European Class 66's to UK
valentaman
6 Sep 2008
oakham
There will be quite a bit of work to do at Longport before it goes elsewhere, particularly fitting U.K. spec kit (headlights, AWS/TPWS, etc).
I’ve not seen anything giving the previous number of 66797 yet - anyone with that gen, it would be much appreciated by many, I suspect.
PB 513-09 266 036 latterly with HSL working between Germany and Holland
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
That's true, I had wondered if it had received any work while abroad to reduce the load on Longport but possibly not.
Anyway, Here is it's original identity: PB 513-09 / 266 036 - Vintage 2004 and of the same age as 66743-746.
themiller
4 Dec 2011
Cumbria, UK
Do the 66s have builder’s plates like European built locos and if so where are they fitted? Thanks in advance if anyone can answer.
Bob figgis
11 Apr 2020
Tinsley TMD
Does anybody know why the movement of this loco ran as a class 6 freight and not as a class 0 for a light engine movement?
ExRes
16 Dec 2012
Back in Sussex
My guess would be that it's because 797 has not yet been converted for use in the UK, it's therefore a load rather than a loco, I could be completely wrong of course .....
fgwrich
15 Apr 2009
Interestingly, from further reading on the Mainline Diesels website, it looks like this batch may be fitted with ECTS already - I wonder if this will be suitable for UK use and therefore the first in their class?
soccermad
2 Mar 2008
Derbyshire
I have details of 66795 and 66796 will post them in a bit
Coming over in the next few weeks
These two locos are 561-05 and 561-03
ExRes
16 Dec 2012
Back in Sussex
These two locos are 561-03 and 561-05
Reported on WNXX (subscription section) today that 561-05 is due at Immingham tomorrow, 561-05 will become 66795 and is currently operating in G&W orange livery
fgwrich
15 Apr 2009
Indeed it is;
Has to be an unusual case where the loco is owned by Beacon, operating in Europe in a rivals livery, about to come over here to work for another rival (as in GBRF).
ExRes
16 Dec 2012
Back in Sussex
Hidden by the coverage of 69001, another movement from Longport yesterday was 66794 being hauled to Doncaster Roberts Road
squizzler
4 Jan 2017
Jersey, Channel Islands
What is the demand pattern driving the repatriation of these locos? I understand goods traffic is flowing more freely than before due to fewer passenger services, this would suggest the same number of locos could do more than previously. In conjugation with the new class 69, does this indicate a step change in goods traffic on the railway after brexit?
palmersears
20 Sep 2011
GBRf clearly feel there is the potential business available to warrant an expanison of their fleet. I would imagine HS2 construction will generate a good deal of new opportunities for all the FOCs, having locos ready to go to meet the new demand will be an advantage I imagine.
Locma51
16 Feb 2021
South Glos
EMD 66's have their build number stamped into the frame on the lower edge of the body under the cab, at one end and either side.
After several coats for paint you need to get quite 'close and personnel' to read some of them!
The number is an eight digit batch number followed by 01, 02 etc, which is where the abbreviated number [eg. 513-09 =66797] comes from.
Full info for each loco can be found on MainlinDiesels.net web data. Some of the European 66's have had several owners and many operators with conflicting running numbers,
so build no. and UIC are the best way to id certain locos
43096
23 Nov 2015
Technically those coming over for GBRf are not being repatriated, as they haven’t been here before.
themiller
4 Dec 2011
Cumbria, UK
Thanks for that, Locma51. I’ve asked drivers and maintainers in the past without receiving a definitive answer.
Class 170101
1 Mar 2014
I guess the Europeans have no use for them or do they just build bigger locomotives?
GB
16 Nov 2008
Somewhere
It could be as simple as just taking work/contracts off another operator. More locos doesn't necessarily mean more new to rail work.
TRAX
2 Dec 2015
France
Mainland Europe renews its locomotive fleet much more often than the UK. At the moment there is quite the influx of EuroDuals for example.
