DCR locos
ExRes
16 Dec 2012
Back in Sussex
Two rather well talked about trips today, 60046 worked 0836 6Q42 Ely Papworth to Eastleigh Works via ECML hauling 43423/468/308/467 followed by 60028 on 1151 6Q43 with 43465/296/484/480 via Hertford Loop, a fair stack of pictures on Flickr
BRX
20 Oct 2008
It seems that it turned out there wasn't enough room for the power cars at Eastleigh so some of them are being moved to Willesden tomorrow, not sure if a 60 is involved.
I'm also not sure how it can happen that no-on checks there's space beforehand.
ExRes
16 Dec 2012
Back in Sussex
It does seem as though someone has made a miscalculation on the face of it, but you never know, there may be a cunning plan behind it ...
Both 60028 & 60046 were reported on last nights 2153 0Z61 Eastleigh to Willesden which indicates that either one of them has got to return to Eastleigh for fridays 0936 move to Willesden TMD or there's another loco already at Eastleigh that could be used .....
** Thanks to @Rhysdabeast for an update today, 60028 worked 0Z61 on its own leaving 60046 at Eastleigh for fridays movement
60028 worked this mornings 0223 6V21 Willesden to Westbury Down TC and loaded 1723 6M16 return
*Updated 5th March*
60046 worked 0936 0Z43 Eastleigh Works to Willesden TMD hauling 43467/308/296/423 for temporary storage, then 1400 0Z60 to Wembley HS to pick up 60055 for 1515 0Z62 to Chaddesden via ECML and Melton Mowbray, this was diverted to Humberstone Road to collect 1926 6Z66 for Chaddesden
*Updated 7th March*
60046 worked 1000 6Z31 Chaddesden to WEFOC with 31 JNAs and then shunts between WEFOC and Willesden DC
ExRes
16 Dec 2012
Back in Sussex
Just 60055 out working today on 0845 0Z60 Chaddesden to Gascoigne Wood Sidings and 1223 6Z21 to WH Davis Shirebrook
60028 & 60046 are at Willesden, 60029 at Toton since 7th January, 56091 (8th April) & 56103 (17th December) at Leicester LIP
*Updated 13th March*
60055 worked 1022 6Z60 WH Davis Shirebrook to Gascoigne Wood Sdgs with 9 converted former coal hoppers
One of 60028/046 moved another set of wagons from WEFOC over to Willesden
*Updated 15th March*
60055 worked 1330 6Z61 Gascoigne Wood Sdgs to WH Davis Shirebrook with another 11 coal hoppers for conversion then 1822 0Z61 to Chaddesden
*Updated 17th March*
60055 called upon for 1100 0Z60 Chaddesden to Rectory Total Sidings to assist the failed 125 Group HST set, after some shunting the 125 Group set left on one power car while 055 stayed overnight at Rectory TS
*Updated 18th March*
60055 returned to Chaddesden as 1253 0Z61 from Rectory Total Sidings
ExRes
16 Dec 2012
Back in Sussex
Another unusual day out for 60055 today, after a change to an original Long Marston schedule 055 accompanied the Class 56 Groups 56301 on a first test run after having been out of service for a couple of years, the 56 hauled the 60 and 24 empty JNAs on 1248 6Z56 Chaddesden to York Holgate Siding, sadly the 56 failed at Aldwarke Junction forcing a run round with 055 hauling the set back to Chaddesden as 1628 6Z57
*Updated 21st March*
60055 worked yesterdays 1408 0Z61 Chaddesden to Leicester LIP returning C56G 56301 for attention then 1551 0Z60 return, 055 has worked todays 1500 6Z20 Chaddesden to Kingmoor VQ via WCML with 24 JNAs
*Updated 23rd March*
60055 worked last nights loaded 2104 6Z31 Kingmoor VQ to Humberstone Road via Hexham, ECML and Erewash and todays 1611 6Z22 return via Nottingham, ECML and Hexham
60028 worked 0223 6V21 Willesden to Westbury Down TC and loaded 1723 6M16 return
*Updated 26th March*
60055 worked wednesday nights 2104 6Z21 Kingmoor VQ to Humberstone Road via Hexham, ECML and Nottingham, yesterdays 6Z22 was cancelled due to a rail defect and returned to Carlisle as 1828 6Z24 via Nuneaton and WCML
60028 worked yesterdays 0223 6V21 Willesden to Westbury Down TC and 1723 6M16 return
ExRes
16 Dec 2012
Back in Sussex
60028 & 60046 finishing the week at Willesden, 60029 at Toton and 56091 & 56103 at Leicester LIP
60055 worked last nights 2104 6Z21 Kingmoor VQ to Humberstone Road via Hexham, ECML and Nottingham and then 1543 6Z60 to Chaddesden
*Updated 28th March*
HNRC 20118 & 20132 worked DCR 1403 0Z20 Worksop Down Yard to Chaddesden today, they will be on one of either Acton TC or Long Marston tomorrow
ExRes
16 Dec 2012
Back in Sussex
ExRes
16 Dec 2012
Back in Sussex
60055 worked 0725 0Z62 Willesden 'F' Sidlngs to Bristol Freightliner Terminal and a 195 early 1600 0Z63 to Bristol Temple Meads, scheduled for some Bristol - Westbury trips tomorrow
*Updated 31st March*
60028 working routes today on 0949 0Z60 Willesden to Reading, 1055 0Z61 to West Ealing Loop, 1257 0Z62 to Reading, 1402 0Z63 to West Ealing Loop, 1605 0Z64 to Reading, 1712 0Z65 to West Ealing Loop, 1821 0Z66 to Reading and 1908 0Z67 to Willesden, same again scheduled tomorrow
60055 worked 0909 0Z60 Bristol Temple Meads to Westbury, 1019 0Z61 to Bristol Freightliner Terminal, 1127 0Z62 to Westbury, 1257 0Z63 to Bristol FT and 1354 0Z64 to Bristol TM, scheduled again tomorrow
*Updated 1st April*
60028 & 60055 both worked identical routes to yesterday, 055 is scheduled for more tomorrow
HNRC 20132 & 20118 returned home today on 1139 0Z20 Chaddesden to Worksop Down Yard
*Updated 2nd April*
Another day of routes for 60055 on 0Z60, 0Z61, 0Z62, 0Z63 as previously and then 1354 0Z65 Bristol FT to Willesden
60046 worked 1012 0Z60 Willesden to Leicester LIP
60028 is at Willesden, 60029 at Toton and 56091 & 56103 at Leicester LIP
ExRes
16 Dec 2012
Back in Sussex
60028 back out on routes yesterday working 0949 0Z60 Willesden to Reading, 1055 0Z61 to West Ealing Loop, 1304 0Z62 to Reading and 1403 0Z70 to Willesden
After almost a year out 56091 returned on test yesterday, accompanied by 60046 it worked 1006 0Z60 Leicester LIP to Chaddesden to form 1129 6Z22 to York Holgate Sidings and booked 1525 6Z24 return, unfortunately the 56 expired at Alfreton on the outward trip requiring the locos to run round at Morton Jct and return as 1448 6Z22 Morton to Chaddesden, they then ran as 1700 0Z60 to Leicester LIP
FGW_DID
23 Jun 2011
81E
Today at Reading:
60055 on 0Z60 Willesden - Reading and 60028 on 0Z53 Bristol TM - Willesden.
ExRes
16 Dec 2012
Back in Sussex
60028 worked this mornings 0700 0Z50 Willesden to Bristol Temple Meads routes/trainer, then 1034 0Z51 to Westbury, 1130 0Z52 to Bristol TM and 1303 0Z53 to Willesden
60055, also on routes/training, worked 0949 0Z60 Willesden to Reading then 1055 0Z61, 1403 0Z63 & 1712 0Z65 to West Ealing Loop, 1304 0Z62, 1605 0Z64 & 1821 0Z66 to Reading then 1908 0Z67 to Willesden
Another routes/trainer was 60046 on 0906 0Z56 Leicester LIP to Derby, 1005 0Z56 to York Holgate Siding and 1213 0Z57 to Chaddesden
*Updated 8th April*
60055 on Bristol duty today working 0725 0V49 Willesden to Bristol Freightliner Terminal, 1127 0Z52, 1354 0Z54 & 1543 0Z56 to Westbury and 1257 0Z53 & 1448 0Z55 to Bristol FT then 1654 0Z57 to Bristol Temple Meads
60028 worked 0949 Willesden to Reading, 1055 0Z61 to Heathrow Airport Jct, 1221 0Z62 to Reading, 1403 0Z63 to West Ealing Loop, 1605 0Z64 to Reading and 1700 0Z65 to WEFOC
60046 worked 1100 0Z60 Chaddesden to WEFOC via Leicester and WCML
Rhysdabeast
10 Apr 2020
Crewe
60028 and 60046 worked 5Q30 09:31 Wembley Yard to Derby Litchurch Lane today moving 730101.
Full consist: 60028 + 8047370436 8047370238 8047370279 8027970192 730101 8027970200 8047370097 8047370071 + 60046
ExRes
16 Dec 2012
Back in Sussex
Interesting that the barrier wagons are operated by RailAdventure as will, allegedly, the Class 43s currently at Eastleigh and Willesden, perhaps more work in future for a Hanson & Hall / RailAdventure / DC Railfreight combination?
After dropping off the 730 both 60s took the barriers into Chaddesden then 028 ran as 1500 0Z60 to Toton
60055 continued routes/training on 0800 0Z50 Bristol Temple Meads to Reading, 1032 0Z51 to Newbury Racecourse, 1128 0Z52 to Reading, 1200 0Z53 to Newbury Racecourse and 1250 0Z54 to Willesden
Rhysdabeast
10 Apr 2020
Crewe
20132 + 20118 going back on hire to DCR should work 0Z20 Worksop to Chaddesden today then 6Z30 to Wembley tommorow with barriers used on 5Q30 which ran on Friday.
ExRes
16 Dec 2012
Back in Sussex
Nice route tomorrow for any photographers who happen to be out and about, assuming all runs as currently shown it's 1208 off Chaddesden via Loughborough (1245), Melton Mowbray (1315), Harringworth Viaduct (1350ish), Corby (1407), Bedford (1510), Bletchley (1618) & Wembley Central (1730), it also looks as though the 20s will then be working 1821 WEFOC to Eastleigh TRSMD
HstFan33
12 Jun 2020
Any news on where the Class 20's will go after heading to Eastleigh TRSMD.
ExRes
16 Dec 2012
Back in Sussex
Stacks of pictures on Flickr this evening of the 20s working 6Z30 with the RailAdventure wagons from the 730101 transfer along with another of their barrier sets, they then continued on 1821 0Z60 to Eastleigh TRSMD for tomorrows 5X20 which, according to Hanson & Hall facebook, is eight Mk3s for storage at Long Marston, possibly the Anglia set that DCR moved there from Norwich last April
HstFan33
12 Jun 2020
Any news on the 20's they were due off 1 hour ago but not left yet. Just wondering as I am currently waiting at Warminster Station
Rhysdabeast
10 Apr 2020
Crewe
Formation for 5X20: 12041 12115 12019 12027 12012 12026 12151 12094. All of them with Chiltern Railways branding
ExRes
16 Dec 2012
Back in Sussex
Rather late start for 5X20 this morning, reported elsewhere that the 20s were on depot at 0930 so presumably a problem attaching to the coaches, eventually 135 late at Long Marston making the following 1530 0Z20 move 126 late into Chaddesden
Schedules current showing for the first Willesden - Bristol Freightliner Terminal - Willesden stone train tomorrow morning
56091
23 Aug 2017
Miles out on the presumption there........
ExRes
16 Dec 2012
Back in Sussex
Yes, I was thinking back to my days of loco hauled when it was 99% what you were hooking up to that caused the problems, serves me right for falling for the old 'assumption' trick ........
The 20s returned home on 0942 0Z20 Chaddesden to Worksop Down Yard this morning, they've certainly had a big presence on Flickr recently
60055 worked the debut 0449 6Z23 Willesden to Bristol Freightliner Terminal and loaded 1459 6Z24 return
*Updated 15th April*
60046 worked 1700 0Z60 Chaddesden to Willesden
*Updated 16th April*
60055 worked 1012 6Z60 Willesden to Chaddesden but failed at Biggleswade, it was rescued by GBRf 66705 and arrived at Peterborough 210 late, 60028 was sent as 1535 0Z60 from Toton and took 055 and its train as 1801 6Z61 on to Chaddesden
*Updated 17th April*
Just 60028 out today taking yesterdays failed 60055 on 1159 0Z69 Chaddesden to Toton and then returning solo as 1410 0Z61
*Updated 19th April*
60028 worked todays 1546 6C59 Chaddesden to Carlisle Kingmoor VQ
60046 was on 1600 0Z60 Willesden to Bristol Temple Meads, scheduled for some more routes tomorrow
*Updated 20th April*
Just one day of routes for 60046 on 0909 0Z60 Bristol Temple Meads to Westbury, 1019 0Z61, 1257 0Z63 & 1459 0Z65 to Bristol Freightliner Terminal, 1127 0Z62 & 1354 0Z64 to Westbury and 1601 0Z70 to Willesden
60028 is working tonights loaded 2104 6Z21 Kingmoor to Humberstone Road
ExRes
16 Dec 2012
Back in Sussex
After arriving with last nights 6Z21 to Humberstone Road via Hexham, ECML & Nottingham 60028 worked 1611 6Z22 to Chaddesden and 1840 6Z23 to Kingmoor VQ via Crewe
60046 worked 0449 6Z23 Willesden to Bristol Freightliner Terminal and loaded 1459 6Z24 return
*Updated 22nd April*
Back down West for 60046 on 1558 0Z60 Willesden to Bristol Temple Meads for routes again tomorrow
*Updated 23rd April*
60028 worked last nights 2104 6Z21 Kingmoor to Humberstone and then 1611 6Z60 empties to Chaddesden
60046 spent another day on routes/learners 0909 0Z60 Bristol TM to Westbury, 1019 0Z61 & 1257 0Z63 to Bristol FT, 1127 0Z62 to Westbury and 1354 0Z70 to Willesden
*Updated 27th April*
60028 worked 0749 0Z60 Chaddesden to Willesden via ECML and Hertford Loop
