reddragon
How are you making the hilly landscape? Looks like polystyrene with plaster cover?Thanks guys.
Although I haven’t been able to move off the sofa for a few evenings this week, I have been making steady progress with the fold up extensions on each end bit by bit.
The main aim is to tie it in to what I’ve already made so that it all looks like the one scene and this’ll mean reading back through the thread at some point (and my eBay purchases) to make sure that I go through the same processes.
So after much testing of the track (including @Peter C encouraging me to give the super-elevation a go), I was happy enough to blow a few coats of Railmatch Sleeper Grime over the track and make a start on the scenery.
Anyway here’s some photos of the first cuts of polystyrene (actually it’s off-cuts of Celotex type insulation board), roughly sawn to shape and then graded using two cheese graters. First a normal one and then a finer one like what you’d use for Parmesan if you’re posh like what I is.
You can also see that I’ve cut into the top layer of cork to create the rivers that runs along the line in this area (the Yeo and the Taw).
Next up are a couple of photos (one taken with the flash as it highlights the contours) of the initial coat of filler and then after a soaking with PVA - the roads going in...
In the background (just behind the wee bridge and the opposite large bridge) will be a backscene (probably just sky to be honest) and my intention is that I’ll blend the various roads and railway into it via the copious use of trees...
Still thinking about this at the moment but I’ve got some ideas, and I’ve made a LOT of trees for this!
Around the back I’m creating a little mini cameo of Eggesford station, which is the next station north of Lapford on the Barnstaple branch and has a passing loop, which you won’t actually be able to see from the front (again because of the backscene), but it’ll be next to the fiddle yard and viewable when you’re operating the layout from behind.
It’s slightly different to the original due to the curves going the wrong way though, which is why I’m calling it Eggishford...
But I’m having fun making it.
Here it is in all of its staggered platform weirdness:
So fellow railway modelling types, any thoughts would be much appreciated.
Bouncing ideas off each other is what it’s all about even if you end up going your own way with things...
Nick
Great finish by the way! I need to learn how to do that
