Derailment in the Bromsgrove area (24/03/2020)
Murray J
10 Aug 2019
East Grinstead
National rail is reporting a "low speed derailment" in the Bromsgrove area, but I can't find anything else on this online. Has anyone else heard of this and heard anything more about it?
Undiscovered
28 Jan 2013
There is an incident on the area. Not sure if it's a derailment, per se, but it will take time to sort out. I have more info, but it's not from a public source, so will not post it here.
The system only has a finite number of generic explainers for things, so they have to go with closest reason.
dk1
2 Oct 2009
East Anglia
Freight loco derailed according to XC. Diversions via Stourbridge.
RichA
17 Mar 2010
66057 has collided with the stop blocks on the Up spur/banker siding. The block have been totally demolished and loco derailed, it was subsequently hit by X/C 170107 on 2105 Cardiff - Birmingham which had its cab door ripped off and damage to all three coaches - no injuries reported.
Murray J
10 Aug 2019
East Grinstead
Ok thanks both of you for your info on this.
High Dyke
1 Jan 2013
Yellabelly Country
Reminds me of an incident at Claypole many years ago, when an errant Cl.31 found the sand drag at the end of the Down loop. I've got a photo of it somewhere.
Darandio
24 Feb 2007
Wow. That could have potentially been a lot worse, hope everyone involved is okay.
kennythelad
25 Apr 2011
Driver of the 170 was obviously very shaken, but no physical injuries. Only a small number of passengers on board, none of whom received any injuries.
O L Leigh
20 Jan 2006
In the cab with the paper
Jeez!! I hope the boys down at Tyseley have enough Tyso Tape for that.
I'd be interested to know about the precise chronology of this incident. I would hope that the driver of the loco got an emergency call out immediately he knew he was off the road. The shunt spur does not have additional clearance to the running line so there was always the risk that the loco would be foul.
PHILIPE
14 Nov 2011
Caerphilly
I think we should await the RAIB Report to avoid any speculating or finger pointing.
JN114
28 Jun 2005
There will only be a report if there’s safety learning to be had.
I’m not privy to the details of this particular incident but seems quite a straightforward buffer stop overrun.
LowLevel
26 Oct 2013
Made complicated by the subsequent collision with a passenger train. I assume they will be doing digging into various things.
Brissle Girl
17 Jul 2018
I’m actually doing neither. I’d just like to know precisely what happened, which I think is not unreasonable.
I actually think it’s very unreasonable to expect the rail industry to release immediately “precisely what happened” including whether the driver of the locomotive “got an emergency call out immediately”, purely so the curiosity of a member of a rail related forum can have that curiosity satisfied.
There’s an appropriate process to follow, and immediate full disclosure of all relevant information to the public won’t be part of a safety investigation. And rightly so.
43066
24 Nov 2019
In fairness, I don’t think anyone has said otherwise. This is a discussion forum where, naturally enough, discussion and speculation is to be expected.
I share @O L Leigh ’s curiosity.
Brissle Girl
17 Jul 2018
Yes, but he was asking for specific detailed information about the driver’s actions, and then followed it up by stating it wasn’t unreasonable to want to know, in a manner that suggested he has a right to know immediately.
philthetube
5 Jan 2016
I think there probably will be a RAIB investigation which will probably focus on why the loco ended up obstructing the running line and what, if anything, should be done to avoid that happening in the future.
O L Leigh
20 Jan 2006
Firstly, I set no expectation on when this information should be shared. I’m happy to wait for the relevant authorities to conduct their investigations and brief out their results.
But, secondly, one of my depot colleagues near enough shat himself inside out after having the cab door ripped off by the blunt end of a Cl66; an outcome that, had the Shed gone a few more inches to the side, could have been so much more serious. Therefore I don’t consider that it’s unreasonable to want to know if something could have been done to have prevented it.
...with respect.
PG
Very relieved to hear that no physical injuries to drivers or passengers. Also thanks for sharing the pictures.
Including, er, the ballast to remove the 66 at some point!
Aye thats way beyond a brown trouser moment and well into I'm not going to survive this territory.
I do hope your colleague can overcome the shock in time.
