OLE damage between Grantham and Newark Northgate (3/12/2020)
MotCO
25 Aug 2014
Why can't the Azumas use diesel power? Or is the dangling wire dangerous?
Domh245
6 Apr 2013
nowhere
Only some of the fleet have got full diesel power - the bulk of the fleet only have an emergency single genset, which won't be up to much
Also, perhaps more importantly, it is ill advised to run a train through a work site where you've got workers fixing the knitting, particularly if with the failed cable there are various bits potentially hanging down in the way of the train
Edit: missed the edit you made to your post. I think this later tweet from LNER answers the question:
Mag_seven
1 Sep 2014
here to eternity
Once again the OLE on this particular stretch of the ECML found to be wanting. When are Network Rail going to sort it out?
Clip
28 Jun 2010
Possibly when they get the funding for a full refit. I've no idea how much it costs but I'm sure it would be a lot
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
Is there also an inherent weakness in the ECML's Mk3 cantilevers or something else? From the rain-soaked image they look like the higher speed ones @59CosG95 provided examples of in the MML thread.
That'll be an AWAC problem - specific to Mk3a/Mk3b catenary. The AWAC (Alumo-Weld Aluminium Composite) catenary was one of the driving cost-savers on the Mk3a/Mk3b range (much cheaper than copper), but is very, very susceptible to galvanic corrosion. Mk3c/Mk3d phased it out, but there are still large lengths of AWAC across the network.
This'll probably be a quick splice fix with a pair of preformed dead ends and a double clevis. The cantilevers are absolutely fine - a quick replacement of the steady arm and re-droppering of the affected spans, and Robert's your father's brother.
