GWR Class 769 information. (Units no longer with GWR - Off Lease March 23)
JN114
28 Jun 2005
Even if the 12 hadn’t gone to HEx, there wouldn’t nearly have been enough 387s - there’s nineteen 769s coming to GWR. With the 12 sets now on Heathrow duties it’s a total non-starter with the current fleet of 33 classic 387s. Perhaps if 101-129 and 301-306 were available for import from their current operators there would be enough to do the whole combined fleet of 80 (including HEx), put a little more resilience in the HEx fleet (10/12 units is tough on both operations and engineering departments, 10/14 like we had with 332s would be more comfortable), cater for wiring of Oxford/Banbury/Branches and see GWR-LTV move to an all-387 operation. But even then it would still rely on the technology being capable enough. The same struggles that the 769s are likely to have - IE generating/providing enough electrical power away from 3rd rail / OHLE to get the units over the hills of the North Downs - are going to be just as likely to occur with a battery 387 if the forays into battery tech so far are anything to go by.
DelW
15 Jan 2015
Planned for 769930 but that was having issues last night on prep. Likelihood is that 946 won’t be available either.
Third unit still isn’t available.
10:33 confirmed by a colleague- all 3 are out of action!
Considering that it seems they've barely turned a wheel in earnest since delivery, that's not very encouraging!
Mollman
21 Sep 2016
Seem to be following the same pattern as the Welsh ones, eventually reliability will pick up.
spark001uk
20 Aug 2010
I'm guessing initial testing is confined to the mainline (centred on the TCD for rescue support) until they confirm reliable enough to have a go on the NDL? (A breakdown there would cause much more of a problem)
Much better to have them on a four track route during the initial phase where they can run on both OHLE and Diesel, then on third rail, before they go anywhere near the North Downs Line. It is still very early days in the testing programme.
Don't also forget that it has been suggested in this thread that the North Downs Line in unlikely to be where they are first used in passenger service (although there are only six potential diagrams before that happens).
spark001uk
20 Aug 2010
That must be a change to their initial plan then, as the timing load on there was changed to diesel loco 769 tonnes quite some time ago, last year I believe?
Edit; (I remember speaking of this recently, it appears it may just have been done to avoid the need for significant timetable changes down the line, now I recall it)
By 'first used', I think I was suggesting that when introducing a fleet of 19 units, it might not be until unit 4 or 5 is introduced that they make their way into passenger service on the North Downs. Not a huge delay, but not the first place.
That is certainly what I took from this discussion between you and 'JN114' up thread.
https://www.railforums.co.uk/thread...mation-discussion.174866/page-23#post-5063716
DelW
15 Jan 2015
Is there anywhere they can run on third rail, other than over sections of the North Downs? (I'm assuming that the term North Downs Line covers the whole of the ex- SER route between Reading and Redhill, not just the section east of Guildford which actually runs over the Downs). Maybe they'll just shuttle between Reading and Wokingham, unless the drivers have route knowledge to continue in the Bracknell direction?
It has been indicated that for third rail purposes they will be tested between Basingstoke and Woking or Eastleigh. This, from August.
However, this relates to fault-free running (involving Colas drivers) rather than driver training for GWR staff which will presumably have to be on routes they actually sign. GWR guards need training as well.
Maidenhead to Didcot/Swindon is the route on which the diesel/AC FFR (Fault Free Running) is likely to take place with the DC FFR on the SWML with either Basingstoke-Eastleigh or Basingstoke-Woking being the sections discussed with NR.
All lines on which passenger use is contemplated will have full test runs for station validation purposes. But first there has to be engineering staff training before anything moves off depot, either for testing, validation runs or driver training.
DelW
15 Jan 2015
Thanks for the info, I possibly saw that at the time but if so I'd forgotten it. It's difficult to keep up with what's actually being proposed.
If we're allowed to travel when they get onto diesel running east of Guildford, I'll be aiming to find a viewing spot and see how get on with the climbs.
Anyone know when the first unit is expected into service?.
Will the full 769 timetable be in place for December 2021.
Many thanks
Previous discussion has indicated Autumn this year.
Full introduction by December 2021 seems very optimistic. The introduction schedules quoted have always been around 8-10 months long - eg February 2019 to December 2019 in the initial plans and September 2020 to May 2021 in the Direct Award.
https://www.railforums.co.uk/thread...ally-for-northern.138660/page-49#post-3398153
https://www.railforums.co.uk/thread...mation-discussion.174866/page-15#post-4819236
The_Train
2 Jun 2018
Latest list as far as the info I have picked up on here and elsewhere:
NumberEx No.LiveryTOCDepot/LocationCurrent State
769002319002TfWTfWCardiff CantonIn Service
769003319003TfWTfWCardiff CantonIn Service
769006319006TfWTfWCardiff CantonIn Service
769007319007TfWTfWCardiff CantonIn Service
769008319008TfWTfWCardiff CantonIn Service
769421319421Ex TL White & Blue DoorsTfWCardiff CantonConverted - awaiting testing
769424319424NorthernNorthernAllertonUndergoing testing
769426319426Ex TL White & Blue DoorsTfWLoughborough WorksUndergoing conversion
769431319431NorthernNorthernAllertonConverted - awaiting testing
769434319434NorthernNorthernAllertonUndergoing testing
769442319442NorthernNorthernAllertonUndergoing testing
769445319445Ex TL White & Blue DoorsTfWCardiff CantonUndergoing testing
769448319448NorthernNorthernAllertonUndergoing testing
769450319450NorthernNorthernAllertonUndergoing testing
769452319452TfWTfWCardiff CantonIn Service
769456319456NorthernNorthernNorth WestUndergoing testing
769458319458NorthernNorthernCrewe Arriva TraincareUndergoing testing
769501319009Orion Dark & Light BlueROGEastleigh WorksConversion to 769 complete - internal work ongoing
769502319010Orion Dark & Light BlueROGLoughborough WorksUndergoing conversion
769503ROGConversion work yet to start
769504ROGConversion work yet to start
769505ROGConversion work yet to start
769506ROGConversion work yet to start
769507ROGConversion work yet to start
769508ROGConversion work yet to start
769509ROGConversion work yet to start
769510ROGConversion work yet to start
769922319422Ex TL White & Blue DoorsGWRWolverton WorksConversion work yet to start
769923319423GWR GreenGWRWolverton WorksConversion work yet to start
769925319425GWR GreenGWRConversion work yet to start
769927319427Ex TL White & Blue DoorsGWRWolverton WorksConversion work yet to start
769928319428GWR GreenGWRNemesis Rail, BurtonConverted - awaiting testing
769930319430GWR GreenGWRReading TraincareUndergoing acceptance exam
769932319432Ex TL White & Blue DoorsGWRLong MarstonConversion work yet to start
769935319435Ex TL White & Blue DoorsGWRLong MarstonConversion work yet to start
769936319436GWR GreenGWRLong MarstonConverted - awaiting testing
769937319437GWR GreenGWRWolverton WorksConverted - awaiting testing
769938319438Ex TL White & Blue DoorsGWRNemesis Rail, BurtonConverted - awaiting testing
769939319439Ex TL White & Blue DoorsGWRWolverton WorksConversion work yet to start
769940319440Ex TL White & Blue DoorsGWRWolverton WorksUndergoing conversion
769943319443GWR GreenGWRReading TraincareConverted - awaiting testing
769944319444Ex TL White & Blue DoorsGWRDerby RTCConverted - now stored
769946319446GWR GreenGWRReading TraincareUndergoing testing
769947319447Ex TL White & Blue DoorsGWRWolverton WorksConversion work yet to start
769949319449Ex TL White & Blue DoorsGWRWolverton WorksUndergoing conversion
769959319459GWR GreenGWRNemesis Rail, BurtonConverted - awaiting testing
As always, the bold items are the ones I have updated since the last time I posted a list
Posted this in the Northern 769 thread but thought I better stick it in here as well :)
trainmania100
8 Nov 2015
Newhaven
How's the testing going chaps? Don't suppose there's any Genny gen gen on when they'll be tested around Redhill/Gatwick ?
spark001uk
20 Aug 2010
Any word on when it's venturing onto DC? Or is the AC/diesel ffr going to be completed first?
dmncf
4 Sep 2012
Thanks. Realtime Trains shows that this is running.
Didn't get very far if Realtime Trains is to be believed. Reports stopped at Reading West Junction at 1148 which suggests it went back to the depot.
