XCTurbostar
- Joined
- 13 Sep 2014
- Messages
- 1,882
Can someone tell me what 2D58 (WMR) today was please?
I'm afraid you will have to enlighten me as to what and where the horse landing is pleaseShould return on 4M27 which gets to Crewe around 10:30 best place to see it would be on the Horse landing
It was 172331.Can someone tell me what 2D58 (WMR) today was please?
Many thanksIt was 172331.
Hi All
Can anyone tell me what is on this
Cheers
Train to | Rail Record
Live Train Times for Train to departing on | Rail Recordlive.rail-record.co.uk
Already looking bad for 88005 for me as I see RTT doesn't show this morning's Mossend to Daventry as having left, can anyone please advise if 88005 will be heading south today please? Also is 66430 still on Gresty Bridge? And can anyone please identify the 66 that was in Bow Goods depot this morning at 0620 which I presume worked in on the 6L90 from Grain?
Thanks for that. Sadly I can't get to go past Gresty Bridge as currently everything on that line is cancelled, very frustrating, thwarted by the weather. 66794 in Bow was one of my last seven 66s, 430 would've taken me down to five!!66430 still on Gresty Bridge, not sure about 88005, 6L90 was 66794.
Hi, can someone please let me know what has operated the following services today?
1Z44 08:12 BHM PLY 220002
1V50 09:11 LDS PLY 43207 43378
Thanks
If you are still at Crewe then try walking round to the other end of the DRS depot.Thanks for that. Sadly I can't get to go past Gresty Bridge as currently everything on that line is cancelled, very frustrating, thwarted by the weather. 66794 in Bow was one of my last seven 66s, 430 would've taken me down to five!!
Thanks for the help. I had left Crewe by the time I saw this as with so many cancellations due to the weather I decided to head off and get ahead of all the football supporters filling the limited trains in the evening. I will note this for future reference though.If you are still at Crewe then try walking round to the other end of the DRS depot.
Directions.
Assuming you are walking from the station towards the DRS depot. Turn left out of the station and left again into Gresty Road. Just before the DRS depot turn right (so before going under the railway) onto a residential road - Davenport Road iirc. Keep left into another road and look for a pathway (down hill) back towards the railway. That path goes over a stream and then ends up crossing the railway iirc. Approaching the railway there is a fiald on the left side. There are gaps in the hedge (across a drainage ditch/stream and bank) into the field that is fairly small. Wander around in the field and you will see the locos at the West end of the DRS depot. MUDDY !.
GW01 49101 48101 48102 48103Hi, can I please ask for what set of coaches are going to be with the following:
43097 + 43156
2C33 17:40 Plymouth to Penzance
43357 + 43301
1E75 18:27 Plymouth to Leeds
Also did 43016 + 43122 run an ECS move from Newton Abbot to Plymouth to operate 2C65 after operating 5C65 to Newton Abbot from Laira?
Thanks
Maybe 5C65 was turned round at Newton Abbot and sent straight back to Plymouth. I’m only surmising there thoughHi, can I please ask for what set of coaches are going to be with the following:
43097 + 43156
43357 + 43301
Thanks
None allocated todayMorning
Any allocations for 507003, 507016, 507018, 507019 and 508120 today please?
Thank you
Please someone tell me what's working this and the correct headcode please? Consist as well if possible.
461N 1439 Churchyard Sdgs Tarmac to Hither Green Down Recedit
Also the small consist of
6Y42 1414 Hoo Junction Up Yard to Eastleigh East Yard
Thanks in advance
150202Hi, can I please ask for what is currently operating the following (including the coaching stock if any):
2C26 13:46 Plymouth to Penzance
Thanks
