Greg Wetzel
Hello,
I have several questions regarding how the J70 class steam tram would function. As you'll see, I have little to no knowledge on steam trams.
1. Where would the firebox be located? Is it located in the cab closest to the chimney, or in the cab that'd be at the rear of the locomotive?
2. How would a steam tram like the J70 get a boiler washout? Does a steam tram have a smokebox of any sort?
3. In the "Railway Series," an engine named Toby is based off of a J70. In the book "Branch Line Engines," it is revealed that he has a whistle, which he uses to shoo a bull off the line. Do steam trams have whistles? And if so, where would it be placed? Also, where would the whistle cord be located. Would it be in the cab closest to the chimney or in the cab that'd be at the rear?
4. Toby is also equipped with a bell. So, if a steam tram has both a whistle and a bell, when would each of them be used?
5. How is the boiler structured in order for steam to travel throughout and to come out of the chimney?
6. How would a steam tram's firebox get cleaned out? Do they have ashpans?
7. Where are the water tanks located? How are they accessed?
8. How would coal be stored? Is it kept in the cab where the firebox is? Would be kept in bags, seeing how Toby doesn't have a bunker?
