December 2020 Timetable Change
Wilts Wanderer
21 Nov 2016
The direct “Intercity” service between London and Holyhead, has existed since the mid-1800s.
It really isn’t anything new.
There was an overnight sleeper service (down only) until 1986! The sleeper coaches were returned to London on the daytime Irish Mail service.
I thought it was Up only - 0100-ish from Holyhead - as the Down connected with a ferry leaving about 0300 so got you much less sleep if you were going to Ireland.
Wilts Wanderer
21 Nov 2016
Perhaps it was - I may have misremembered what I’ve read.
berneyarms
26 Nov 2013
Dublin
Correct - the sleeper was Holyhead-London connecting off the 20:45 Sealink sailing from Dún Laoghaire by the St. Columba.
Some people may be too young to realise the massive volume of foot passenger traffic across the Irish Sea, prior to the arrival of Ryanair in 1985.
Y Ddraig Coch
1 Nov 2013
Footfall will return in decent numbers when duty free trips start again on Jan 1st :)
Jamesrob637
12 Aug 2016
If only Ireland were a bit sunnier... or at least less rainy... I'd move there in the new year in a heartbeat if I had fewer commitments here. But I think we're discussing other things than next month's timetable change.
43055
8 Mar 2018
EMR PDF timetables are now on the website. Looks like it is the same base timetable as the September one but the Worksop services once again stop at all stations in the day so no buses are required to fill the gaps. The London timetable shows services run just by HSTs or 222s but 180s are due in service and HSTs reduced.
peters
28 Jul 2020
Cheshire
Wouldn't fancy turning up expecting a HST and getting a 180 !
To be fair if you turn up for an Intercity service and get an Intercity train you can't complain that it's not your preferred type, unless it's too small for the number of passengers. It's worse that Pacers got used on long services, while some short local services got regional standard trains.
43055
8 Mar 2018
Personally I wouldn't mind a 180. Only been on them once and I quite like them but I do prefer a HST to a 222 or 180.
Looking at Real Time Trains it does look like the diagrams are going to change quite a bit in December and HST use may become fairly limited in the day. The three HST from Neville Hill depot in the morning go to Cricklewood after arriving in London and the evening trips all come off Cricklewood at some point in the afternoon. The platform numbers at St Pancras suggests that the Nottingham Fasts will interwork with other services which removes the 70 min layover and reducing the need to double up on platforms.
43074
10 Oct 2012
There are also significantly more EMR ECS between St Pancras and Cricklewood compared to now from the December timetable, which is a blatant attempt to keep the mileage down to a minimum on the remaining HST diagrams, and cover whatever possible with the 222/180 fleet, which is sensible enough if they can get the 180s to work.
There will be at least some opportunities for off peak HST trips though, e.g. reading into RTT 1434 St Pancras to Nottingham and 1645 return which then forms the 1904 to Leeds.
HamworthyGoods
15 Jan 2019
The biggest driver behind this is to try and provide ‘accessible’ stock on as many journeys as possible.
Scotrail314209
1 Feb 2017
Edinburgh
Scotrail announcing a reduction from 30th November, apparently reducing trains between Edinburgh and Glasgow. Looking at the timetable, I see no difference from any other time?
----- NEW POST ----
From 14th December Scotrail are cutting the hourly fast service via Shotts. Shotts returns to an hourly train service.
diamond chap
25 Mar 2016
----- NEW POST ----
I noticed a difference on the Falkirk High route - there are currently 15 minutes between successive services in the weekday morning and evening peaks and 30 minutes during the rest of the day. From the timetable change, the service reduces to every 30 minutes all day.
Jamesrob637
12 Aug 2016
Looking at Stockport the South TPE gaps seem to have been plugged to reinstate the full service.
D6975
26 Nov 2009
Bristol
The eNRT has been postponed. From the NR Site:​
December 2020 NRT – update​
The December 2020 NRT has been postponed due to the COVID-19 pandemic’s impact on the volume of change on the operational timetable. This level of change means we cannot produce an NRT that represents a high standard of accuracy and therefore would not benefit our customers.
We will update the site in future when we have a proposed date for the NRT to be published.
In the meantime please refer to National Rail Enquiries' website for the latest operator timetables.
TEW
16 May 2008
SWR's planned December 2020 timetable change will not be going ahead as planned now. The weekday timetable will run as per now until March, although the new weekend timetable will come in. RTT now reflects this.
HamworthyGoods
15 Jan 2019
So TPE December timetable will not go ahead also?
TPE’s timetable was also ‘descoped’ from what was originally planned. This descoped timetable has been in the downstream systems such as National Rail and Real Time Trains for a couple of weeks at least now.
SWR’s has only more recently been uploaded to these systems.
DaveHarries
12 Dec 2011
England
GWR have a poster at Bristol Temple Meads giving at least some of their changes from 13th December and RTT does carry these. Cuts to late evening and Sunday morning services from Bristol, Didcot, Oxford and Paddington for starters but there are some increases in weekday services as well along with additional services between Par and Newquay.
Dave
Mintona
8 Jan 2006
South West
Wow, that is late first London from Bristol on a Sunday. It’s been 07.45 since I can remember.
I’m guessing it is probably as much to do with Bristol East Jn remodelling work as anything else.
Wilts Wanderer
21 Nov 2016
Yes, there is a very significant bank of work to be undertaken by Network Rail to ensure next summer’s Bristol East blockades can go ahead, and follow up work afterward.
peters
28 Jul 2020
Cheshire
Some Northern services for w/c 15/12/2020 included in the new pdf timetable booklets are currently missing on RTT.
jonnyfan
6 Apr 2013
Manchester
There's going to be some services removed temporarily until mid-January due to increasing levels of covid related absence around the Manchester & Liverpool depots - I'd expect something on the website shortly to explain any changes
peters
28 Jul 2020
Cheshire
Not good for anyone who already has bought Advance tickets for travel over Christmas. There is already a message about Liverpool to Manchester 'service amendments' for this week.
**Update**
Northern's pdf timetables have been updated. Some services now have a W at the top of the column, meaning the service doesn't operate until 25th January.
js1000
14 Jun 2014
I presume these are the missing Liverpool to Manchester Airport express services? We were expecting an uplift of 10 services in December. I think there are only 6 accounted for on RTT currently.
