Double deck IC trains in Belgium (or Netherlands)
ASharpe
4 Feb 2013
West Yorkshire
On a bit of an interail trip with the wife and we have spotted a few double deck trains.
Are there any particular routes they run on? We would quite like to try one out.
Our itinerary for the next few days is roughly Bruges to Antwerp then Rotterdam on Friday. Rotterdam to Amsterdam Saturday and then to Brussels on Sunday.
Thanks
ASharpe
radamfi
29 Oct 2009
Quakkerillo
23 Jan 2015
From my personal experience, double-deck trains are - generally - expected in Belgium on at least the following routes:
Kortrijk - Brussel - Welkenraedt
Charleroi - Brussel - Antwerpen
Brussel - Luxemburg
Genk - Brussel - Blankenberge/Knokke
They also frequently run the following services, but above is almost >80% double-deck:
Brussel - Antwerp - Essen
Brussel - Namur - Liège
And less frequently on:
Brussel - Turnhout
Antwerpen - Gent - Oostende
Eupen - Brussel - Oostende
Landen - Brussel - De Panne
92002
27 Mar 2014
Clydebank
Brussel - Luxemburg
Brussel - Turnhout
From my personal experience Oostende - Brussel -Eupen are the exception, rather than the rule. Most trains are single deck
Similarly Brussels - Luxembourg are onlt Double Deck in the peaks. These are usually a number of single deck units coupled together
Quakkerillo
23 Jan 2015
About 20-25% runs as a double decker from what I experienced commuting Leuven-Brussels.
This might be a bias by me then, as I frequently use them, but only in peak periods, and I can't remember having not had a double decker! (I live near Brussels-Luxemburg station myself).
ASharpe
4 Feb 2013
West Yorkshire
Thanks all. Not sure if the wife would make a special trip but I can probably work something out from what Quakkerillo posted.
I'll let you know how we get on.
Antwerp was worth a visit for the station itself.
Spoorslag '70
29 Oct 2017
Garching (b. München)
I might be a bit late to the game. Dutch stock can be found in Real-Time via https://www.rijdendetreinen.nl/ or https://www.ovtijden.com/ (or using the NS site itself).
Prinicipal Routes (for VIRMs) in NL: Alkmaar-Amsterdam\Schiphol-Utrecht-[Arnhem-Nijmegen]/[Den Bosch-Eindhoven], the Amsterdam-Den Haag-Rotterdam-Dordrecht Corridor (including ICs to Zwolle and the North) and some services on the "Ijssellijn" (Series 36, Roosendaal-Zwolle). There are some older (modernised) coaches as well: DDZ on various services (e.g. Amsterdam-Enkhuizen), loco-hauled on some peak trains and between Apeldoorn and Enschede. Special formations are automaticly collected on this website https://actutrein.nl/opvallend/live.php (it is indeed the best part of cryptic at first).
Belgish working can be found http://beluxtrains.net/indexen.php?page=searchrollingstock here (planned formations). Double deck stock types are either M5 (bit older) or M6 (newer).
Principal routes in BE are indeed Genk-Coast via Brussel-Gent St. Pieters-Brugge (portion working to Knokk&Blankenberge), "THE SOUTH"-Brussel-Antwerpen(-Essen), Bergen-Brussel-Luchthaven Zaventem and Welkenrath-Kortrijk.
ASharpe
4 Feb 2013
West Yorkshire
We are on one now. First class on the top deck. A bit disappointed there are no plug sockets.
Enjoying the views over the fields and dykes/canals.
There is also a noticeable side to side swaying motion but my beer is mostly staying in place. Far better ride ride than you'd get on a pacer.
Groningen
14 Jan 2015
Sideways motion in a VIRM is often (always) the heaviest where you use the 2 doors to get to the new carriage/wagon. The balcony; the area behind (and between) the outer doors to exit and step in.
MisterT
12 Oct 2014
The Netherlands
Sounds like an older VIRM. The newer VIRM4 and the refurbished VIRMm have some changes addressing the bit too heavy side-to-side swaying motion and they have plug sockets in the first class.
MisterT
12 Oct 2014
The Netherlands
Correct and it should not be used for charging mobile phones (or other things). That plug socket doesn't have a voltage limiter and the power is likely to fluctuate out of range when the train is on the move.
175mph
25 Jan 2016
I've used a double decker IC train when travelling from Luxembourg to Brussels.
317666
4 Sep 2009
East Anglia
German IC double deckers are also known to sway. Must be design in a restricted loading gauge.
I find that very odd seeing as the Regio double deckers are some of the smoothest-riding coaches I've ever been on!
For future reference, this site is a goldmine for Belgian or Luxembourgish train formations: http://www.beluxtrains.net/indexen.php
Edit: Oops, didn't see it had already been posted above!
Groningen
14 Jan 2015
Groningen - Rotterdam (depart 18)/Den Haag (depart 48) has a lot of DDZ now. Before the change of timetable in December 2017 it was mainly VIRM. Maybe because the are now rebuilding the VIRM trains. At ovtijden.com one see each material used with often even the trainnumber(s). At this moment one can look back to November 11, 2013.
