Lothian Group discussion (Lothian City, Lothian Country Bus and East Coast Buses)
route101
16 May 2010
Not really, the nearest is a good 10 minute walk and goes on a much longer route compared to the 8, my main alternative uses mostly B9TL’s so I try and use that sometimes to mix it up.
Just unfortunate the route I use is the one that can’t have them. But hey ho there’s more important things to worry about.
Yes Indeed, few options. My nearest bus stop with regular service is 20 mins walk away.
29 May 2008
Featherstone, West Yorkshire
The only corner I know of that the XLB’s can’t do is Pilton Drive North onto Boswall Parkway on the 8 in the Royal Infirmary direction only.
It is possible and has been done, but is extremely tight and really not recommended unless absolutely necessary due to the risk of hitting the fence on the corner or the traffic Islands.
FlybeDash8Q400
26 Jun 2018
Edinburgh
Wow I was always told by my friend who drives for Lothian that it was completely impossible rather than it being unadvisable. I’ve seen smaller buses hit the fence before which is why I thought the ex London buses were great for this part of the 8 - admittedly less useful elsewhere. In any case I think Lothian would be better not serving the turn and run a service serving both Pilton Drive North and Pilton Drive (lots of new housing up there so there’s definitely a potential market) but the humps make that a bit trickier and other services would need to be reduced for it to work (the 27 being the most likely). A less frequent service could still do Granton Road etc but run the whole length of Boswall Parkway instead of half. It’s something in my view that when the trams arrive that could probably be looked at if it was a good idea and practical.
alexf380
6 Mar 2011
Musselburgh, Scotland
Running a service right down Pilton drive to the Morrisons at Ferry Road, then run east from there could work. Passenger numbers could probably stand the 8, 21 and 27 all going along that stretch (reduce the 27 to every 20 mins, maybe the 23 too to give a combined 10 min frequency from Goldenacre to Tollcross?) The 14 and 19 both run the full length of Boswall Parkway so that's that box ticked.
DunsBus
12 Jan 2013
Duns
There is a problem with regards to Pilton Drive, though - the hump-back bridge over the old railway line. As I remember, it has quite a sharp crest.
The bridge is the reason why there's no bus service on Pilton Drive, though a tendered minibus service, the R70, did briefly serve it in 1993-94. It also was the reason why all loads leaving the Bruce Peebles factory (where the housing is now) didn't head direct to Ferry Road - they all headed down Pilton Drive and Pilton Drive North. Heading to Ferry Road would have caused problems with trailers bottoming out on the bridge and, through time, likely have weakened it.
FlybeDash8Q400
26 Jun 2018
Edinburgh
The bridge does have quite a bad crest however I have seen buses go this way before, admittedly only when they are off service and there’s a number of road closures so it doesn’t happen that often. Coaches and trucks are now a common sight on Pilton Drive though. Perhaps something that might happen if trams ever go that way (as the bridge would need to go) - but that would probably render any potential bus route pointless.
DunsBus
12 Jan 2013
Duns
Thanks for clarifying this. I remember my grandad saying to me that the bridge was the reason for Pilton Drive not having a regular bus service.
So the bridge can cope with buses, admittedly infrequently. It certainly wouldn't have coped with the loads leaving Bruce Peebles, though - some of these were rather on the large, and heavy, side! (Slightly off-topic, there is footage on Facebook of the 1999 fire there that took out the transformer shop and ultimately resulted in the eventual closure of the factory site. It makes for spectacular, if sad, viewing.)
I remember there being a dip on the Ferry Road side of the bridge, which was levelled out when the nearby Morrisons was built in 1996. There were plans the previous year (1995) to close off Pilton Drive at the bridge itself - the relevant TRO was advertised, but ultimately came to nothing.
CN04NRJ
28 Nov 2019
Assuming this is some kind of bug? Or can it really be 713? (screenshot of 713 tracking on the 12)
Aictos
28 Apr 2009
I'm not too familiar with the area but you say the old railway line, do I take it that the railway line no longer exists there in day to day use and if so could they not replace the bridge to reduce the sharp crest you talk of at all?
FlybeDash8Q400
26 Jun 2018
Edinburgh
Lothian_Bus
29 Jan 2018
All service 26's terminating at Corstorphine Road roundabout from 7pm tonight and tomorrow night due to an issue with anti social behaviour.
Bus9120UK
5 Oct 2019
Edinburgh
Tweet from Lothian's twitter about this: https://twitter.com/on_lothianbuses/status/1368199493150273541
Due to an incident relating to anti-social behaviour, all Service 26s will terminate at Corstorphine Road roundabout from 1900hrs tonight & tomorrow night. Please plan accordingly where possible if you must travel at this time - thank you.
Update:
Lothian won't be serving Clermiston at all, from 19:00 hours. Link here: https://twitter.com/on_lothianbuses/status/1368234932833771522/photo/1
31 Jul 2020
West Lothian
I am not sure, but by anti-social behaviour I imagine it's damaging vehicles in the area.
Ahh, okay thanks, It's a shame to hear about stuff like this happening, not even a month since the incident in Wester Hailes, also I think these people are also forgetting about the pandemic.
Things like this will probably never stop but hopefully it can be at least calm down a bit, not only are they affecting the company, they are also putting more and more fear into the drivers.
DunsBus
12 Jan 2013
Duns
The railway line there is long since defunct - it closed in 1962 and became a footpath in the 1980s.
I wonder how these little s###s would like it if I was to go round to their houses and throw stones at (and put the windows out on) their dads' cars.
Bring back the belt, I say!
Tartan shorts
26 Dec 2019
Edinburgh
As I said before. These things tend to happen in spates. Probably now helped with teens communicating on social media. It kind of grows legs as a "fun thing to do" for bored kids It was Niddrie the other night. It's the same handful of areas that pop up time and time again.
Quite right that they're pulling services. They should do likewise elsewhere tho it can be hard if it's a through road like Niddrie Mains, Westerhailes Road etc. You'll tend to find that in these areas the parents will care more about something when they're directly inconvenienced by it. If they can't get a bus on their doorstep they'll take action against their little cherubs.
What is the cost of replacing glass these days? I remember when it was bad in the early 00's it was quoted at about £1k to replace a standard full size window. Not to miss the time taken and the clean up of the debris inside the bus.
CN04NRJ
28 Nov 2019
I believe it it was around 30-40 window incidents (some more than one window) just last month alone. That's not mentioning when they've missed the window and damaged the bodywork, I've had two MCVs handed over to me with fresh bodywork damage from rocks recently.
PSV glass were doing three buses one morning at Longstone alone the other week (including an upper deck window on a B5LH).
Tartan shorts
26 Dec 2019
Edinburgh
Thanks. While repair bills are not good at the best of times, when revenue is so far down at the moment the last thing you need is a constant churn of glazing bills night on night.
That's obviously of lesser importance to the risk of injury to staff and passengers.
And of course the people inconvenienced waiting on a bus that fails to arrive because it's sitting somewhere with a missing window.
FlybeDash8Q400
26 Jun 2018
Edinburgh
Hopefully this starts to draw a line on this latest area of incidents. Pennywell Road, Wester Hailes among others seem to have remained issues (no surprise to me), just hope it doesn’t take somebody to get hurt before people actually start to pay for their actions, the kids are just bored and have to cause bother. I’ve only ever been on a bus once that had rocks thrown at it, I was upstairs at the time however a young mum with her child needed a good reassuring afterwords. And surprise surprise nothing happened to those that did it.
OmniCity999
30 Jan 2018
Is this at Clermiston and Clerwood?
And what has happened (gang violence, damaged buses, driver attacks, ect...)?
A member of staff has been assaulted and taken to hospital.
Unfortunately police resources haven't been enough. Councilors are rather upset. Would be a different story if it was there family. The company is acting accordingly.
Aictos
28 Apr 2009
Okay, so can they not remove the bridge and replace it with a newer one that's less steep?
As to bringing back the belt, they won't for a number of reasons - I can't go into detail as it would be off topic.
FlybeDash8Q400
26 Jun 2018
Edinburgh
They could, but it’s not viable. Only if trams ever go that way in my view will it ever happen.
DunsBus
12 Jan 2013
Duns
Were it up to me, I'd pull all services after 7pm. It's not worth risking drivers' safety just because of a few bored kids. Yes it would inconvenience others, but the message has to be put across.
