TheHSRailFan
- Joined
- 16 Jun 2018
- Messages
- 245
Something I'm genuinely curious about and would like to see after Dorothy is transferred back up to the north portal is a walk-through of the completed tunnel considering how short it is.
The district council is trying to block approval of the remaining Bromford tunnel works so potential delays are in prospect.I'm guessing it'll be the second one, because based on the amount of work that's already happened at Bromford east portal, I'd have thought that the portal will be ready before the second Long Itchington bore is complete
What spurious reason(s) are they citing to justify blocking the works?The district council is trying to block approval of the remaining Bromford tunnel works so potential delays are in prospect.
All this will achieve, of course, is extra cost at the end of the day.
In general terms, their argument is that the extension to the tunnel is outwith the scope of the works authorised by the Act and, accordingly, a separate planning consent is required accompanied by a full environmental impact assessment.What spurious reason(s) are they citing to justify blocking the works?
You'd have though that a longer tunnel would be preferable for numerous reasons, amongst which I believe the original plan had the line going through a nature reserve (the green area around the River Tame south and east of Castle Vale). Surely the line no longer going through the nature reserve is better?In general terms, their argument is that the extension to the tunnel is outwith the scope of the works authorised by the Act and, accordingly, a separate planning consent is required accompanied by a full environmental impact assessment.
Needless to say, HS2 does not agree with this.
I daresay it will end up back in court before the year is out.
Hang on, so they’re objecting to the scheme being made *less* destructive to the built environment in the area?In general terms, their argument is that the extension to the tunnel is outwith the scope of the works authorised by the Act and, accordingly, a separate planning consent is required accompanied by a full environmental impact assessment.
It's not even "built environment": it's "unbuilt environment" that's being spared by the extra length of tunnelHang on, so they’re objecting to the scheme being made *less* destructive to the built environment in the area?
And the specific link for the order being applied for is here:Authority for the change to the Bromford Tunnel is being sought under the auspices of a Transport and Works Act Order (TWOA.)
Transport and Works Act orders: a brief guide
Outlines the procedures involved in applying for a Transport and Works Act order.www.gov.uk
I believe the cutter head and associated bits will be removed and taken back to the start by road, but the majority of the machine will be pulled back through.
Yes, the machine will then be used to note one of the two Bromford tunnels. I'm guessing it'll be the second one, because based on the amount of work that's already happened at Bromford east portal, I'd have thought that the portal will be ready before the second Long Itchington bore is complete
Good to see this country still can do some great contructions.Incidentally, there's already a few bits of a TBM on site at Water Orton.
They can be seen in this vid at about 1m24s onwards...
A web search for the name of the group reveals that it's at Swynnerton, so on phase 2a.Good to see this country still can do some great contructions.
Meanwhile, the anti-HS2 groups remains persistent and continues to call for donations.
If anyone doesn’t already know he has had a thread here for a few years linking to his blog:IIRC the "Bluebell Woods" (Swynnerton) camp got evicted a few weeks ago with little, if any, media attention. This was the last (of very few) "protest camps" along the line of route. For anyone wanting more details on protestor activity, rail journalist Paul Bigland blogs (and Tweets) on the subject from time to time - one could do worse than look through his blog site.
Thanks!Fantastic pics. I’m going to have to find myself a cycling route in that direction!
The A412 used to be my main route for work from Watford to Slough a few years back. It was not a nice road for cyclists or pedestrians even then - it's undoubtedly worse now. Having moved away some 300 miles or so, I find it hard to believe that so much activity and construction work is going on now in what is (or was) a lovely, peaceful valley. Having said that, the kit being used to place these segments is awesome and the viaduct (bridge or whatever) when complete will look fantastic. I just hope I live long enough to be able to travel over it.Thanks!
Unfortunately it’s a pretty difficult area to get to! Unless you want to cycle on the A412, which I doubt would be pleasant. In a year or so they ought to be passing over the Grand Union Canal towpath though, so I’m sure there’ll be good shots to be had then.
To be fair, I was actually surprised at how peaceful the valley still is. I walked down from Tilehouse Lane through the patch of ancient woodland there and the road noise was far more intrusive than the construction work. Admittedly the site where Tilehouse Lane Cutting was being built was a lot less pretty, lots of diggers and piles of mud.The A412 used to be my main route for work from Watford to Slough a few years back. It was not a nice road for cyclists or pedestrians even then - it's undoubtedly worse now. Having moved away some 300 miles or so, I find it hard to believe that so much activity and construction work is going on now in what is (or was) a lovely, peaceful valley. Having said that, the kit being used to place these segments is awesome and the viaduct (bridge or whatever) when complete will look fantastic. I just hope I live long enough to be able to travel over it.
Incidentally, I used to live for a time in Buckingham and travelled through Winslow many times, looking down at what is now the EWR and was once a tree and bush infested narrow corridor, looking more like a nature reserve. Then I lived close to Brackley (and look what they're now doing just north of there).
Maybe I need to move to an area which needs its rail links restored, then move away so that construction can start!!
Mods please feel free to move this comment if necessary. My last misplaced post, on digital v. physical tickets, started a thread that is now 550 posts long and still going!
Tilehouse Lane was a "short cut" to work when A412 and M25 were clogged (frequently). One morning as I was driving down it, a Bentley pulled out of the driveway of a large house right in front of me, forcing me to jam on the brakes. It was Paul Daniel and the Lovely Debbie Magee. He's dead now and she'll be very glad she's not living next to HS2 works ...To be fair, I was actually surprised at how peaceful the valley still is. I walked down from Tilehouse Lane through the patch of ancient woodland there and the road noise was far more intrusive than the construction work. Admittedly the site where Tilehouse Lane Cutting was being built was a lot less pretty, lots of diggers and piles of mud.
I wonder if it’s just because the concrete segments are bigger and heavier than on the Byker Bridge? Certainly that’s a pretty lightweight structure compared to the Viaduct.It’s amazing how massive the lifting equipment is for this viaduct compared (for example) to the way the Tyne Wear Metro’s Byker viaduct was built. AFAICS the building process uses a very similar technique, the balanced cantilevers extending simultaneously either side of the piers. So is this massive temporary structure a way of removing almost all risk in a way that wasn’t expected in the 1980s?
Post #1365 has the images.
Are there any bridge builders here who could comment?
It's not designed specifically for HS2 so I guess it could be over-engineered for the job to some degree
Ah, that’s a key point I hadn’t appreciated, that it has been and could be used for similar projects in future.It's not designed specifically for HS2 so I guess it could be over-engineered for the job to some degree, though the segments aren't exactly light…
Yes and no. I believe the degree to which they are match casting is more than in most bridges where the individual segments are more uniform.I see in the linked article they mention all the sections being slightly different and “match-casted” to the previous one that they but up against, but AIUI this part of the procedure is in common with many other similar bridges or viaducts that are curved in one or two dimensions.
Quite!!One hopes it’s not under-engineered…
I don't think the match casting of itself affects the size of the equipment needed to position the segments, and nor is it particularly related to whether the bridge is curved. The process just involves a segment being cast against its predecessor on the ground, separated by something resembling clingfilm. Once the new segment is sufficiently cured to hold its shape, and the predecessor sufficiently to withstand the stresses of being lifted and in position, then that can take place. Each segment is re-united with its predecessor during assembly of the bridge itself and the match-casting ensures they fit exactly.Ah, that’s a key point I hadn’t appreciated, that it has been and could be used for similar projects in future.
Hence about the only remarkable feature of this viaduct is its length. Even so I’ve no doubt they’ll take every opportunity to issue exaggerated PR about it…
Yes, I also saw a Byker Viaduct construction video on YouTube a while ago which was fairly informative about match casting, although I don’t think they actually used that term. The lifting rig was noticeably simpler.I don't think the match casting of itself affects the size of the equipment needed to position the segments, and nor is it particularly related to whether the bridge is curved. The process just involves a segment being cast against its predecessor on the ground, separated by something resembling clingfilm. Once the new segment is sufficiently cured to hold its shape, and the predecessor sufficiently to withstand the stresses of being lifted and in position, then that can take place. Each segment is re-united with its predecessor during assembly of the bridge itself and the match-casting ensures they fit exactly.
Do an image search for "Riyadh Metro Viaduct Construction" for pictures of a very similar operation there. There will be many others too.
Affordability
Removing the Golborne Link from the hybrid bill reduces the overall cost range of the scheme from £15 billion-£22 billion to about £13 billion-£19 billion.
The government is committed to exploring alternatives that provide similar benefits to the Golborne Link within the £96 billion envelope of the Integrated Rail Plan. Analysis suggests that there are credible alternatives to the Golborne Link that range from providing more benefits at a higher cost to those that provide fewer benefits at a lower cost.
Conclusion
On the basis set out in the accounting officer assessment, I note that:
The decision to retain or remove the Golborne Link should take a range of factors into account including funding, impact on the business case and delivery of the government’s wider strategic aims for the scheme.
Removing the Golborne Link reduces both the costs and the benefits of the Crewe to Manchester scheme. The reference case BCR is 0.7 to 0.9, depending on whether a 60 or 100 year appraisal period is used. However not all benefits of the scheme are captured within the BCR.
The VfM for the HS2 network, with or without the Golborne Link, is still expected to deliver a BCR above 1.
The wider strategic case for the both Crewe to Manchester and the wider network, which is built upon increased connectivity in the North, remains largely intact if the Golborne Link is removed.
The government has decided it wishes to consider affordable alternatives to the Golborne Link that maintain or improve overall VfM. Removing the Golborne Link at this stage means it is no longer part of the principle of the bill. This allows this work to continue while retaining optionality (as retaining the Golborne Link in the bill would, in effect, create a commitment to build it).
Work is at an early stage on alternatives and the costs and benefits of such options are currently uncertain. It would be possible to reintroduce the Golborne Link by a separate process if no viable alternative is identified, though this would incur additional costs.
There are no reasons of propriety or legality why the government
should not take the decision to remove the Golborne Link from the bill.
On this basis and the assumption that further work on alternatives will be based on options that present equal or better value for money as other outcomes, I conclude that removing the Golborne Link from the current HS2 Crewe to Manchester Bill and continuing with investment in the Crewe to Manchester scheme, should Parliament agree, is consistent with official guidance on managing public money.
