An hourly XC service between Exeter and Birmingham would be a start.Also fingers crossed XC reintroduce their hourly Newcastle to Reading service via Doncaster
Didn’t help that SWR would take input from individuals, only stakeholders (groups) they identified.No, the current timetable is a permanent reduction. There was a consultation on it I believe (though like all "consultations", the outcome was largely decided before it was even published!).
Presumably you meant would not take input?Didn’t help that SWR would take input from individuals, only stakeholders (groups) they identified.
Yes - apologies. SWR determined who could respond and it did not include passengers.Presumably you meant would not take input?
They said:Yes - apologies. SWR determined who could respond and it did not include passengers.
It’s also important to note that SWR said:We are considering a specification for services rather than specific trains or a timetable. It is for that reason that we are consulting with a defined set of organisations, which have a strategic or representative role rather than the wider community. This includes all MPs and district and county councillors across our network, as well as passenger groups amongst others.
SWR have badly managed those new patterns of travel and have so far failed to meet demand.How will you respond if passenger numbers recover more quickly, or new patterns of travelling emerge, before December 2022?
Our comprehensive customer research does not suggest that this is likely. However, we view this outline specification as a baseline for the future and, working within the set parameters for timetable changes, SWR and Network Rail will discuss how best to respond to emerging travel patterns with the Department for Transport.
That’s what I was dreading. I travel frequently at weekends between Gloucester and Bristol and for a few months now the hourly trains have been overcrowded. The only way to be sure of a seat now is to change at Severn Tunnel Junction.Will probably get deferred again unless there is serious progress with getting the 769s into traffic and the Reading 165s released and through the refurbishment programme.
Extremely poor that it hasn’t returned at the very least considering their desire to go half hourly with all Manchester-Bristols extended through.An hourly XC service between Exeter and Birmingham would be a start.
I thought that was dropped after the relevant consultation when they came up against resistance from the natives of Paignton? It certainly went a bit quiet.Extremely poor that it hasn’t returned at the very least considering their desire to go half hourly with all Manchester-Bristols extended through.
It is possibly revised with the prospect of more 221s heading XCs way & the platform 2 extension at St.David’s.I thought that was dropped after the relevant consultation when they came up against resistance from the natives of Paignton? It certainly went a bit quiet.
This is some stuff for Southeastern for December
- Orpington-Cannon Street stoppers no longer call at Lewisham
- Sevenoaks-Charing Cross will additionally call at Lewisham
- 4TPH Orpington-Victoria in the peak
Well the timetable didn’t support the 2tph Thameslink, the multiple Southeastern services and then any stuff coming across Bickley Junction.Has the issue being resolved around Orpington terminating platforms capacity/congestion then tied in with Thameslink or has there been a subsequent decline in the GTR services?
This is excellent news. The same should probably happen, if they could make it so, for the stuff from Gravesend to Charing Cross to create more direct journeys and DLR connections.This is some stuff for Southeastern for December
As it is, with a standard pattern and only 6tph via Grove Park (2 of which don’t use the bays) and you should be able to achieve 10tph in 3 bays.
Isn't the reduction with trains from Victoria which used to be 4tph to Orpington, cut back to 2tph with the other 2tph spinning at Bromley South (effectively replaced by the 2tph Thameslink to Orpington if they ever come back)?Yes so my question is what’s different. Charing X or Cannon St services reduced?
What's the logic behind swapping the Lewisham stops from the Orpington to the Sevenoaks train? Now passengers from Dunton Green, Knockholt and Chelsfield face an even longer journey into London, especially since the removal of the 2tph Tunbridge Wells - Charing X there is now no fast connection available at Orpington.This is some stuff for Southeastern for December
If I lived in a small village that has always had Metro services, I would probably enjoy and appreciate the Lewisham connection which previously I couldn’t have. It opens up more than it closes, including Denmark Hill (off peak via Lewisham not necessitating a change) and makes journeys to New Cross for the Overground slightly faster, too.What's the logic behind swapping the Lewisham stops from the Orpington to the Sevenoaks train? Now passengers from Dunton Green, Knockholt and Chelsfield face an even longer journey into London, especially since the removal of the 2tph Tunbridge Wells - Charing X there is now no fast connection available at Orpington.
For example, when the ex-Tunbridge Wells trains ran off-peak it was possible to make the change at Orpington and do Dunton Green - London Bridge in about 30 minutes. Since the removal of the xx21 and xx51 Tunbridge Wells - Charing X, the scheduled journey time has increased to 37 minutes, and the detour to Lewisham would increase it to around 42 minutes. Unless there's a retiming of the remaing Hastings - Charing X trains to connect at Orpington, or the reinstatement of the TBW trains, this seems like a pretty poor state of affairs.
Though the trains that the platform 2 extension was intended for (hourly Exeter Manchester) can't return anyway, most of those paths are now taken by GWR Penzance-Cardiff services xx54 (ish) past the hour from Exeter St DavidsIt is possibly revised with the prospect of more 221s heading XCs way & the platform 2 extension at St.David’s.
I personally don't think anything should be terminating at Bristol from the north as it just leaves passengers waiting for the next XC south. They must continue at least to Taunton or Exeter in order to allow passengers to access GWR for services to the south west. Terminating at Bristol may be operationally convenient for XC but it really isn't for passengers.Extremely poor that it hasn’t returned at the very least considering their desire to go half hourly with all Manchester-Bristols extended through.
I hear you & agree matey.I personally don't think anything should be terminating at Bristol from the north as it just leaves passengers waiting for the next XC south. They must continue at least to Taunton or Exeter in order to allow passengers to access GWR for services to the south west. Terminating at Bristol may be operationally convenient for XC but it really isn't for passengers.
Supposed to be still but I’m going more for May 23 now rather than this December.Interesting to see if the GEML is recast with the 720s coming online
Would make sense with the WAML likely to get recast in May 23 as well.Supposed to be still but I’m going more for May 23 now rather than this December.
The rest of it is even more interesting.This is some stuff for Southeastern for December
Does it? Bristol is a major destination in its own right.
