GWR Class 769 information. (Units no longer with GWR - Off Lease March 23)
TT-ONR-NRN
30 Dec 2016
Farnham
Seems a bit arbitrary to me given they've never carried such numbers even as 319s.
Indeed, it seems rather unnecessary and confusing when people shorten numbers to four digits.
I'm really quite curious to see the first class section - I'm wondering whether they're keeping the leather covering as was demonstrated on 166205, or if they're just using the same covers on wider seats. After all, they may want to keep it closer to the IET seats which are cloth.
I seem to recall it was just the same moquette with the wider seats from pictures that I thought were shared. Will have to see if I can take a look at lunchtime - 769946 appears to be behaving itself today.
That area in 166205 really isn't anything special.
Deepgreen
12 Jun 2013
Betchworth, Surrey
I think 166205 was considered a minor disaster and its features will not be repeated elsewhere.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
Spot on, same seats just recovered in the same Moquette as the standard class and some GWR Carpet. Either way, FC on the 319s was nothing special and I don’t expect these to be either. There wasn’t even a door to the 319 FC whereas I think the 321s (and of course Turbos do) had.
There was a door to first class on a 319 originally. It got removed at the last revamp in Thameslink days, possibly due to the cost of converting the door to one which could be dismantled in an emergency (which the 321s got).
768946 managed both trips on the North Downs line today. On the second eastbound trip I saw it slow at Reigate to change power but it didn't stop. Removing the intermediate stops would appear to reduce one possible source of failure.
fgwrich
15 Apr 2009
A new modification to the fleet that I don't think has been previously mentioned, they are now receiving the same style of body mounted cameras as the IETs and Turbo's, though unusually fitted at Window / CDL marker level height.
warwickshire
6 Feb 2020
leamingtonspa
Out off interest will the guards still be fully responsible for the doors.
Or say for example on the turbos ie the body side cameras are used for existing doo services ie driver only say twyford to Henley branch line
Will this be the same for the 769s on this line only. Hence the fitment?
Guards haven't been fully responsible for the doors on LTV services since Turbos were introduced. Driver release and ten-bell dispatch from new although door controls have since been fitted so that may have changed.
Henley and Bourne End are both DOO, originally with lookback / big mirrors.
warwickshire
6 Feb 2020
leamingtonspa
So that means then for that purpose just the Henley 769s from twyford will be still driver only then.
All it is. Is way up thread or mentioned elsewhere on here until op mentioned about this fitment that guards due to the original features off 769 would have meant a return off them working on this line since around 1993.
Obviously with the cameras on side and being LTV services then still will remain driver only then.
DownFast
30 Sep 2021
It started as 10 bells, then the door close buttons in cabs were modified so they were active in a non-active cab (so the guard could despatch from the rear cab) then went to the guard closing from the saloon panel once these were installed.
769s will be the same method of work for guard operated services (driver releases, guard closes) but can also be operated DOO. This meant refitting the door release buttons in the driving cabs as they were removed to make way for some of the diesel system controls/indicators, because TfW & Northern placed orders first and they don't need door release buttons in cabs.
They're the same kit as on the Turbos, as they are part of the ASDO/OTCM system being installed on both from the same supplier (Petards). The only significant differences between 16x and 769 are that 16x has two monitors in the cab (one for ASDO, one for OTCM) whereas there is only room for one monitor in the 769 cab (which does both ASDO and OTCM functions), and that the driving vehicles on 769 have two cameras as there would be a blind spot with only one.
warwickshire
6 Feb 2020
leamingtonspa
0H70 loco move ex Derby dep 0501.
5Q74 57312 769936 dep 1040
Confirmed on time 57312 leading 769936. Through Warwick.
However I get only 5 left now to be moved to reading.
Does anyone know what unit numbers are still to be moved please from wolverton. Thank you.
warwickshire
6 Feb 2020
leamingtonspa
So this means then that services operations wide as they are now with remain the same.
So iff 769s do end up on twyford to Henley as mentioned way up this thread then that service still remains driver only operated then
fgwrich
15 Apr 2009
Thanks for the info Downfast, that's quite interesting to read. I have to say though, while it's good to see another UK Supplier used, I hope Petards camera's are better than the CCTV fitted to the inside of the Turbo's!
