ECML problem at Bawtry 9/11/21
johnnychips
19 Nov 2011
Sheffield
At Doncaster all services towards Leeds, London and York are delayed. The announcer said that all trains were sat near Bawtry as there was a problem with the electric supply. Passengers advised to take 1835 stopper to Sheffield and change there for York, Leeds and St Pancras.
I think a lot of people have not taken advice as this train is fuller than usual but not rammed.
DanNCL
17 Jul 2017
County Durham
The situation hasn't been helped by the Royal Train being part of the southbound queue of traffic, no doubt requiring some careful regulation of passenger service to allow the Royal Train to divert unhindered via the Joint Line.
Stathern Jc
30 Nov 2019
Inverness
This is listed on the LNER Travel Alert page on their website.
Part of the advice is for Grand Central ticket holders who have two options to travel from Sheffield to St Pancras, at 1837 and 1900. I suspect that 1835 from Doncaster might be a bit tight!
55002
16 Aug 2019
Ldn
Some southbound trains been allowed past now very slowly..nothing going north still. Passenger on 1400 KGX ABD tweeted announce they need evacuating due to “extreme” damage
800001
24 Oct 2015
1W20 will evacuate on to a Hull Trains unit, and 1w20 will sit till there till.end of service. Substantial damage apparently with wires down on to roof of train.
Hull Trains unit was culprit train, now sat in Doncaster West Yard with damaged pantograph.
Bayum
21 Mar 2008
Any suggestion as to what has happened to the pantograph leading it to be described as 'extreme damage'?
Buffer_mutt
7 Apr 2021
Peterborough
Kind of unrelated. But I'm 90% sure I just saw a HT 800 pass PBO going north on 5Z90 running on it's diesels. First time I've seen a 800 at speed running on those, they sound nice.
Danor97
24 Jan 2015
802302 looked to have a pretty mangled pan when it arrived in Doncaster. Was subsequently shunted to the West Yard for further inspection from the bridge of some sort.
Nicholas Lewis
9 Aug 2019
The BiMode units could divert via Lincoln but no doubt drivers don't sign the route as LNER don't ensure route knowledge is maintained.
Banham7
12 Aug 2020
Lincolnshire
Seen a couple of GC and HT divert from Peterborough through Lincoln onward to Donny. LNER seems to be branching the 800s off at Newark, sending them via Gainsborough LR and then onward to Donny.
Danor97
24 Jan 2015
How big are the sections to isolate when something like this occurs? Always puzzling how it works.
TheBigD
19 Nov 2008
Assuming the 10 x 9 carand 8 x 5 car* bimode units are in the right place...
As for route knowledge, LNER are one of the better TOCS. Cambridge, Joint Line, Hambleton, Knottingley, Durham Coast, Carlisle amongst the routes that staff sign. Obviously not every depot signs every route.
* 10 from 13, and 8 from 10 are diagrammed daily.
Nicholas Lewis
9 Aug 2019
Four in the queue at Retford at the moment suggest not sufficient drivers do sign it.
43096
23 Nov 2015
Of those, only one (1W24) is formed of an 800 that could go via the Joint Line. That suggests you're just jumping to incorrect conclusions?
Bristol
801s don't have gensets capable of providing traction power (not sure if they have a limp-to-safety capacity).
Interesting, never realised the sections are so big.
It's also about how the section can be managed - it's presumably easier for the person authorising trains over the single line to meet each train at Retford where it's lit and there's a platform than by some signal at the lineside.
Crossover
4 Jun 2009
I think they do, but generally can't be used for traction without authorisation from Hitachi
DanNCL
17 Jul 2017
County Durham
801 gensets can provide traction power to some extent. They can (slowly) get up to around 50mph on diesel, which is used in a limp to safety capacity as well as during some OHLE isolations, Depot shunts and for moves to/from Newton Aycliffe on the unelectrified line from Darlington.
5 car 801s don’t provide traction power when working in multiple with an 800 that’s on diesel, so might be where you’ve got confused.
Bristol
Thanks for the clarification. I had slightly underestimated their capacity, and should probably have been clearer and said 'service traction power'.
