Heathrow Terminal 5.
This left from Platform 4 (which it seems to do daily from BRTimes): I touched in and touched out at the barriers as normal.
I was charged the Heathrow Express fare for this journey, I guess in retrospect because I touched in at the 'High-speed platforms' barriers' at Paddington.
I assumed this would be an easy fix for a refund by calling TfL - but despite explaining the above, the fundamentals of different platform banks at Paddington, the longer journey time, or the simple fact I touched in at the barriers between me and the train - I was just told no refund is due as I touched in at the 'Heathrow Express' platforms.
Not sure what to do except a charge-back of the Oyster top-up?
Also I guess this is happening to other users of this service?
hkstudent
11 Nov 2018
SE London
I don't think there will be a high chance of Oyster charge-back, as I don't even think TfL Customer Service know that TfL Rail train was diverted to other platform.
What I would suggest is, get a screenshot from realtimetrains / recenttraintimes / any train departure history page, stating which platform that the TfL Rail train departed, and send it in a web form to TfL Oyster team, asking for a refund of the difference in fare.
If they refuse to acknowledge that, I would suggest escalating the case to London Travelwatch
bb21
Emeritus Moderator
4 Feb 2010
I think you can potentially take it further with strong evidence in your case. Did you touch out immediately on arrival at T5?
The first Heathrow Express doesn't seem to be running until 0525 (T5 0546) on weekdays, so if you touched out immediately on arrival at T5, eg. around 0540, it isn't possible for you to have travelled on HX.
Western Sunset
23 Dec 2014
Wimborne, Dorset
HEX go from 6/7 anyway - wouldn't they have their own gateline?
PS The 0502 left from 4 today. You'd have to go through the GW gateline to access it.
Cdd89
8 Jan 2017
Re the low gates element, this was raised in an article on Oyster Rail back in February. It appears the low numbered gates are all configured the same way. @MikeWh might be able to comment further.
MikeWh
15 Jun 2010
Crayford
It's one of a number of problems that catering for the HEx fares has produced. I'll include your story in a new article on my site and follow it up with TfL as they really need to do something.
Brilliant spot.
HEx now only use one platform, but the issue is common to all the gates serving platforms 2-7.
Thanks for the mention.
Mag_seven
1 Sep 2014
here to eternity
Is Paddington unique in that the fare you are charged is dependant on what reader you tap in on? For example if your local service leaves from platform 2-5 and you therefore tap in on one of the Platform 2-5 readers and tap out at say Ealing Broadway, are you charged the HEX fare?
Haywain
3 Feb 2013
There isn’t a HEx fare from Paddington to Ealing Broadway.
Mag_seven
1 Sep 2014
here to eternity
Yes I know that, however that doesn't appear to stop people being charged "as if" they had travelled to or from Heathrow on HEX, purely due to the fact they have touched in/out on the Platforms 2-5 barriers at Paddington:
It’s come to my notice that there is a problem for travelcard holders on Oyster with the gates for platforms 2-5 at Paddington. If you travel in from the West using a ticket to the boundary of the highest zone on your travelcard, then touch out using your travelcard at those gates, you will be charged a fare from Heathrow using Heathrow Express. The same will also apply in reverse. That’s a £22/£25 interest free loan to TfL until the help desk issues a refund.
It might not be the case for a touch in / touch out at Ealing Broadway though - that is the question I am asking.
matt_world2004
5 Nov 2014
You get charged the normal fare. But the journey history says that you left from the Heathrow express platforms
Mag_seven
1 Sep 2014
here to eternity
Thanks for clearing that up. So it looks like:
Tap in at Padd 2-5, travel on X Rail train to stations up to and including Hayes - charged correct fare
Tap in at Padd 2-5, travel on X Rail train to Heathrow - charged HEX fare not X Rail fare
What is the position on platforms 1, 8 and 9?
Are the barrier staff meant to direct passengers to touch out on the readers elsewhere in the station when a TfL Rail train arrives on platforms 2-7 (like they direct Southern passengers to leave platforms 13/14 at Victoria through the side gate to platforms 9-12)?
I guess the problem is that a lot of TfL Rail use of platforms 1-8 is at the time of day (ie start and end) when there aren't barrier staff.
Cdd89
8 Jan 2017
Re the O-R article isn’t the issue specific to travelcards that haven’t touched in? IE travelcard containing Zone 1, not touched-in as started on paper up to BZ2-6, and touched out at Paddington on a HEX reader. If I understand the example correctly the readers appear to assume in the absence of a touch in that a travelcard holder originated from Heathrow.
Charging £0.00 as would usually happen for a reader touched within zones would be an open door to HEX fare evasion for Travelcard holders so I assume the only solution is for TFL to be more selective as to which barriers are configured for HEX and reroute people away from them in case of unusual platforms - like the GEX at Victoria.
Paddington isn’t unique in terms of using certain gatelines to determine (assume?) the service you used, it was also done at Victoria for GatEx...
mattdickinson
14 Nov 2010
Uxbridge
There is still a standalone Oyster validatior near these platforms so a solution in future is to use that instead (if that's not an issue with the gate line staff)
TFN
17 Aug 2017
I don't know if they're still around but when a TfL Rail I was on was diverted onto Platform 4 (in the daytime), we were all guided to touch out at a stand-alone reader just past the gateline on the Platform 5 gates, instead of touching at the barriers. I'm assuming it's to avoid being charged a HeX fare?
This happened after contactless and oyster was extended to Heathrow / Reading.
It's quite difficult isn't it. If they make the notice to touch in at a separate reader when using platforms 2-5 too prominent people who have used Heathrow Express will try to use it when the barriers are open.
I don't really get why they removed the barrier between platforms 2-5 and 6/7. I know that some GWR trains use platform 6 but it would be easy to do what they do at Victoria and direct passengers via the 2-5 barriers to/from platform 6 only when necessary.
On 22 November the entire TfL Rail service appears to be scheduled to use platforms 4 and 5 with platforms 11 and 12 unavailable. However, it seems that the Heathrow branch is shut so no Heathrow travellers to be overcharged.
MikeWh
15 Jun 2010
Crayford
Over 100 fares have been charged since June. TfL are looking into it.
Yes, this is what is supposed to happen, apparently. TfL are liaising with GWR staff to remind them about this. I guess it's harder to police when a TfL Rail train departs from a low numbered platform as people will arrive in dribs and drabs. Arrival is easier as they're all there at the same time.
eoff
15 Aug 2020
East Lothian
I don't undersand why is there a reference in the FOI request to a time limit? Perhaps this is some inside information.
MikeWh has regular correspondence with TfL. He will undoubtedly realise that certain Oyster data is not retained long term.
7 Jan 2009
Yes, this happened to me back in Feb. A bit of a nightmare, although the Oyster 'Help' Line did sort it out pronto when I put the evidence to them.
In the interests of finding a quality solution to the problem of charging differential fares, can I suggest that all the GW operators plus NR solemnly agree that HEx trains will only ever be routed to the HEx gates. Ever. Impossible? Well they manage this in Japan. And they managed it for the first 20 years or so of HEx's life. If UK operators can't do reliably do this, they shouldn't be allowed to change differential fares in this way and thereby create a system in which (at best) unwary travellers must make £22 interest free loans to TfL but more often just ends them making a non-returnable £22 donation....
eoff
15 Aug 2020
East Lothian
Well, based on a recent TV series which follows their revenue inspectors they seem to be able to get journey histories for passengers going back quite some time in order to determine a pattern of fraudulent behaviour.
MikeWh
15 Jun 2010
Crayford
That's a separate database used when history is required to be kept for revenue investigation. Normal journey history is anonymised after 8 weeks.
matt_world2004
5 Nov 2014
When they suspected irregularities they will save a customers journey history. this does not stop regular journey histories being wiped after 8 weeks.
43096
23 Nov 2015
That's customer irregularities. In the case of an operator irregularity (like this), they'll be wiped after the time limit, no doubt.
MikeWh
15 Jun 2010
Crayford
That's quite a cynical view. The data protection policy says that customer identity is detached from history after 8 weeks. If they become aware of an issue like this one then they could take a snapshot of history while it is investigated. They can't retrospectively re-attach the customer data though. However, if a customer produced an emailed journey statement after the 8 week limit then I'd hope that it might be looked upon favourably. But if you're getting monthly email statements then you're probably checking all your history within the time frame.
matt_world2004
5 Nov 2014
The quote above was in response to someone who asked why they keep a record of travel for someone who is suspected of fare evasion and not everyone else.
Horizon22
Jobs & Careers
8 Sep 2019
The issue is also that these earlier morning TfL services often depart from 1-6 due to possessions. And there's often no gateline staff at those times so you could I guess walk through anyway. It becomes an issue too in disruption and would then be an ad-hoc issue for GWR gateline staff to arrange with passengers. Also with Covid, all TfL Rail services diverted to T5 vice T4, which may exacerbate the problem?
I would hope TfL would become aware of this issue as incidents rise - of course these trains aren't even meant to be coming out of Paddington mainline station if Crossrail was running as booked.
Taunton
1 Aug 2013
Well what a ridiculous policy. Do you think their accounts department detach the customer detail from all the invoices they have processed after 8 weeks?
