National Routeing Guide update
RJ
25 Jun 2005
Back office
Appears to have been updated again this week.
The URL has changed, with a brief step by step guide of how to use it shown on the new web page. Thumbs up from me if it aids staff in understanding how to identify permitted routes - though of course, there is the hurdle of getting them to appreciate its role in the first place.
A significant change being the maps - it appears they can no longer be downloaded in PDF form, instead being presented in a Google Maps based web app. At this moment in time, I think the PDF based maps contained less scope for disputes to arise.
The NRG can now be found here - http://data.atoc.org/routeing-guide
talldave
24 Jan 2013
Just had a peek at these for the first time - fascinating!!
There's a "D" missing from the top diagram on page F4 though!
RJ
25 Jun 2005
Back office
that's great, never knew there was a bridge direct from Morecambe to Barrow in Furness ;)
The maps seem to suggest non existent links in some places and appears to provide a line of best fit in others. Map HK is very unclear on the route between Faversham and Ramsgate. London Group appears to be focused at a static location which opens up a whole new range of routing possibilities.
I'd like to see rules clarified to explain how we use the red lines in relation to the real lines shown on the maps.
I like the drop down functionality of the new maps page compared to scrolling through a pdf file. But I share the concerns of RJ in interpreting the map.
CallySleeper
27 Jun 2006
trentbartonland
I can see what they've tried to do with the maps, but I don't like it - it's too ambiguous. You are lead to only assume where the routing points are on the map, and which specific lines are being refered to, since there are no physical labels (i.e. like on the PDFs). This also becomes harder as you zoom out.
I also don't like how intermediate stations are not covered by the lines. Map IP is one horrific example of this.
Also, what's an interchange in this context?!
cjohnson
3 Sep 2009
Section C has gone wrong somewhere in the update - e.g. Lincoln is only listed against RPs starting with L or later, and from Wivelsfield RP you can only look up routes to Wolverhampton or York!
button_boxer
12 Nov 2009
Though this does make sense when you consider that the maps are only for tracing routes between routeing points, they're not relevant to the segment between an associated station and a routeing point.
CyrusWuff
20 May 2013
Can't access the maps at work, though whether that's down to firewall issues or the fact that we still use IE8 I can't tell.
Haywain
3 Feb 2013
I was surprised to notice that there is a map RJ. I didn't know what to expect to find! :D
Deerfold
26 Nov 2009
Makes it very confusing when you have lines from Leeds to Skipton that look to not go through Shipley (though the line from Bradford does look to).
Goatboy
23 Jun 2011
Still not fixed the bizarre change whereby Worcester to Glasgow is banned via the ECML yet Bromsgrove to Glasgow (You almost certainly will pass through Bromsgrove if travelling from Worcester to Glasgow) is permitted via the ECML.
Merseysider
Fares Advisor
22 Jan 2014
Map ML no longer shows Liverpool - Kirkby - Wigan or Liverpool - Huyton - Earlestown - Manchester. Have these routes been moved to a different map?
Baxenden Bank
23 Oct 2013
Lets face it, using routeing points and maps is the wrong answer to the question. It was a quick fix at the time of privatisation which has outlived it's purpose. Like an alcoholic, until someone puts their hand up admits they have a problem, they will never move forward. The number of routeing points and maps together with ever increasing numbers of (not actually permissable) negative easements will continue until virtually every station becomes a routeing point in its own right. Bite the bullet and go straight to station specific routes. It's a ballache, its a mammoth task - impossible for clerks sat behind desks but not so with modern computing power.
Future proofing - anticipating the new tidal barrage?
All the obscure but perfectly valid routes together with a long list of negative easements as a result of RJ's previous journeys and subsequent 'discussions' with operators!
Map ER is a concern! It doesn't have the ECML north of Doncaster, despite the title stating otherwise.
They tried that, but then they realised how mammoth it was!:lol:
Look them up and see. If it no longer appears to be a permitted route, you could ask ATOC. But don't forget it would not be lawful for ATOC to make any changes without the permission of the DfT and/or without consulting Passenger Focus. Both DfT and PF are subject to FOI, so if ATOC are not going to co-operate...
PermitToTravel
21 Dec 2011
Groningen
They could make some very simple tweaks for free - replace shortest route (+ 3 miles) with the quickest route, plus up to 10 minutes (or ideally 10%!), at the time the journey is commenced.
Merseysider
Fares Advisor
22 Jan 2014
That'd lead to issues in itself unfortunately. Manchester - Wigan - Liverpool is a permitted route but is up to 30 minutes longer than catching a fast TPE/EMT service via Warrington.
Also, if route validity were dependant upon journey times, it would lead to utter chaos every time the timetables were changed as connections would be missed, new connections would be possible, etc.
Granted, the current system isn't perfect but neither is there an obvious solution to make it perfect.
PermitToTravel
21 Dec 2011
Groningen
I meant that this would happen on top of the existing routing guide, instead of the shortest route rule. The shortest route rule introduces massive loopholes. A quickest route rule would always allow the most reasonable journeys, as a backup / fallback almost.
higthomas
27 Nov 2012
Remember that to have station to station maps would produce over three million maps if my maths is right, which even if they only needed a check would still be a massive task.
furlong
28 Mar 2013
Reading
I disagree - I think people (and computer algorithms) have misinterpreted that rule when they ignore recognised transfers between nearby stations when applying it and then think they can justify ridiculously circuitous routes.
PermitToTravel
21 Dec 2011
Groningen
I agree with your thoughts, but of course the contract leaves it completely undefined what is meant by the shortest route.
It should be codified that the fastest route rule includes transfers, each of fixed time as present, from an official list. And a computer program that can unambiguously say yes or no to any route.
Cheds
29 Feb 2012
So this is the third (at least) version of the routing guide to be in use in well under a year. I don't see how this helps passengers get a 'reliable' train service (since the permissions can and do vary). I also don't see how staff are supposed to keep up, or how it helps to have to revise front line staff training so often. And if training isn't given, that's just more confusion and problems isn't it?
We seem to have route systems and for that matter fare structures which will put people off train travel.
Merseysider
Fares Advisor
22 Jan 2014
You mention staff training needing frequently revising in order to keep up with the ever evolving Routeing Guide.
Unfortunately, I think a certain TOC up North ( ;) ) doesn't bother giving its staff training on the NRG as half of them don't even know what it is. Confusing? Try chaotic.
