Luton refuse trucks between 1995/98.
Ladder23
29 Oct 2015
Hi guys,
I can’t find a appropriate place to ask this so hoping to try my luck here. I am after any info or photos of the fleet of refuse trucks used around the time stated for Luton borough council.
I have a vague recollection of the fleet being yellow, but I cannot find anything at all despite hours of searching,
can anyone help.
Thanks
westcoaster
4 Dec 2006
DTOS A or B
Really thinking about it, sometime in the very late 90's they changed to white bin lorries iirc Daf's. Believe they still have white Daf's as the bin lorries of choice today.
Edit
Was they Seedon Atkinson lorries
Ladder23
29 Oct 2015
Edit
I’ll look! Thanks for your help I’m at a dead end with this
westcoaster
4 Dec 2006
DTOS A or B
Only other option is facebook groups of luton past.
I did find on picture of a LBC vehicle from 1995 that was a LDV van in white with the red council logo on it ( I found that on Flickr (( searched for luton bus 1995 and it was in amongst bus pictures)) might be worth trawling through those in a chance of one being in the background).
Ladder23
29 Oct 2015
I did think that. Also thought to look for buses as the trucks should always be around so chances of one in the background as you say is likely! Cheers for the help
westcoaster
4 Dec 2006
DTOS A or B
Found a yellow council lorry https://www.flickr.com/photos/andysbusphotos/8997530437/ behind the bus
Search manchester street luton
Yellow daf coucil vehicle next to the town hall service area. Might be worth a more In depth look.
Again LBC seen to have a long history of DAF and LDV vehicles, which they still do to this day.
westcoaster
4 Dec 2006
DTOS A or B
LBC kingsway depot
2 photos dated 2005 show multiple seedon Atkinson bin lorries, a bit after the era you wanted
They are in blue which I do not remember.
Ladder23
29 Oct 2015
LBC kingsway depot
Great find! Funnily enough I have a photo with me and the yellow truck in the background from when I was young. I was mad on them as a kid, but the photo has been misplaced and I cannot locate it otherwise I’d share!
With all the transport photos on Flickr I am surprised to not find one yet! I’m sure someone out there recorded/ photographed the fleet
westcoaster
4 Dec 2006
DTOS A or B
A yellow council vehicle in this photo
Ladder23
29 Oct 2015
Thanks for carrying on for me! I still have no luck, will spend a hour or so now though!
Tom B
27 Jul 2005
Depending on how badly you need to know, you could either speak to the records department or put in a FoI, although whether information on dustcarts from 30 years ago is held on file (maybe) or easily accessible (unlikely) is debatable. But you never know, they might ring up old Bert who's been there for donkeys years and has all you want to know in a buff file in the basement.
Brooke
13 Jan 2020
Switzerland
I worked in waste haulage years back (but know nothing about Luton specifically!). The clue here might be mention of them being square & that we talk mid-90s. That sounds like one of three cab designs: the steel cab version of a Dennis Delta, or it’s replacement the Dennis Elite, or maybe a Seddon Atkinson with their pre-Paccar cab. Here you can find links to images (not mine) of them. Was it one of these?
Dennis elite: https://topworldauto.com/cars/dennis/dennis-elite/photos.html
Dennis delta with steel cab: BBN274 1987 Dennis Delta Refuse Collector | Images of Maltese Buses and other forms of transport in the Maltese Islands:
Sed Atki 201 / 211 pré Paccar: CBJ023 1987 Seddon Atkinson 2-11 Refuse Collector | Images of Maltese Buses and other forms of transport in the Maltese Islands:
Ladder23
29 Oct 2015
Great response thanks!! Let me dive in and see
Ladder23
29 Oct 2015
Still in deep search, have found nothing from the 96-98 period. Can anyone recommend any sites I can look on
Ladder23
29 Oct 2015
And by deduction then, whatever they were, they weren’t one of the three types above? Will ponder...
As much as I hoped, I am in doubt to all three as I have strong believe they were DAF.
Brooke
13 Jan 2020
Switzerland
So if we know they were DAFs then it becomes a lot easier to identify i think.
Leaving aside their long haul trucks, DAF have only really had three basic designs (eg from a cab design point of view) through the last 20 or so years.
The DAF CF is the most likely. This has a very distinctive cab that is wider above the wheels. It used to be known as the 65/75, then became the CF, but it’s broadly the same vehicle. Here is one as a dustcart.
For very narrow streets and tight turns, you occasionally see the DAF LF being used as a small dustcart. This used to be the DAF 45/55 and here is one. It’s a development of the Leyland Roadrunner from the 1980s.
If we really go back to the early 90s there was also briefly a Leyland Daf 60/70/80 like this. These were like a larger version of the Roadrunner in style, but much less common the ones above.
So basically, if they were DAFs they were one of these three in some form or other...
Ladder23
29 Oct 2015
That’s a great response thanks so much for narrowing this down for me. I will take a look at these now and see if I can get any info of the bodies used too
Ladder23
29 Oct 2015
Little late but I have finally found a photo of me as a young lad stood with one in the background, I can confirm in 1997, they were Yellow Dennis delta crew cabbed 6x4 24 tonne chassis with Phoenix (1) series rear loading units.
Brooke
13 Jan 2020
Switzerland
Excellent - pleased the mystery is solved for you!
Ladder23
29 Oct 2015
Still haven’t found any photos, however apart from the lifting gear, the truck appears to be virtually the same as the photo attached.
not sure how long after 1997 the trucks were replaced as these ones were 87/88! So getting on a little even then.
