Island Line Upgrade updates
Gloster
4 Sep 2020
Up the creek
Is ferry capacity an issue during August in trying to get more units across there?
Probably not if they are prepared to move them in the evening or middle of the night. It might slow things down a bit, but the whole project seems to moving at a snail’s pace.
Gloster
4 Sep 2020
Up the creek
National Rail Journey Planner now shows buses until 29th August, trains from 30th.
I wouldn’t make any definite or expensive plans based on this. It appears to be the aspiration, but there are an awful lot of potential pitfalls remaining and it only needs a few problems to appear for the date to be unachievable.
norbitonflyer
24 Mar 2020
SW London
Indeed - I was observing that until yesterday the Journey Planner was showing trains would be running from Sunday August 1st. I assume August 30th (a Monday this time) is just another placemarker.
Gloster
4 Sep 2020
Up the creek
A look at the rails at Esplanade today suggests that nothing has run over them since the road/rail vehicle hauled 001 through the tunnel nearly two months ago. The rail is once more so rusty that the thin line on top produced by the last movement has disappeared.
Gloster
4 Sep 2020
Up the creek
The line is apparently flooded to the south of St Johns Road and, by the sound of it, in the station area as well: the flood warning is expected to last for another two days. We shall see if this will further delay the reopening. 2022, anyone?
Chris125
12 Nov 2009
Doesn't look too bad thankfully, no reports of the depot being flooded or damage to the railway so far - we've had three biblical rain events in recent weeks and the brook seems to have topped out at similar levels each time so [touch wood] the improvements appear to be working.
River level heading back to normal:
43096
23 Nov 2015
The depot has been flooded.
Just a gentle reminder this is an infrastructure thread to discuss the progress of the Island Line upgrade.
The forum has plenty of capacity for alternative threads to discuss anything else :)
Chris125
12 Nov 2009
That's not ideal! Fingers crossed none of the trains have been affected, 007 spent a long time OOU after the depot was flooded some years back.
tnxrail
8 May 2011
I was in the area Monday went to see if there was any activity and saw this.
pompeyfan
24 Jan 2012
16 washouts reported between Smallbrook and Brading, some up to 3ft deep and 3 sleepers wide.
Chris125
12 Nov 2009
Wow, the Brading side of Smallbrook? That's much more unusual, can't recall that before. Normally it's the Ryde side where the brook alongside can overflow.
Gloster
4 Sep 2020
Up the creek
The flood warning appeared to be mainly north of Smallbrook (possibly an inappropriate name recently). One wonders how much worse it could be between Smallbrook and St. John’s Road or Esplanade.
hermit
23 Jul 2019
Isle of Wight
Areas south of Smallbrook did have a lot of rain - the Brading to Ryde road was flooded at Beaper Shute, which I don’t remember happening before.
Gloster
4 Sep 2020
Up the creek
It may have been a lot of rain falling in the catchment area of the streams that feed into Monktonmead Brook, which runs alongside the railway to north of St John’s Road. Rain was very localised: in Wootton there was virtually nothing.
Chris125
12 Nov 2009
BBC: Isle of Wight rail work falls further behind after flooding
South Western Railway (SWR) said it could not give a specific re-opening date but expected the railway line to remain closed into the autumn.
It said newly laid ballast had been washed away from underneath sleepers and electrical, signalling and points equipment had also been damaged by the water.
In a statement, the operator said: "We had been aiming to reopen the Island Line in the first half of next month, but flash flooding has added uncertainty to our programme.
DavidGrain
29 Dec 2017
According to this report severe flooding up to 18 inches deep at most stations between the platforms has washed away ballast putting the projected reopening back to autumn.
SWR said during the recent flash floods - when more than a month's worth of rain fell in two hours - water was 18 inches (46cm) above the track at Ryde St John's Road, Sandown and Shanklin railway stations.
Meerkat
14 Jul 2018
This is pretty damaging for the railway project reputation - can’t even get a simple line upgraded on time.
Do they need to put in some better drainage whilst they are at it - this will happen again….
Gloster
4 Sep 2020
Up the creek
The County Press and Island Echo mention that the previous date they had been hoping to open by was the first half of next month (September). This is not even meteorological summer, which ends on 31 August.
Gloster
4 Sep 2020
Up the creek
SWR have released some photos, including one of dirty water swilling around 484 001. The water seems to be up to about the level of the bottom of the obstruction deflector.
snowball
4 Mar 2013
The other main definition of summer (sometimes called astronomical summer) is from the summer solstice to the autumn equinox, and so begins and ends about three weeks later than meteorological summer.
Chris125
12 Nov 2009
While I'd be surprised if it was that high at St Johns going by the river levels reported by the EA, I don't see how that's even possible at Sandown and Shanklin - different articles seem to be reporting it slightly differently so perhaps some miscommunication.
KendalKing
4 Mar 2009
North Lancs
I think you are being a bit unfair to Network Rail and South Western Railway, as they are not responsible for the rain, nor were they responsible for the Covid pandemic.
After nearly 200-years of running trains, you would honestly expected the railway engineers, to have come-up with a solution to the age old problem of flooding on railway lines, by now.
Maybe we need a modern day, super engineer like Isambard Kingdom Brunel, to sort out the ongoing problems.
Meerkat
14 Jul 2018
I was saying what the Treasury/politicians will say when told about a possible project “oh yes, this is a realistic budget/schedule”
snowball
4 Mar 2013
I seem to remember reading an article some years ago which suggested that George Stephenson, form his mining experience, understood drainage issues better than Brunel. It may have been the same Modern Railways article that I and others have mentioned in other threads, about the difficulties of achieving clearance for overhead electrification at bridges.
