Class 484 replacing class 483 on the island line: progress updates
VEP3417
27 Jun 2011
Hampshire
is there a reason (in law or a safety booklet ect) that the line has to be so far back? i thought it might have been so in the slam door days if a door was opened whilst going slow into the station, they people wouldnt get hit by it
Without registering for membership you can no longer see the relevant rail group standards. But as I’ve said earlier the yellow lines are only supposed to be provided as a precaution against turbulence caused by passing trains, and are required to be behind the tactiles, and their position is also defined.
So you shouldn’t see them unless the high speeds apply, and not at a terminus platform. Other uses are then piggy backed on them where they already exist, eg someone mentioning I think that they can define a “safe dispatch corridor”.
Slam doors open on a moving train are no longer possible so should not be relevant to any decision anymore.
30907
There must be a particular risk of getting sucked off at Sandown. I'll bear that in mind should I visit the island.
That's Smallbrook BTW. A junction in the middle of nowhere, but you might get a connection... :)
PS back on topic, I suspect the platform is minimum width rather than the tactile paving too far back.
Gloster
4 Sep 2020
Up the creek
Trains do run non-stop through Smallbrook when the Steam Railway isn’t running, but there shouldn’t be any passengers on the platform when there are no connecting steam trains...
I think that’s definitely the most likely reason.
Chris125
12 Nov 2009
Ultimately the yellow line is where the designers of the pre-fab platform system put it - presumably at a distance that will always be compliant with the relevant standards wherever it's used.
Not sure they need a separate line mind, I'd have thought the bright yellow tactile strip would suffice?
the sniper
4 Sep 2007
Thanks for the intel! I'd have been disappointed if I'd gone to the wrong place... I mean, not been aware of the risk there.
cav1975
24 Sep 2010
Gosh, the trains must normally go pretty fast through there. That large yellow line seems to be quite a way back from the platform edge.
In fact Smallbrook Junction is the only Island Line station that regularly sees trains passing through non stop. Even on Steam Railway operating days not all trains stop so there's a reasonable justification.
DelW
15 Jan 2015
Though I think Island Line trains only run through nonstop at times in between steam services, when there wouldn't be anyone on the platform anyway. (For those who don't know the station, there's no non-rail access, and no real reason for anyone to wait there between two steam services).
Speeds of the 484s might be faster now the track has been aligned and tamped, but it's hard to imagine much wind turbulence from passing trains in the days of the 483s bouncing their way along that stretch. You'd be at similar or more risk when standing on a pavement as a truck or bus passes, and there are no yellow lines there.
Chris125
12 Nov 2009
Probably easier to repaint the lines than replace the tactile... tiles.
No paint required - as you can see below the yellow line is attached just like the tactile strip, or you can fit blanks which match the rest of the platform surface.
D365
29 Jun 2012
Hoping that Island Line reopening is on-track. I'm due to visit Ryde in a few weeks.
Chris125
12 Nov 2009
No news feels like good news at the moment - there was a train running after 8PM this evening, perhaps the first to run so late since services stopped in January?
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
One small and slightly surprising thing noted from the Hidden London video posted in the other thread is that the 484s have a different and rather smart Moquette covering the seats, than SWRs now familiar “ski chalet” flat cloth covering. They also have a small luggage rack at the end of each vehicle.
Gloster
4 Sep 2020
Up the creek
Is that luggage rack for passenger use or is it somewhere for the guards to put their clobber? It looks as though it may be behind a door.
spark001uk
20 Aug 2010
Yes as above, it's just the carriage interconnecting door that's been opened against it that's all.
DelW
15 Jan 2015
RTT this morning shows the first down train reaching Shanklin 10 late, and the return working leaving 10 late and reaching St John's 25 late, where it possibly terminated.
Not an encouraging start it would appear!
Goldfish62
14 Feb 2010
Yet nothing on Journeycheck about delays.
Also Journeycheck shows 2 cars but the train has been running as 4 cars.
MotCO
25 Aug 2014
I thought a shortage of rolling stock meant only one train was running instead of two. Why was the train running as 1 train of 4 carriages, instead of running 2 trains of 2 carriages each?
Gloster
4 Sep 2020
Up the creek
And now it appears, according to the County Press and Island Echo, that Wightlink have started refurbishment work in their terminal at Portsmouth Harbour. This will last several months and groups of ten or more should consider using the nearby car ferry..
Sorry: should have been in the Island Line Upgrade thread.
pompeyfan
24 Jan 2012
I thought the plan was to use the other path to continue crew training and fault free running?
MotCO
25 Aug 2014
Is there no capacity to run three trains on the network, even if it means only shuttling back and fro beween a couple of stations, or running a few minutes behind a timetabled train?
Woods
3 Sep 2021
Banbury
Delays and cancellations this morning due to debris on the line apparently, presumably linked to the high winds. Not train related.
