Class 40 hauling ETH (air con) stock ? ! ?
DB
Guest
18 Nov 2009
I remember having 58013 on a rake of mark 3s in 1989. Also a few 47/0 or 47/3s turned up that year; even had a pair of 31s! Think they didn't drag, the diesel worked Wolverhampton to Nuneaton where loco was changed for an electric.
31/4 has the standard ETS index of 66, so is fine on mk3s apart from the lack of traction power - hence pairs on longer trains.
Richard Scott
13 Dec 2018
One was a 31/4, other was a 31/1. Just it was unusual having 31s on the service, only time ever had them on Nuneaton diversions, others may have experience of them.
hexagon789
2 Sep 2016
Found this article in an online copy of Rail Enthusiast about the use of 40152 on the diverted southbound 'Royal Scot' on 2nd April 1983:
Elecman
31 Dec 2013
Lancashire
I have memories of Class 40s sometimes being used in place of 47s on the Blackpool to Preston leg of the Euston trains back in the late 70s and early 80s. Stock would have been Mk2f air con at the time. I may even have a photo somewhere.
Agreed and I travelled most Fridays behind them in the late 70s/ early 80s
Journeyman
16 Apr 2014
I've got a photo somewhere of a Cross Country train at Reading in the 90s, which had come from somewhere off the electrified network with a pair of 73s in diesel mode at the front. 73s can't provide ETH on diesel.
Cowley
15 Apr 2016
Devon
I think they made it to Birmingham at least a couple times on those services. That would’ve been a long hot journey with no aircon!
Journeyman
16 Apr 2014
Possibly rather a slow one as well! Class 73s were hardly quick on diesel, even with a pair of them.
Cowley
15 Apr 2016
Devon
Yep. Like having a couple of washing machines on a spin cycle up front. :lol:
hexagon789
2 Sep 2016
Plus all the time it took to reach that speed!
I know drivers on the GatEx used to like using the diesel over some of the complicated trackwork where the third rail was rather piecemeal to smooth out the power delivery over the points but that would be been only at about 30-45mph.
Mind you, a double wouldn't be too bad at 1,200hp gross, you'd have about 4/5 the performance of a 33 then.
Ash Bridge
17 Mar 2014
Stockport
Absolutely agree with this. Way back in 1987 had a pair take over a charter train I was onboard from Kensington Olympia to Waterloo that took us on a trip around various NSE commuter lines before eventually reaching the above mentioned terminus. Their sluggish performance on diesel made the previous class 40 feel like an 86/87 electric by comparison!
Coincidentally on the very day you and I first met but without realising it at the time [USER=34117]@Cowley :D
CW2
7 May 2020
Crewe
I think there were 3 occasions when 73s set off north from Reading aiming for New Street on Cross Country services. The first two boiled over and came to a steaming halt in the Banbury / Fenny Compton area.
On Tuesday 28 Jan 1997 I returned home from Paddington to Reading as usual, and was more than a little surprised to see the 14:20 Brighton - Manchester sitting in platform 8 with 73132 + 73139 on the front, having replaced a failed 47/8 on the Southern. The train sat at Reading for some time, presumably sorting out drivers and conductors, then off we went. It being January, it was decidedly chilly - but that meant the EDs were unlikely to overheat. We were 115' late setting off, and 133' late into New Street, with both locos still running.
To get back to class 40+aircon, 40 145 hauled Mk4 stock last Saturday on the Skipton-Appleby charter shuttles.
There was a 47 on the back, though, which may have provided ETH.
Cowley
15 Apr 2016
Devon
And power for the central door locking.
43096
23 Nov 2015
I expect it’s a typo, but it was Mark 3 stock (+ a Mark 2 brake).
randyrippley
21 Feb 2016
Don't believe the supposed performance figures....when the donors for the 73/9 project were tested/benchmarked prior to rebuild they were only outputting around 400hp on diesel.
hexagon789
2 Sep 2016
Interesting - not quite even their listed continuous output on diesel which the diagram book gives as 430hp.
montyburns56
5 Oct 2015
Here's a picture of a 40 on Sunday drag at Kidsgrove with a 87+MK3s in tow.
hexagon789
2 Sep 2016
Sounds about right..I imagine those engines will have shed a few HP over the previous fifty years of their life even with intermittent use versus third rail.
I always overlook that point, that as engines wear they 'lose' hp. I really should remember that from Top Gear when they had some second hand cars they bought tested and one lost more than half it's nominal rated power!
Richard Scott
13 Dec 2018
Know someone who used to work on overhauling engines and he said they struggled to get 2000hp out of class 40 engines even in good condition, however the slight modification of adding intercoolers and turbo mods and the class 50 engine easily could reach its rated 2700hp.
hexagon789
2 Sep 2016
I was informed that 47s, although nominally derated to 2,580hp, in reality only put out about 2,400hp from the engine.
Arguably makes some of their exploits more impressive, though when the CrossCountry ones were on their last legs you wonder how much power they were actually putting out!
Richard Scott
13 Dec 2018
Rated power and actual power certainly show some discrepancies. In reality think there was little to choose between a 47 and a 45 in terms of power output despite the 47 having an on paper advantage of 80hp. When fitted with ETH the 47 was only 13 tons lighter than the 45 so performance gain minimal and possibly 45 was better due to more stages of field weakening. In my observations when dabbled in timing and monitoring performance 50s were way ahead of 47s on same line/schedule so likely the EE unit was close to or on rating and Sulzer possibly lower than rating? Although remember someone saying 50030 was a bit tired and only producing around 2200hp towards the end, this did show as wasn't a great performer.
hexagon789
2 Sep 2016
I have heard more than one ex-driver say they felt a good 45 had the edge over a 47
