Class 810 for East Midlands Railway Construction/Introduction Updates
greatvoyager
15 Aug 2019
Exeter
The 9 car Meridians were around for about a year and a half, and were rather offset by the fact that all the other Meridians were only 4 cars long..
Worthing noting though that the seating capacity of a 5 car 810 at 312 seats (268/44) is only 38 down on the current 7 car meridian seating (244/106), and that around half of the trains formed of 810s will run as pairs - for around 624 seats (88/536) which dwarfs anything that's run before..
That is quite considerable, and I’m looking forward to seeing how the internal layout is.
BayPaul
11 Jul 2019
IMHO by the time you need to rely on niche spaces for knees you have created a train where seats are too close together / densely packed. Again not a feature in my car that I need to think about when choosing how to travel....and cars are getting bigger or so it seems to me.
But as I understand it they aren't relying on this niche space. I've seen hundreds of complaints about seat hardnesson 80x trains on here, but I don't think I've seen a single complaint about seat spacing from someone who has been on the trains, so I really don't think seating density is something you need to worry about!
The rest of the 80x don't, mainly because a considerable benefit (there is one! :) ) of Fainsa's finest is that the back is very thin. FISA LEANs are quite thick backed, so need the "niche".
To give an example, Northern's 158 refurb with ironing boards has very close to the same layout as the originals (only varied to provide priority seats), yet the originals have very poor legroom and the refurbs excellent.
WesternLancer
12 Apr 2019
I hope so!
Glad to hear that.
Domh245
6 Apr 2013
nowhere
Weren't there claims the 810s would have more seats than the 800/802s, despite the shorter vehicle length though?
I don't remember seeing any claims about having more seats, but comparing an 810 to a GWR layout 800/2 there's only a 14 seat difference, and some of that will come from a relatively larger provision of 1st class seats on the 810 (44 v 36)
They beat the LNER layout 5 coach IEPs, which seat 302 (48/254) but those units lose a number of seats to the buffet
43066
24 Nov 2019
Are they still planning to stay on diesel south of Bedford until the OLE has been upgraded? I'd hope however that they can at least start out and accelerate from St Pancras on OLE before dropping the pan, somewhere around Hendon I guess.
Diesel under the wires South of Bedford (subject to modification of OHLE), hotel power at St Pancras to be drawn from the overheads, is the current ambition.
Speculating here but, based on other class 8xx operation, this will presumably require a period of engine pre-warming prior to departure, but will at least avoid the current situation of 222s idling between trips.
py_megapixel
5 Nov 2018
Northern England
Does this mean that the 810s won't use the OHLE for traction power at all in the first instance?
43066
24 Nov 2019
If you've got 25kV to hand, having an electric engine preheat seems the obvious answer there. The 80x do generally, don't they?
I have no idea, but that would certainly make sense, if it’s possible.
Certainly not south of Bedford. Whether pans will be raised for the stretch between Bedford and Kettering (only twenty odd miles) is also an unknown at this stage.
hexagon789
2 Sep 2016
I've seen suggestions they will run electric to Cricklewood then switch to diesel
Again I've read that they would run on OLE out of St Pancras until where linespeed rises above 100mph which is in the region of Cricklewood iirc
AM9
13 May 2014
St Albans
Which might help inner London a bit but if it's a shortcoming of the headspan OLE, when will that be fixed? Apart from the unnecessary CO2 creation, why should Hendon, Mill Hill and Borehamwood have to suffer elevated pollution and noise levels when the infrastructure is there?
Roast Veg
28 Oct 2016
Of these two possibilities, the former is the simplest from an infratructure wear and staff training perspective, but the latter is more deisrable from an environmental (and perhaps fuel cost, though negligable) perspective. I'm sure both have been looked at extensively, and Network Rail will have their preference.
londonmidland
22 Dec 2009
Leicester
If I remember correctly the headspan OLE is 125mph capable, however the single masts aren't. Something to do with the max amount of travel it allows vertically as the pantograph pushes it up I think.
AM9
13 May 2014
St Albans
I was passing the stretch where the MML runs parallel to the M1 on Wednesday and realised then that most of the OLE supports there are single cantilevers with shorter masts, i.e. the distance between the horizontal catenary support arm and angled registration arm, is quite small. Here is a picture I've found:
https://live.staticflickr.com/1783/28055121327_e920dc3e1c_b.jpg
I imagine that the vertical compliance would need to be constrained because there couldn't be much sag. Would it need more conventional geometry single track masts to be installed from scratch?
Edvid
7 Feb 2008
Shallow registration arms on single cantilevers are just one aspect. The bigger issue is the MK3b wire runs, which are only tensioned for 100mph running; mechanically independent arrangements may also be required at crossovers between Radlett and Bedford South Junctions inclusive (which means replacing headspans with portals).
What exactly needs doing, how much it'll cost and whether TPTB will pay for it is still unknown AFAIAA.
There's some explanation in this portion of the MML Electrification updates thread.
hexagon789
2 Sep 2016
It's certainly not ideal, but running electric for at least a proportion of the journey to Bedford is better than nothing I suppose
It was my understanding the latter was going to be the arrangement, but I've not seen any firm confirmation
Master29
19 Feb 2015
I thought it was a 254/47 seating ratio? 268/44 would seem to indicate pretty dense seating with fewer tables considering the reduced carriage length.
Domh245
6 Apr 2013
nowhere
Yes, apologies I was taking the 268/44 from the franchise agreement whilst the series of articles that came out earlier this year quote the 254/47. That said there's only a 14 seat difference between the two standard capacities, 4 (at least, possibly 8) of which would come from a seeming enlarged first class section in the composite coach. I'd expect similar layouts to the rest of the Hitachi 80x, with the 2m difference in vehicle lengths mostly coming from between the doors & vehicle ends compared to the other 80x.
Master29
19 Feb 2015
Indeed. That is where most of the non window seats are. It always seems rather large on the earlier 800's but I always thought that is down to various equipment. perhaps they're looking to improve on the earlier evolutions of the various 800's.
There are no seats in that bit. The non-window seats are on the other side of the door against the door pocket, which protrudes into the passenger compartment. Stuff like toilets, electrical equipment and bike space are in that end bit so they don't need to intrude into the passenger compartment itself. I guess in these shorter units they will need to.
How much time would be lost restricting the trains to only 100mph South of Bedford?
Master29
19 Feb 2015
I wonder if they have a much smaller kitchen than their earlier cousins, hence the ability to squeeze in a few more standard seats.
Pacerman99
23 Apr 2019
Third Rail Land
The food preperation area (not a proper kitchen) will be 3m or so long, so about the same size as on the Hull Trains or Transpennine units. The first class seats in particular will be denser than on the 800s, which have generous legroom. Standard class seats will also be denser, and have only 6 bays of 4per carriage as opposed to 8 on an 800.
Do they? They appear to have normal First Class spacing to me, and on the 1 side it is quite poor as they have been unable to resist the temptation to squash in an extra row.
That doesn't bode well at all, particularly as the FISA LEAN is a much thicker-backed seat than the Fainsa Sophia (the use of which is why the legroom on other 80x is so good).
I'm getting the feeling I won't like these :(
Not much, and effectively none in the peak. I posted the numbers in a thread somewhere, but can’t find them. It’s about a minute south of Luton, and another couple Luton - Bedford, assuming there’s no pathing time (which there is in the peak, lots).
I can’t help but think there is an easy solution to this.
