D365
- Joined
- 29 Jun 2012
- Messages
- 11,449
The passing loops at St Johns and Sandown are being used, even in spite of the 1tph service.
In public systems, probably the sequence you suggest (if it does ever get changed later on). In internal industry systems, it could either start with TG, MD or MN and then move between them. The way the cancellation data comes down from TRUST means that the first reason code for a train appears and doesn't get subsequently changed even if it is in TRUST. The latest DAPR might be an interesting bedtime read if you're having issues sleeping.Hypothetically, and only a thought inspired by this (not an accusation). How would the system code it if the train crew not as familiar with new stock couldn't get the train to move ('a fault with the train') but the root cause was actually the driver forgetting to press a particular switch or something ('an issue with train crew' maybe)?
004 was on the 12.45 Pier Head.003 swapped for 004 at St Johns in the morning for some reason - seems they managed to avoid cancelling any services though.
I was told that unit swaps during the day are not uncommon.003 swapped for 004 at St Johns in the morning for some reason - no services cancelled though by the looks of it?
There are two trains an hour during weekday peaks and Saturday daytime.Had my first run on a 484 today from. Shanklin to Ryde Pier Head.
Much to my surprise, today was the first day of a 2 train per hour service, for parts of the day.
The additional trains run either to/from St Johns Road or Ryde Esplanade.
As there is only 1 fast cat per hour it seems that the the non connecting trains are stopping short.
There were 2 SWR Ambassadors on the trains telling passengers about the additional services.
Please correct me if I am wrong but I thought that the connection on the outer ends of the axles were relatively small and not capable of taking the full traction currents. Their purpose was to prevent stray currents from passing through the bearings and possibly causing damage. I thought the brush boxes were on the axles between the wheels and much heftier; designed to take the traction currents into the axles and then into the wheels.The bogies and axles have to be adapted to run on “normal” third rail, on the London area shared routes the LU stock still uses 4th rail traction return, with the mainline stock using running rail return.
Normally traction return via the wheelsets uses a “brush box” which is visible, (with cable connections), on the outer end of a number of axles throughout the train.
It’s possible, the modern installations I’ve researched such as Desiros and Electrostars it’s done on the outside ends. I suppose there must be other designs.Please correct me if I am wrong but I thought that the connection on the outer ends of the axles were relatively small and not capable of taking the full traction currents. Their purpose was to prevent stray currents from passing through the bearings and possibly causing damage. I thought the brush boxes were on the axles between the wheels and much heftier; designed to take the traction currents into the axles and then into the wheels.
What I also see on most modern stock is there are many axles with the return brush gear fitted, possibly a high majority, so the current is split into many parallel paths.Generally speaking, inboard brush boxes were in use for vehicles with high inrush DC currents, modern traction electronics which provide a soft start generally allow for brush boxes on the outer ends of an axle only, with the only exception being those with hollow axles (not that I’m aware of any such vehicles off the top of my head!)
Whereas, as the response to my earlier comments, there needs to be provision for traction currents, maybe this is the case where stray currents are being led away from the bearings. When you consider a roller bearing, there are only 'lines' (as opposed to 'areas')of contact between the races and the rollers and any current passing between them is likely to cause erosion of the rolling components.What I also see on most modern stock is there are many axles with the return brush gear fitted, possibly a high majority, so the current is split into many parallel paths.
I’m not quite sure what you’re getting at. The axle end brush gear still bypasses the bearings for that very reason.Whereas, as the response to my earlier comments, there needs to be provision for traction currents, maybe this is the case where stray currents are being led away from the bearings. When you consider a roller bearing, there are only 'lines' (as opposed to 'areas')of contact between the races and the rollers and any current passing between them is likely to cause erosion of the rolling components.
I was trying to suggest (maybe I should have explained better) that lighter weight connections to the axle ends could be standard practice to prevent stray currents from passing through the bearings on all axles, whilst, as in the previous comments, a heavier duty brush box would be necessary to handle the high traction currents returning through the axles and wheels.
Well assuming the wheelchair space was free surely he could have put the bike there.Had my first ride in a 484 on New Year's Eve. It seemed OK for the Island line, but I did notice three things:
The PA in my coach was badly distorted;
The ride was quite bumpy in places;
When a guy with a bicycle got on, there was nowhere he could put it without blocking the doors, the passage between the seats, or both.
Well, no, but they are routine ones. Shortage of staff in the evening, train failure, axle-counter failure at Smallbrook, etc.Does the fact that there have been no posts for 2 weeks imply that all is running well?
Island Line is suspended this lunchtime (Monday), but although its operator was originally warning it could be until as late as 6pm, it now says trains should be running again by 2pm. Problems have been caused by a fault on a train near Brading.
It means the line between Shanklin and Ryde Pier Head is blocked. Operator South Western Railway (SWR) said it train crew is in contact with its fleet maintenance team, which is investigating and working towards fixing the fault.
Any update please on 484005, has in been in passenger service yet? Thanks for any information.Weeks of near faultless running have come to an end after 004 failed at Brading "due to a problem with the traction equipment" - however once again it seems the unit could self-recover back to the depot, and services resumed with 003 just an hour later.
Broken down train blocks Island Line
Operator South Western Railway says services will start running shortly.www.countypress.co.uk
