Government ownedEither the newly set up East West Rail Company (Privately owned, Government backed)
Looks like the Alesbury line north of quainton has now been lifted up to the EWR line
Picture from Quainton via Phil Marsh tweet site - Quainton
AIUI the track bed north of Quainton Rd has to be reinstated on a new alignment to serve the resited Calvert waste terminal, irrespective of whether or not there’s an EWR passenger service?Is this mainly to facilitate HS2 construction further north rather than an early move to relaying Aylesbury Parkway to Calvert for EWR ? . Is that part of EWR still "paused " ? - so I guess the GC trackbed north of Quainton will be left without rails for the foreseeable future.
It's probably also useful to have an extra route to feed the HS2 construction railhead, later to become an infrastructure maintenance base.AIUI the track bed north of Quainton Rd has to be reinstated on a new alignment to serve the resited Calvert waste terminal, irrespective of whether or not there’s an EWR passenger service?
I expect just left of centre must be where the new footbridge extension will be connected. It looks quite a distance for a single span.E-W platforms at Bletchley coming on nicely
Agreed - not shown just below the frame is what I assume is the massive foundation for the new bridge span. It is a huge concrete blockI expect just left of centre must be where the new footbridge extension will be connected. It looks quite a distance for a single span.
Basically right next to the HS2 alignment. The HS2 route maps will likely show it.I am trying to find a plan which shows where the route reinstatement of the GC track north of Quainton Road station will be.
The gov.uk plans for Greatmoor (link a few posts above) appear to show Quainton Road as a terminal station!
Anyone advise please.
Much appreciated
Much appreciated
I expect the HS2 map doesn’t show anything immediately north of Quainton Rd because it doesn’t change the route position at all until the bridleway bridge GUN/28 way over on the left.…I guess there is more in the HS2 Plans, but all I can find is this which seems to lack detail.
Many thanks for responses ChapsI am trying to find a plan which shows where the route reinstatement of the GC track north of Quainton Road station will be.
Much appreciated
What about provision for the planned, but now postponed, link from Aylesbury to EWR and on to Milton Keynes?I expect the HS2 map doesn’t show anything immediately north of Quainton Rd because it doesn’t change the route position at all until the bridleway bridge GUN/28 way over on the left.
If we’re still discussing maps then it’s shown on the next HS2 map in sequence to the north. But it’s re-routed slightly to the east of the original curve to allow for the link between HS2 and their Calvert infrastructure depot. The drawing is in Post #317 showing the changes.What about provision for the planned, but now postponed, link from Aylesbury to EWR and on to Milton Keynes?
I think it’s temporary stage works, and they’ll build another new embankment over the site of the existing road south of the new bridge. That part of the existing road couldn’t be diverted west, because there are buildings in the way.I'm confused - why the rather vicious kink in the road immediately one side of the Bicester road bridge? There seems space for it to have been a straight approach and its a busy A-Road isnt it??
Also are the abutments passive for dual carriageway - they look longer than they need to be?
Did they keep the road open during construction then? It isnt open in the video.I think it’s temporary stage works, and they’ll build a new embankment on the site of the existing road south of the new bridge. That part of the existing road couldn’t be diverted west, because there are buildings in the way.
Yes it was open until a month or two back. (17th Oct it turns out.) On the north side of the railway they had built a temporary road almost all the way to the roundabout. It came with full pavement, kerbs and street lighting, now removed.Did they keep the road open during construction then? It isnt open in the video.
Also the kinked bit of road seems to have tarmac lines and lampposts??
Please note that when Charbridge Lane reopens, the traffic flow will be switched onto the new bridge structure from the north with a temporary alignment still to the south and work will begin to complete road approach from the south in order to put the road into its final alignment.
Is it because they have to allow a significant time for a raised embankment like this to settle, before adding the road base, and they build the level up in phases? They also probably have to remove the existing road and foundations to do it properly? Not really something they can speed up.Correct. The aim is to reopen the road at the end of next week with the temporary alignment to the south of the line
Charbridge Lane Road Closure - Launton Parish Council
Charbridge Lane will be closed from 17 October to 17 December between the Launton roundabout and Gavray Drive for EWR works. However, access will be maintained at the southern end from the Rodney House roundabout to the Langford Village entrances and to the businesses / frontages beyond Gavray...www.launton-pc.gov.uk
“By 2025”, according to the EWR company website. I posted a link a few months back, but it’s easier to repeat it:What’s the current estimated opening date for the Oxford to Bletchley section?
Thanks for the link.“By 2025”, according to the EWR company website. I posted a link a few months back, but it’s easier to repeat it:
Connection Stages | East West Rail
East West Rail is a major infrastructure project to connect communities between Oxford and Cambridge. Services will be introduced in three stages; from Oxford to Milton Keynes, Oxford to Bedford and Oxford to Cambridge.eastwestrail.co.uk
That’s what I thought back when I found it. I suggested here that it was relatively unambitious, but others disagreed…Thanks for the link.
Considering the progress with the bridges along this stretch, I’m surprised it will take a further 3 years.
