It works the same as a car braking system (minus servo assistance). Plenty of reading material on that.
So how can it "be set for a higher mechanical advantage" within that range? It sounds fixed as what it is.No, caliper assembly, hose and lever comes as a system which is matched to the range of mechanical advantage that normal riders expect to use.
Know any on resetting mechanical advantage?It works the same as a car braking system (minus servo assistance). Plenty of reading material on that.
I said:So how can it "be set for a higher mechanical advantage" within that range? It sounds fixed as what it is. ...
That 'range' is the amount of force that an adult would find reasonable to squeeze the brake lever. I don't know what the level is in lb. or kg. and nor does it matter to me. For a car, the typical pressure to achieve maximum braking force on the wheels is set to around 50-75kg. but owning to the servo assistance of the brakes, it is possible to stop a vehicle of several tonnes weight with than force. On a cycle, - stopping about 10-20kg of cycle plus up to 100kg of personal body weight, there isn't the same weight ratio, so there is no need for a servo assitance. However, by designing in a hand pull of say 50mm, which is reduced to c.2mm at the brake pads, a 25:1 magnification of the hand force gives enough retardation to stop both cycle and rider.No, caliper assembly, hose and lever comes as a system which is matched to the range of mechanical advantage that normal riders expect to use.
Probably not the best way to cycle competitively!... Best to ride carefully and avoid braking as much as possible
Yeah, its pretty understandableI don't think he said it could be adjusted, but rather it was configured that way by virtue of the size of the pistons.
I find bus drivers to mostly be the best fellow road users when cycling.
*One exception in Warrington at a stop line, bus parks next to me then slowly steers left pushing me over onto the kerb... I then realising it was a pain in the neck total clown who I used to work with lol
Disk brakes can be too powerful, for someone used to rim brakes
In some races only rim brakes are allowed because discs could cause serious injury (working like a meat slicer) in crashes
I can't explain it any better than that, but rest assured it works which is why major cycle races usually insist on all competitors having the same type of brakes. If the leaders in a peleton on the Tour De France had hydraulic disc brakes and the rest had simple mechanical brakes, there would be some pretty destructive pile-ups.
I cycle for exercise, do try to push myself and get tired, I never use my rim brakes. Deceleration using back-pedal brake or holding back on fixed, simples
The annual reports of UK homicide statistics include analysis of the suspected attackers as well as victims. Why do the road casualty statistics only analyse the victim types?Cyclist road deaths are a great topic for the media to sensationalise in their news columns, thereby propagating the perception among the public of the foolhardiness of riding a bicycle. Statistics show the risks to cycling of being only slightly greater than those of being a pedestrian.
There are quite a few, and I'll use my judgement to change lanes.
It's often more dangerous to change lanes unnecessarily on a busy A road anyway.
Totally disagree with you on this. My friend living in the flatlands of peterborough cycles to the train staion to work everyday for his commute. I suggested a single speed bike for him due to the lower maintainance required. He finds it absolutely perfect. A perfectly practical and sensible mode of transport, I didn't suggest the back brake.Most UK bikes don't have backpedal brakes, you pretty much only get one of those if you import from Holland or Germany. Fixies and singlespeeds are for enthusiasts (like their running equivalent, barefoot-style shoes), not a sensible, practical mode of transport.
If a road is wide enough that you feel you can safely pass a cyclist without crossing the white line, it should have a physically segregated cycle lane down the side of it. Therefore, If it doesn't have a fully segregated cycle lane (and no a stripe of white paint doesn't count) then you shouldn't be overtaking a cyclist without crossing the central line.
There is no excuse for the poor levels of cycling provision in the UK.
That depends on the road. I use some A roads through rural areas between urban ones that have huge amounts of space in each lane, presumably due to them being regularly used by very large quarry lorries and tractors.
No authority would bother painting a few miles of cycle lane in however, despite it's popularity with cyclists.
I use a fixed-wheel machine in town and often for 20-30 km trips, quite flat here mind. I have a freewheel cycle too but I love fixed a bit more
Thick tyres, dynamo lights carrier
Very practical and not more complicated than necessary
Makes me work a bit harder too, and most tealeaves couldnae get away on it
Many children learn to cycle on fixed-wheel tricycles
@Bletchleyite: have you ridden one?
I shall post a photo of mine
Still far too highCyclist road deaths are a great topic for the media to sensationalise in their news columns, thereby propagating the perception among the public of the foolhardiness of riding a bicycle. Statistics show the risks to cycling of being only slightly greater than those of being a pedestrian.
On a shared use cycle path the priority is for pedestrians. Ringing a bell does not give you priority and can be intimidating to those with sensory disabilities.I tend to avoid shared-use paths whenever possible now. Even with a loud and clear bell, people ignore cyclists. I would also like to see more cyclists with bells attached to their bikes and using them, to be fair. I prefer to ride on the main roads, where I'm not going to come across families and dogwalkers very much and I can put the legs to good use and actually ride at more than 10mph.
