London Connections map - any update?
miklcct
2 May 2021
Cricklewood
The London Connections map produced by TfL, dated May 2014 shows all the railways in London on a geographical map.
This map is much more readable compared to the official "rail and tube map". The only shortcoming is that it lacks the fare zones.
However, this map is becoming outdated. Are there any updates to this map, or other up-to-date geographical railway map (showing all of the tube, DLR, trams and National Rail) I can use?
Thanks all.
Thanks all.
IIRC the “London’s rail and tube” map replaced the “London Connections” map. Once Oyster PAYG became available throughout the zones on (nearly) all modes, I suspect there was no point in printing a map without the fare zones. I believe the present map is a joint TfL/National Rail product?
(There’s a thread in another sub-forum suggesting the 2-sided folded paper copies, (London & SE & London Rail and Tube), that used to have the to hand out at NR stations are no longer printed, but I’m not sure about that.)
Basil Jet
23 Apr 2022
He's talking about a different London Connections map, namely https://www.whatdotheyknow.com/request/224813/response/560395/attach/3/London%20Connections%20Map.pdf
I think this only became available because someone put in an FOI request, so if somebody puts in another FOI request, a new version may escape from TfL, because they may well be updating it for internal use.
It has not been updated since the start of the pandemic, but the December 2019 one is still in racks at a number of stations and so is maybe still being printed.
bcarmicle
11 May 2018
https://www.whatdotheyknow.com/request/tube_map_5 says they hadn't updated it after 2014, so it's probably been fully abandoned at this point. I think the only realistic way forward short of starting from scratch would be to FOIA the original design file (i.e. not PDF) and edit that.
I don’t think that was ever a publicly available map. I think them naming it “London Connections” seems to have added to the confusion.
I've seen the geographical map before, but didn't realise anyone called it "London Connections" which I agree is confusing as London Connections was the name given to the predecessor of the Rail & Tube Map.
stuu
2 Sep 2011
What was the geographical map produced for, if not intended for public use?
Dstock7080
17 Feb 2010
West London
internal use.
there are also standard Tube maps with London boroughs overlaid; where depots and other facilities are located etc.
