Express Points
Sad Sprinter
5 Jun 2017
Way on down South London town
Does anyone else find Hornby's express points a pain to use? They really complicate the track geometry and require a lot of tiny straight sections to line the tracks back up again. Perhaps I'm not using them correctly?
BRblue33
12 Dec 2020
End of the southdowns
I never use Hornby track . Peco flexy track and points i use. Then you have a choice of code 100 or code 75 plus Concrete sleepers. Even bullhead track.
Cowley
15 Apr 2016
Devon
Same here (except code 55 N gauge).
Gentle radius points make big difference to how a railway looks but I’ve never designed a railway using set track so it’s all cut to measure for me.
Peter C
13 Oct 2018
GWR land
I've got two pairs of Hornby express points on my layout. I installed them sometime last year to improve running over one particular junction on one side of the layout and then on the other side to keep the geometry and spacing between the tracks. They're designed to be the width of 1.5 R600 pieces; this means to make up the length of an express point, you need 1xR600 and then 2xR610 (IIRC). To line the tracks up when building off of the 'normal' points setting, you need two of the R610 pieces (quarter-straights, where four don't make one R600-length piece).
-Peter
deltic14
13 Oct 2019
Ossett
I had to remove my Hornby express points because they broke (tie bar failure) after a very short time. In my opinion Peco points are much more robust but you do have to cut flexi track to appropriate lengths to maintain distance between running lines if you use the medium radius points which are the nearest thing to Hornby express points.
