Major Disruption At Woking (31/7/17)
SpacePhoenix
18 Mar 2014
There's major disruption at Woking at the moment:
http://www.nationalrail.co.uk/service_disruptions/168397.aspx
A signalling problem at Woking is causing major disruption to journeys between Woking and Wimbledon.
Services may be cancelled, delayed by up to 120 minutes or revised.
We anticipate disruption will continue until 14:00.
The following alterations will apply:
Services from Portsmouth to London Waterloo via Eastleigh will terminate at Winchester
Services from Portsmouth to London Waterloo direct will run via Cobham
Services from Weymouth to Waterloo will be diverted via Havant
Services between Exeter St. Davids and London Waterloo will terminate at, and start from Basingstoke
Some services from Poole to London Waterloo will terminate at Winchester
Services from Basingstoke to London Waterloo will be cancelled
Services from Alton will run to Guildford and terminate there
Rail replacement buses are running from Woking and Basingstoke.
Customer Advice:
You may use your ticket on:
Great Western Railway services between Reading and Basingstoke / London Paddington
CrossCountry between Basingstoke and Reading
London Underground services from London Paddington to London Waterloo
Stagecoach Buses between Aldershot and Reading / Guildford
GW43125
8 Dec 2014
From what I've heard, a few track circuits failed outside Woking earlier which blocked both up lines from Brookwood (from Guildford was ok) just south of the station.
pompeyfan
24 Jan 2012
I think it was slightly more serious, otherwise stuff would have been able to keep moving, where as nothing was moving at all from Basingstoke towards Woking. 1T22 0650 Portsmouth Harbour - Waterloo Via Basingstoke was R/T leaving Basingstoke and 205L into Woking. I can only assume the points locked up.
GW43125
8 Dec 2014
I think the points went OOC too-everything was stumped
