Ex LNER (and Grand Central) Mark 4 sets for TfW
47827
3 Mar 2020
Middleport
Re: 14 minute turnaround at Holyhead. My hunch (only from past goings on as I'm several years out of touch with some of these railway operations) I would expect everything to run as planned for any delays of below about 30 mins and simply cause a knock on delay to the return, provided the paths in each direction did not cause complete carnage to everything else on the route. Delays over 30 mins by Chester on the way up may result in either running through to Holyhead and return with stops removed (if that served any purpose) or terminating at Bangor/Llandudno Junction if a good part of the delay couldn't be recovered by doing that. The issue is then the relief crew being Holyhead based so they would need a taxi or similarly timed rail departure to reach the curtailed start point. You could, of course, just go all old fashioned and let the set return with a hefty delay, but I would imagine that wouldn't be favourable generally if over 30 mins.
And with the crews, Chester set up a link similar to this for class 47s in 2002 with a good handful of mostly ex BR drivers only needing refreshers or a short course. With many no doubt retired or moved elsewhere and the fact a class 67 (especially with mk4 push pull sets and DVT included) requires much more training than back in the 2000s for the other example. Llandudno Junction has gone much longer without locomotive experience at the driving end although their smaller size and cross cover potential for Holyhead turns would be of use if the project ever went above 2 operating diagrams. Whilst guard competency isn't unimportant, especially on mk4 sets, it would not be quite as big an ordeal as the driver training aspect so more staff could be covered should the need ever arise. As posted last year junction guards were trained on mk3s so it may be slightly easier to retrain them than Chester who've had no loco hauled trained guards since maybe 15/16 years ago (and that was only on mk2s) at a much larger depot with the usual staff turnover and retirements. Crewe used to have many of its guards trained due to the former ruggex and footex trains, which had been lost by the time mk3s came on stream, especially as no hiring in of third party stock took place post mk2 days. But again mk4 sets are effectively a new challenge. Good job it probably won't go beyond 2 diagrams save for the likelihood of the third set occasionally covering events days on Marches additionals perhaps.
craigybagel
25 Oct 2012
Either link at chester is 40+ drivers.
It would unlock a mountain of routes, liverpool to birmingham via chester - Man airport etc. You could have rakes going cardiff-liverpool.
It makes operational sense to have Chester men do the units. But cost wise its never going to happen.
No, probably not. If they did extend the driver knowledge they'd give it to Junction first like with the guards, which wouldn't give them any more routes but would be a lot smaller group to train.
Training from scratch for drivers on 67/DVT is currently a 3 week course, which would go a long way to explaining the limited amounts who sign it. It's still only one link of 2 at Crewe, and 1 link of about 5 at Cardiff Mainline.
3 Mar 2020
Middleport
Yes thought it was in the weeks rather than days. And to be honest, it takes a while to get used them for the crew even after a 3 week course. More difficult with such a small number of the services ever booked for 67s and worse still when units have subbed on a few those days. Even at somewhere like Holyhead some drivers would be lucky to get an odd shift a month. Some of those would be DVT driving and others in the loco which aggravates things even more. At least 15 to 20 years ago there wasn't 2 cab environments on the same set as you still had to do run rounds.
sw1ller
4 Jan 2013
Just to put in perspective of how long training can take at Chester. Manchester airport training for an experienced driver is two days plus a day to pass out/sign off. I’ve been waiting since early October to get on it and still not getting anywhere.
giving one link (probably red to take advantage of the Stafford diversion*) at Chester a 3 week course would take forever. And given the new trains coming in service soon (230’s and 197’s) would simply be unworkable, even with covid relaxed.
*im personally ruling out loco hauled trains going to Manchester airport, but could see them going to Birmingham in the future.
craigybagel
25 Oct 2012
Funnily enough, in recent years Holyhead was the easy one in that regard. With the introduction of an all day North Wales coast loco hauled diagram, worked exclusively by Holyhead drivers (with the exception of the Crewe - Chester and Chester - Crewe legs at the beginning and end of the day that Crewe worked, to bring the sets on and off the depot), I think they had at least 4 jobs per day involving loco at some point, which in a small depot like Holyhead meant they were spending a lot of time at both ends of it. Crewe had 3 jobs in a link of 30 (2 of which were the ATC - Crewe - Chester runs mentioned above so only about half an hour driving) and initially of Cardiff's two jobs in their loco link, one of them was only driving from Cardiff Central to Canton, shunting as required, and then back to Cardiff Central again. In the end they had to take over the Newport - Cardiff leg of the morning WAG service from Crewe just so they had the chance to drive the DVT at more then 20mph.
47827
3 Mar 2020
Middleport
Not surprised RE the other depots. In the late 90s and early 2000s at some points there was even less runs on the Marches than that as loco knowledge at some depots was down to Rugby and sports event days at CF. So traction was on cards but the risk of failure greatly heightened as there may be as few as 10 opportunities over a full year to use it for some staff.
With Holyhead when the Manchester turn was running I'm sure some staff were on it by the minutes too but believe there were ones swapping onto it and others off it too (or trying to). If just the WAG set it was somewhat harder with presumably just 2 live turns and a depot turn to keep knowledge. The other depots, as you say, have stayed stuck in that position given their limited or non involvement with the Manchester set when it ran. 3 services each way all the way from Cardiff to Holyhead across the day should mean all of those currently lined up should get more runs except Holyhead who will get a similar amount presumably if they do everything past Chester. Presume seasonal weekend work and sports days too.
Rhydgaled
25 Nov 2010
I certainly hope they don't acquire more MK4 stock, scandalous waste of money for a regional service. I wonder how many actually use the North Wales service from the South, the Cardiff-Manchester route strikes me as being far more important and that's the route they should be used on if any but of course that's not in Wales. It always struck me that Manchester Cardiff should be XC although not with the current company that run it.
I defer to craigybagel's knowledge of crew depots regarding where any additional sets are likely to be used. On that basis I too hope that TfW don't acquire any more mark 4 stock, unless TfW are willing to undertake the required additional training to allow more widespread deployment. In that case I hope for two diagrams on Holyhead-Cardiff expresses (as currently planned) plus a number doing Manchester - Swansea with connecting DMUs to Carmarthen and points west.
craigybagel
25 Oct 2012
I think it's hard to say exactly where they should go at present without seeing the full timetable plans for the network, including stopping patterns.
In an ideal world, the Manchester - South Wales service would only run as far Swansea, and would be limited stop (Manchester - Stockport - Wilmslow - Crewe - Shrewsbury - Hereford - Newport - Cardiff, and then usual main stops to Swansea). For such a service, the MKIVs would be ideal.
The problem is, that service pattern would cause uproar. Nantwich and Whitchurch would demand their direct Manchester services are retained, as would the smaller Marches line stations (even though with the exception of Ludlow, most have few or none at all passengers for North of a Crewe boarding most services). The folks West of Swansea would equally be complaining about losing their direct service to Cardiff (assuming there are neither the paths nor rolling stock for a separate West Wales - Cardiff service).
If you start to include those stops as well, then the use of MKIVs becomes problematic. The full 67 + 4 + DVT rake won't fit at several of the platforms involved, the dwell times would be too slow, and whilst a 67 and a short formation of stock will outperform any of the current DMUs in the TfW fleet above a certain speed, their acceleration from a stop to that speed isn't as good. They're really not suited to the kind of semi fast work that the current Manchester - South Wales service is.
If the plan is for the Manchester services to be sped up, with the new Liverpool - Cardiff services picking up the majority of their marches calls, and maybe the Crewe - Shrewsbury local service being doubled to hourly to pick up the calls there, then maybe it would work. But if, as I suspect, it's the same as now, then they might as well keep them on the Holyhead. I suspect it'll be the Holyhead services that stop less anyway.
Rhydgaled
25 Nov 2010
Yes, that's pretty close to my thinking. I would have put Ludlow and Leominster in there too, because there's no other practical way to give them a better than hourly service, but other than that I agree 100% assuming that by the usual stops between Cardiff and Swansea you mean Bridgend, Port Talbot Parkway and Neath.
I'm west of Swansea. Each Four/Five coach mark 4 sets on Manchester-Swansea would free up two units each (given that it's going to be lengthened), so there should be stock to put on a seperate West Wales - Cardiff service which if it was a fast service which avoided Swansea would be a big improvement on what we in Pembrokeshire have now. Pathing might be more of an issue. Nantwich and Whitcurch are more of a problem; I'd give them an hourly shuttle using a 197 but that doesn't help with the through Manchester services. Maybe if the HS2 rebuild puts platforms on the freight lines at Crewe (which have an underpass) Northern could run a Manchester-Shrewsbury stopper?
I agree, you don't want LHCS with poor acceleration from a stop if you have too many stops which is why I think they would be a better fit on Manchester-Swansea (which as noted above I feel should be speeded up where possible) than Holyhead-Cardiff (which from other comments on here I get the impression doesn't have sufficient end-to-end demand for more than three fast runs each way per day).
craigybagel
25 Oct 2012
Problem is, you have to draw the line somewhere. Add in those two, you might as well add in Abergavenny, and soon you're back as more of a semi fast. Plus they won't fit on either platform at Leominster anyway
Stock maybe, but paths (even allowing for going via the Swansea District)? And more importantly, crews and the money to pay for them?
There is certainly much talk of platforms going on the Independent lines so as to remove the need to cross the WCML on the flat. A Manchester - Shrewsbury stopper would still struggle however to find a path, unless it was an extension of an existing Crewe terminating service in which case it would need to be bi mode. Again, expensive....
True, but politically speeding up Holyhead - Cardiff services looks better.
Again we come back to the same problem - TfW is by its very nature a compromise franchise, and there just isn't the money or capacity to find a solution that keeps everyone happy. It's difficult to see the MKIVs changing this issue. I'd be very happy if they go ahead and procure them as an enthusiast, but as an employee it's difficult to see the problem they'd solve.
47827
3 Mar 2020
Middleport
The ONLY possible reasons for wanting say 4 diagrams instead of 2 would be to either release units (can't see it with all the new builds due and falls in passenger numbers) or, more plausible, if the WAG wanted more intercity quality stock with catering and first class. I'm not aware of any of the new trains conveying cooking facilities.
Realise its likely to be just 2 diagrams from 3 sets but if not it wouldn't be shortage of trains as the logic.
22 Jun 2013
Does anyone know when the Premier service is due to resume? Tweeted TfW and got no useful info. Thanks
berneyarms
26 Nov 2013
Dublin
Looking at Real Time Trains, the through Cardiff-Holyhead services may return on 13 September. Of course that may change!
Whether the full onboard service returns then is anyone's guess.
HamworthyGoods
15 Jan 2019
Because the point at which you can share a table with a stranger and eat a meal together isn’t even on the road maps of re-opening bearing in mind it’s an airborne disease.
Social distance dining would mean you could only serve about half a dozen - hardly worthwhile
PHILIPE
14 Nov 2011
Caerphilly
That is just the base Timetable that has been carried forward. I don't think we can answer many queries at the moment as most dates are dependant on the state of COVID
berneyarms
26 Nov 2013
Dublin
I get that - hence the comment that things may change either before or after that.
craigybagel
25 Oct 2012
It's not been decided yet officially. Training is still taking place and it will probably be a while yet before that's complete.
The journey is about 4 hours, isn't it? Plenty of time for multiple sittings.
Andy Pacer
11 Jul 2017
Leicestershire
True, but I suspect the vast majority of those travelling who want to avail of the cooked food are boarding in Cardiff and Newport.
In my experiences that was the case. In fact I was wondering about the practical availability of the full service for passengers boarding further north.
43096
23 Nov 2015
A very reliable source tells me that TfW have acquired an additional four Mark 4 sets.
So that's just in time for the end of the staycation season then?
It's a poor show if at least a couple of through trains don't run in the summer (not Mk4s, obviously).
Cardiff123
10 Mar 2013
What I can't understand is that these sets will only have 2 standard class carraiges per set. Hardly a capacity upgrade for standard class passengers over a 3 car 175.
One and a half first class carriages seems overkill compared to just two standard.
Doveymain158
9 Apr 2014
The Catering vehicle on a MK4 is standard class.
43096
23 Nov 2015
The ex GC sets?
I believe so...
...If what I'm told is correct they are acquiring vehicles to lengthen the three existing sets as well, so will be formed TOE-TO-TOD-SV-FOD-DVT.
Presumably that means that DB Cargo will be providing some more 67s on top of the 6 already modified.
Cardiff123
10 Mar 2013
I believe so...
Well that is encouraging to hear. But for a non-industry person, can you explain those abbreviations? Thanks
