Didn't happen on 455s and I don't think it's happened on any of the over Kipe Electric conversions.A combined power & brake controller is the plan I believe.
The other conversions didn’t require the amount of changes to the braking system required by the 442 works.Didn't happen on 455s and I don't think it's happened on any of the over Kipe Electric conversions.
Any idea what unit and what loco is dragging it.Realtime Trains - 577G 0928 Wolverton Centre Sidings to Bournemouth T&R.S.M.D
Realtime Trains provides live realtime running information for the Great British railway network using open data.www.realtimetrains.co.uk
Another unit returning to BM
The locomotives are 47 812 leading and 57 312 trailing.Any idea what unit and what loco is dragging it
Running just under an hour late at the mo, but should catch-up on the schedule if omits the wait at Kew.
Eyeballed 47813 leading (not 812), 442414, 57312 rear.
It'll be getting dark by the time I see it...
Only half an hour late now.
Should run straight through, depending what else is in its path.i thought it was running about 40 mins late at the moment, any idea if it will stop as planned at brockenhurst, or as its late run straight through
Which looking at it, it was just to let the 1438 to Weymouth past, which it will probably be behind now, so yes it should just run through.
Highly unlikely unless there's a fast passenger or something on its tail. At its current lateness I'd reckon it has enough slack to at least arrive Poole about right time.i thought it was running about 40 mins late at the moment, any idea if it will stop as planned at brockenhurst, or as its late run straight through
Four.Anyone know how many barriers?
It's just passed Basing on the fast, but 1W67 has caught it up now, so signaller has routed that around it. So it's likely it won't stop at Brock now, and indeed should hit Poole roughly on time.Highly unlikely unless there's a fast passenger or something on its tail. At its current lateness I'd reckon it has enough slack to at least arrive Poole about right time.
I wouldn’t be surprised if it avoids Poole and goes straight into Bournemouth depot from Branksome
