Dr A.Johnston
- Joined
- 6 May 2016
- Messages
- 48
Yes. Rail first, then the Balfour Beatty New Track Construction machine adds the sleepers. Then ballast is dropped. It’s how it has been usually working on this project, there's a video in post #549 of how it lays the sleepers, and various photos of it and other trains on ballast-less track a few posts back around that point.Did they initially lay sleepers and rail directly on to the Terram?
Then Tip Stone and Tamp, lifting the track in front of the Tamper or did the Tamper manage to lift enough to avoid puncturing the Fabric?
An interesting video showing several of the same views I saw on the 15th. The shots of a ballast train in action dropping ballast on the outskirts of Bletchley (where both tracks are already laid) are particularly interesting.New video from NWP Exploring on YouTube - Progress on EWR
Ok sorry, yes I see on a reread that’s really your main question. It does seem risky for the Terram as you say. What sort of depth is the Terram supposed to be on completion of the final alignment?I understand about the NTC, I worked with it once a number of years back.
My point is that when the track is laid directly onto the Terram, how is the track lifted through the ballast without puncturing the Fabric?
Is it first Tamper pass with a big lift?
Yeah i was a bit surprised to read the above and look back at the pictures to see the sleepers laid direct onto the terram. Also the front of the NTC is supported on steel tracks which could also chew up the terram but clearly the client track team are comfortable with the approach.I understand about the NTC, I worked with it once a number of years back.
It helps stop weeds growing into the ballast and stops the ballast mixing with the soil. The permeability allows water to drain but stops the solid particles moving through. If it were torn by the tamper, you'd have long gashes where the sub ballast could mix into the ground, and over time this would lead to insufficient support and drainage for the track, giving low spots, wet beds, etc.Can anyone tell me what is the function of the Terram in this instance,please? I see there are lots of different sorts of Terram geotextiles used as trackbed separators at https://terram.com/products/ , but I can't tell what sort is being used here.
What would happen to the track over time if Terram was not used? And given that the fabric is supposed to be permeable, why does it matter if it gets punctured by ballast?
Thank you for that explanation. The great thing about these forums is that there is always someone who knows the answer!It helps stop weeds growing into the ballast and stops the ballast mixing with the soil. The permeability allows water to drain but stops the solid particles moving through. If it were torn by the tamper, you'd have long gashes where the sub ballast could mix into the ground, and over time this would lead to insufficient support and drainage for the track, giving low spots, wet beds, etc.
I may be wrong, I am familiar with the reasons but don't have any close involvement so there may be other factors. It's a combination of informed guesses, Heritage railway project updates and the fact that terram is very similar to the membranes Gardeners use.Thank you for that explanation. The great thing about these forums is that there is always someone who knows the answer!
I would surmise on first pass the tamper operator would put on maximum lift (150mm) so the tines are well clear of the Terram product and get a base of ballast under the sleepers then on 2nd pass can fine tune lift and alignment.It helps stop weeds growing into the ballast and stops the ballast mixing with the soil. The permeability allows water to drain but stops the solid particles moving through. If it were torn by the tamper, you'd have long gashes where the sub ballast could mix into the ground, and over time this would lead to insufficient support and drainage for the track, giving low spots, wet beds, etc.
It won’t, but Bletchley is only a quick hop on a frequent local service from MKC.Long may it continue!
This line will provide interchange between multiple main lines.
Once it’s all up and running I hope Bletchley becomes a regular stop on the longer distance WCML services to ensure a decent interchange between that line and the MML and later the ECML if the project gets that far!
Yes, very close, AIUI the maximum length LWR strings that the delivery train can handle is 216m, which is two of the maximum length that the steelworks produce welded together.What is the standard length of a rail ? 235yd / 215m just guessing.
You can see a number of rail ends overlapping by a metre or so.
Oxford has a direct connection to MKC. Cambridge does not. Only folk from the East need to change at Bletchley. If folk from Oxford catch the Bedford train they will also need to change, but a direct train will run to MKC as well.It won’t, but Bletchley is only a quick hop on a frequent local service from MKC.
Have they figured out the paths for MKC? I know it is touted as 2tph MKC and 2tph Bedford at launch, all to Oxford - but I understood it wasn’t actually calculated how.Oxford has a direct connection to MKC. Cambridge does not. Only folk from the East need to change at Bletchley. If folk from Oxford catch the Bedford train they will also need to change, but a direct train will run to MKC as well.
Expecting some shorter turns - the Southern to Watford we know - but maybe another service at Bletchley itself.
They exist.2 MKC and one Bedford, no?
I would be surprised if the paths hadn't been taken into account in the December recast.
They wont - but E-W passengers will have a direct link to MK where the transfer will happen. Passengers from Bedford will have to change at Bletchley & MKOnce it’s all up and running I hope Bletchley becomes a regular stop on the longer distance WCML services to ensure a decent interchange between that line and the MML and later the ECML if the project gets that far!
It still seems nuts that the N-E chord at Bletchley isn't being built - why you would force a change to the major local travel generator is unclear to me.They wont - but E-W passengers will have a direct link to MK where the transfer will happen. Passengers from Bedford will have to change at Bletchley & MK
argh - Kenny, Get me a Zantac!!!!!!!!!!!!It still seems nuts that the N-E chord at Bletchley isn't being built - why you would force a change to the major local travel generator is unclear to me.
I know they wont but it would be nice if the Marston Vale train could run into the high level platforms rather than P6.
LNWR wont use P5 at peak time ( for MV services) as it blocks access to the carriage sidings and p6 should have a lift now!I don't think the Dec 2022 timetable has any Bletchley terminators, and so 6 should be able to be put pretty much out of use and 5 used instead?
If 6 has any future they really should install a lift.
I get that. But nonetheless....argh - Kenny, Get me a Zantac!!!!!!!!!!!!
This thread was purposely broken out of the original more general thread to concentrate on construction news. I think lack of specific curves is not really a construction issue?I get that. But nonetheless....
