Following in an even line the general curve of the river, the Embankment extends from Westminster to Blackfriars Bridge, rising at each end by a gentle gradient to open upon Bridge Street, Westminster, opposite the Clock Tower of the Houses of Parliament, and upon Chatham Place, Blackfriars, opposite the station of the Metropolitan District Railway. It passes beneath the Charing Cross Railway Bridge at Hungerford, and the first arch on the Middlesex side of Waterloo Bridge. It is about a mile and a quarter in length, and is 100 feet in width throughout. The carriage-way is 64 feet wide; the footway on the land side 16 feet, and that on the river side 20 feet, planted with trees 20 feet apart. On the river side the footway is bounded by a moulded granite parapet, 3 feet 6 inches in height, and on the land side partly by walls and partly by cast-iron railings.
The wall of the Embankment is a work of extraordinary magnitude and solidity. It is carried down to a depth of 32½ feet below Trinity highwater mark, and 14 feet below low water; and the level of the roadway is generally four feet above high water, rising at the extremities to twenty feet. The rising ground at each extremity is retained by the increased height of the wall, which is built throughout of brick, faced with granite, and founded in Portland cement concrete. The river front presents a slightly concave surface, which is plain from the base to mean high-water level, and is ornamented above that level by mouldings, stopped at intervals of about seventy feet by plain blocks of granite, bearing lamp standards of cast iron, and relieved on the river-face by bronze lions' heads, carrying mooring rings. The uniformity of line is broken at intervals by massive piers of granite (intended to be surmounted with groups of statuary), which flank recesses for steamboat landing-stages; and at other places by stairs projecting into the river, and intended as landingplaces for small craft. The steamboat piers occur at Westminster, Charing Cross, and Waterloo Bridges, and those for small boats midway between Westminster and Charing Cross, and between Charing Cross and Waterloo Bridges, and both are united at the Temple Pier, opposite Essex Street.
www.british-history.ac.uk
