Ealing Broadway Validators
Horizon22
Jobs & Careers
8 Sep 2019
Can confirm they’ve been removed, and the purple readers by the District line stairs are now switched off.
Bit of a silly decision from TfL. I had to go all the way up to the ticket hall with my bag, show them my ticket to exit the barriers and then turn straight back around and tap in.
Yep last time (which started this thread) I had to do the same thing with bemused looks. Didn’t think the validators on District line were pink though - just standard?
MikeWh
15 Jun 2010
Crayford
It's probably a conflation of pink/yellow and gate/validator.
MikeWh
15 Jun 2010
Crayford
District ones were pink.
Not disputing what you say, but Ealing Broadway does not appear on https://tfl.gov.uk/fares/how-to-pay...rd-reader-when-changing-trains#on-this-page-1. I also had a case years ago where someone came from Southall, touched on the yellow validator (his description) at Ealing Broadway, changed to the DLR at Bank and was penalty fared because the DLR TSA didn't realise that the continuation exit at Ealing Broadway meant that the journey wasn't closed.
I would suggest that the advent of contactless means that a lot of the passengers who change there must now already be using PAYG.
Horizon22
Jobs & Careers
8 Sep 2019
Likely true now but of course anyone Didcot Parkway - Reading and changing at Ealing Broadway would have no other option. Whilst the amount of people doing this is likely small, it's probably non-zero as well as those choosing for whatever reason some sort of stand-alone ticket.
Horizon22
Jobs & Careers
8 Sep 2019
I therefore wish I’d taken a photograph yesterday when I visually confirmed the colour of the two on platform 8
You’re right that the bridge over to P7/8 has a pink one (pictured) turned off - no idea how long this one has been turned off though. The one at the lower level next to P7 was definitely yellow.
Acton1991
20 Jan 2019
Reply from TfL below:
This is due to the ongoing works at works at the station. This is a temporary issue however I cannot give any timescale for their replacement. Unfortunately there were no other options when considering locations to facilitate the ongoing site works.
I'm sorry for the inconvenience this is causing and we hope to have the readers back as soon as practically possible.
I can’t see why they’d remove these for station works…
Horizon22
Jobs & Careers
8 Sep 2019
The only reason I can think of is a canopy and/or the works in the old entrance and associated rewiring but that still seems odd.
su31
18 Feb 2015
Romford
Unless it's a disused pink one, brought into Ealing as a replacement and due to be changed to a yellow one as spare parts maybe limited.
Mojo
7 Aug 2005
Possibly, or because there's some kind of mistake. The sticker on the validator is the same wording as what you see on a yellow one.
Horizon22
Jobs & Careers
8 Sep 2019
I have to say it looked rather battered and old.
I’ve got an idea the underlying validator hardware is identical, they have a self adhesive label applied and how they appear to the system ie in/out/continuation/route validator is set up in software. So in theory a simple wrong label would be a quick thing to correct.
Dstock7080
17 Feb 2010
West London
16 Oct 2011
Do you have a source for this?
I'm looking at the map and struggling to think what fares might have a cheaper option if you change at Ealing Broadway. Most local fares via there will assume changing there anyway.
Yes, but that source I can't share on a public forum. Lets just say I spend a lot of time there ;)
Dstock7080
17 Feb 2010
West London
Power back on both on platform 8, but still closed.
matt_world2004
5 Nov 2014
I wonder if the validators are there because it will be quicker to go via Paddington to stations on the Wimbledon branch than going on the district line.. there would be no gateline to pass through to access the district line platforms when crossrail opens ( as you will be able to access them from the bakerloo.entrance to crossrail)
MikeWh
15 Jun 2010
Crayford
The more I think about it, the more I believe this is the case. I think there will be some major changes to default routes for journeys via Ealing Broadway in the March revision.
Dstock7080
17 Feb 2010
West London
Pink validators to be commissioned at Ealing Broadway 12 June.
For Elizabeth <> District and
Central <> District change only.
located on bridge from ticket hall to District platforms and by access to platform 8.
No validators on Central platforms.
Travelentails
20 Jun 2022
Hi all.
I'm one of the schmucks using a paper ticket from Maidenhead to Ealing Broadway then going out and back in the main gates to "tap on" to the central line.
Can anyone confirm if I'm able to start the contactless portion of my journey at Ealing Broadway by tapping in on one of the new pink readers? Or do they not register as the start of a journey?
Tapping out at the main gate on the way back is fine as it's much less of a faff as I go past it anyway. Would be good to know if the minor inconvenience on the way in is done with!
Thanks
Tester
5 Jul 2020
Watford
Hi all.
Thanks
Yes, you can use a pink reader to enter, but not to exit - so the right way round for you!
If you don't know of it https://oysterfares.com/ is a treasure trove of useful information.
MikeWh
15 Jun 2010
Crayford
When you say 'contactless' do you mean using a bank card or device, or do you mean using Oyster. Are you aware that you can use contactless PAYG from Maidenhead and thus not have to touch out and in at Ealing Broadway?
Travelentails
20 Jun 2022
I use my phone loaded with my bank card for the central line portion of my journey.
A peak paper ticket return from Maidenhead to Ealing Broadway with my 16-25 Railcard is currently £12.40, and then the tube to White City (my destination) is £1.70 each way (off peak), making total cost £15.80.
Using contactless all the way from Maidenhead to White City peak is £12.80, and off peak on the way home is £6.60, making total journey cost £19.40.
That's a £3.60 saving per day which adds up. The paper ticket was previously even cheaper, making even more savings.
Sometimes if I'm in a rush I do tap all the way, but when they removed the yellow reader on the central line platform it did somewhat feel like they were trying to force me into going fully contactless, which is ultimately a slightly more expensive journey.
Thanks for taking the time to reply.
That's great news, will save me a bit of time each day. Thanks for your response, will check out the link you provided.
Either way I won't be using the reader tomorrow that's for sure!
Mojo
7 Aug 2005
If you have a Railcard then why do you use Contactless payment rather than an Oyster card with Railcard discount added?
rebmcr
15 Nov 2011
St Neots
I believe* if you use an Oyster rather than Apple Pay/Google Pay for the contactless portion, you can have your railcard loaded on to it, saving you even more.
* it has been some time since I was a 16-25 cardholder
