Derailment at Redhill 17/7
DelW
15 Jan 2015
Local travel news this morning referred to an earlier derailment causing delays to Reigate - Gatwick and Redhill - Tonbridge services.
At the moment (08:00) there is a GWR unit stationary on the Tonbridge line south of Redhill (which is highly unusual), with a Southern unit at a stand beyond it. These are either on the up running line, or possibly on the adjacent siding. The down Tonbridge line is evidently clear, as a Southern service has just departed that way.
Does anyone have more info' on what happened, and particularly how a GWR unit apparently ended up heading towards Tonbridge?
Dren Ahmeti
17 Oct 2017
Bristol
5O90 (GWR ECS) derailed going into the Redhill Loco Sidings (which, if my memory serves me correctly, is on the Up Tonbridge), delays were caused as the derailed unit was accentuating the track circuits in the station throat.
DelW
15 Jan 2015
Thanks for the explanation, I presume that must mean GWR stable one or more units at Redhill overnight? I'd always assumed they returned to Reading for the night, but I suppose that would involve a lot of ECS mileage.
30 Jul 2015
Normally two turbos stable every night at Redhill off 2235 & 2334 Reading - Gatwick for 0510 Gatwick - Reading & 0619 Redhill - Reading
Dren Ahmeti
17 Oct 2017
Bristol
One very lucky Reading driver gets that job, works the last and first Reading back, if I remember the job correctly.
DelW
15 Jan 2015
Ah, thanks, that makes sense, I'd never really thought about where they might be out-stationed.
Just to update what i said earlier, I think the Southern unit might be on a siding rather than the running line. And the GWR unit has evidently been split, it's only two coaches with a corridor connection visible at the north end, so the northern end driving car has gone elsewhere.
I shall keep an eye open for developments, no sign of activity around it at the moment, though the trees get rather in the way of my view.
Assuming that they're not given anything to do between the arrival of their train at Redhill and then the departure some hours later those drivers must know all the best places to have a kip on a Turbo then! :lol:
big all
23 Sep 2018
redhill
some thing coming out the loco trap points could cause this
you used to be able to leave redhill up side via the up road to the crossover at earlswood via dummy[shunt signal ]movements then cross over at the oil siding crossover to the down road but that was 25+ years ago
its probably very different now.??
Sunset route
27 Oct 2015
With HG track circuit being occupied you can’t normalise 1944 points to be able to use that route or ever could in this situation.
DelW
15 Jan 2015
Seems to be being cleared up now (09:40), orange suited personnel in attendance and the GWR coaches have been moved further into the yard. Can't tell whether there is any track repair work in progress, too far away and trees in the way.
HamworthyGoods
15 Jan 2019
There are Great Western conductors at Redhill however the workings that start and finish at Redhill overnight are worked by Southern Redhill drivers.
JN114
28 Jun 2005
Not anymore - Since the May TT change the two “Southern” diagrams work (amongst other bits) the 0619 Redhill - Reading (2V47); and the 2234 Reading - Gatwick (2O88). Dren is correct that the last one over and first back is now a Reading night turn.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
Indeed. Previously GWR drivers based at Reading would have been taxied back to Reading, however as you and Dren say this is now a night turn. And yes, some of the driver's happen to know where the best bit to kip on a Turbo is. My choice would easily be the ex / non ex FC end.
AndyPJG
29 Jun 2012
Anything to do with this thread? (https://www.railforums.co.uk/threads/derailment-at-redhill-17-7.186319/#post-4110001)
embers25
16 Jul 2009
SWR do the same overnight stint on the last down and from Up Exeter train.
DelW
15 Jan 2015
What happened?...
I assume this is at Redhill (there is no context!). If so, there was a depot derailment.
That single coach is standing at the north end of platform 1 at Redhill (which is a dead end since platform 0 opened) so it must indeed have been the missing coach from the derailed set.
Summary from the National Rail cleared disruptions list:https://www.nationalrail.co.uk/service_disruptions/cleared.aspx
Quote: "trains are now running normally through Redhill following a low speed derailment at the station earlier today"
11 Jun 2011
Red'ill
So, the GWR drivers sleep on the train in the sidings at night, or are they allowed off site to visit probably the only thing open at Redhill which is a 24hour McD?
JN114
28 Jun 2005
They’re diagrammed to immobilise the set they bring in at 01something; take a break (which should be done at an “official” break point ie the mess room), then mobilise the set and work the first one off Gatwick in the morning. They’re definitely not diagrammed to sleep anywhere; although as long as they can bet gotten hold of what they do on and where they spend their break is generally their business.
It’s way off topic to discuss any further though.
