All of this discussion on the back of a rumour ......
No, a 4-car 150 formation with an engine out produces 639kW.
Also for accuracy (though helping my argument none ) a 4-car class 150 is around 150 tonnes in weight (150/1s are a bit heavier than 150/2s), while a 4-car Bi-mode class 319 will likely be closer to 160.
Around 21 months ago on the cl.230 thread, I suggested doing a 230-job on 507/508 units of which there were some redundant examples around at that time... having in mind some of the clear limitations of the D-train proposal, and the potential of such a conversion for Preston-Ormskirk, Kirkby-Wigan for instance...
But the suggestion fell on stony ground...
And some things change over time...
And some things stay the same..!
All of this discussion on the back of a rumour ...... I'll believe it when I see it. hock:
The redundant 508s were badly corroded, while the Merseyrail ones aren't still in good nick. With the 319s it's their reliability letting them down rather than the body work.
So would the bi-mode results be called class 219?
I suppose that it would be.
Should ever a class 150 get the bimode treatment then maybe we could see a class 250, as with a 158 what about a ElectricExpress class 258 and if we're really desperate a class 244 EDMU ElectroPacer.
If a 377 or one of the other units in the Electrostar range gets converted to bimodes, it'd probably make sense to number them as class 277's / 27x's.
I thought aluminium diddnt corrode.Would 315s be in a better state perhaps? They've been worked at least as hard as the 507/508s but I imagine the tunnel sections on Merseyside and slightly colder, wetter climate would see the 5xx units deteriorate quicker. Being aluminium I'd expect they'd be lighter than 319s, and having more motored axles would help with acceleration and dealing with leaf-fall or ice.
A Pacer with a pantograph? Good lord. It'd knock the wires down.
I hope that no-one mentions any Class 242 units on this thread...
Nah, they are almost definitely/probably/might/never will be going to be used as stock for an open access service to London Waterloo and LHCS for ATW you need to keep up
Now if you could insert the pantograph coach from another mk3 based EMU then you might be going somewhere!
242s are off the cards. Paul Nuttall has just appeared on the TV saying the Pacers will be used to transport all the Romanians back to Romania in 2020 and they'll be keeping the Pacers unless they choose to ship them back at their own cost - which is unlikely.
well Iran didn't but I class them as a special case.
Iran paid us for the 141s and then took a dislike to all western countries. They obviously thought the west had screwed them over by selling them pretend trains!
No, we're going to be doing it at about 50mph, so we only need enough power to get there at a reasonable rate. Not to run at 100mph. Coincidentally, that's probably going to be about the same amount of power as you need to move a 9-car 800 at 20mph
Crikey, if raw power was what we needed, the 185s wouldn't shut down an engine when running on the branch.
What the Windermere branch needs is a train that can manage an all stations round trip every hour. A Class 185 can just about manage that (even with one engine shut down.) However, I have my doubts that even an all-electric 319 could manage such a schedule. Adding the weight of a diesel engine would make that worse. The main problem is that the low-speed acceleration of a 319 is rather slow - from 0 to 25 mph, even a Class 150 or 156 is faster. Moreover, especially in wet weather, 319s are prone to slipping, and it can get very wet in the Lake District.
Maximum line speed on the 10-mile Windermere branch is 60mph.
I don't think the wires currently cover all the branch platform.
A bi-mode 319 would also suit Preston-Lancaster-Morecambe (55max on the 2-mile branch, plus 2 miles on the main line).
Presumably they would have to switch modes while stationary.
Would also suit Barrow well. That entire mini-network of former NorthWest Express middle-distance services is absolutely textbook perfect for bi-mode operation.
Depending on fuel capacity/range, Leeds-Morecambe would be ideal too.
The speculative bubble has grown apace, At what point can we expect some official announcement.
