Railway General Knowledge.
EbbwJunction1
25 Mar 2010
Ah, thank you .. guesses are sometimes right after all!
What have the following locos have in common, other than all having been preserved from Barry Scrapyard?
BR Standard 9F 2-20-0 No. 92207
GWR 4575 Class 2-6-2T No. 4588
LMS Stanier 8F 2-8-0 No. 48151
SR Maunsell S15 4-6-0 No. 30828
Thanks.
Cowley
15 Apr 2016
Devon
Thanks.
Is it something like they’ve all carried names since being preserved?
Gloster
4 Sep 2020
Up the creek
Thanks.
Now, a 2-20-0 I would like to see!
Pulled the first train on a preserved line, or part of one?
EbbwJunction1
25 Mar 2010
You have it, well done ... these are the names:
BR Standard 9F 2-10-0 No. 92207 "Morning Star"
GWR 4575 Class 2-6-2T No. 4588 "Trojan"
LMS Stanier 8F 2-8-0 No. 48151 "Gauge O Guild"
SR Maunsell S15 4-6-0 No. 30828 "Harry A Firth"
Your turn in the Pattern Shop, sir!
Yes, that would be interesting, wouldn't it ... ? Sorry, that's not right - see above.
The first of their class to run in preservation?
Sorry, that's also not right - see above.
Cowley
15 Apr 2016
Devon
Ah brilliant. :)
Also along preservation lines. What link do these locomotives share:
Class 15 D8233
Class 24 24054
Class 50 50031 Hood
Class 35 D7017
Cowley
15 Apr 2016
Devon
Do they all carry a livery they never wore in service?
Yes very good!
In order they’ve been shopped thusly:
Class 15 D8233 - Original Railfreight
Class 24 24054 - Loadhaul
Class 50 50031 Hood - Intercity Swallow
Class 35 D7017 - Civil Engineering grey and yellow (Dutch)
10% off Dulux voucher is yours…
xotGD
4 Feb 2017
Next up...
What is the connection between the following:
1, 7, 22, 50, 119, 122, 401
Cowley
15 Apr 2016
Devon
Next up...
I think it might be pioneers?
1 - 44001
7 - not sure. D5300 maybe?
22 - D9000
50 - D400
119 - D6700
122 - D200
401 - D1500
Gloster
4 Sep 2020
Up the creek
Is it locos moving into gaps in tje series when renumbeted for TOPS:
D9000 became 55022
D400 became 50050
D6700 became 37119
D200 became 40122
D1500 became 47401
Not sure about the others, although 1 did become 44001. Unless 7 was the Vale of Rheidol loco which was ?
xotGD
4 Feb 2017
1 - 44001
22 - D9000
50 - D400
119 - D6700
122 - D200
401 - D1500
D9000 became 55022
D400 became 50050
D6700 became 37119
D200 became 40122
D1500 became 47401
Both correct, but @Cowley got there first. So back over to you.
Yes , 26007 was D5300, and 50 is also applicable to D8000 / 20050, btw.
Cowley
15 Apr 2016
Devon
Ah. I’m pleased that I got the 26. I was furiously typing those out before someone else got there first. :lol:
I’m going to pass it on to @Gloster because I’ll be a bit busy for a few hours.
Gloster
4 Sep 2020
Up the creek
A fairly simple one. What was the main difference between the GWR 4800 and 5800 classes introduced in 1932 and 1933?
Gloster
4 Sep 2020
Up the creek
Autocoach provision? (Absent on the latter)
Correct. The 4800 Class 0-4-2T were fitted to work push-pull with autocoaches, while the otherwise almost identical 5800 lacked this feature. The 4800s were renumbered to 14XX in 1946.
To you the driver’s cab.
xotGD
4 Feb 2017
Numbers didn't exist under British Rail.
Locos received these numbers in preservation.
DerekC
26 Oct 2015
Hampshire (nearly a Hog)
To add a bit more - 90733 would be an ex-WD 2-8-0 and 32643 a Terrier, I think. So the WD came back from wherever it had been working since WWII and the Terrier was perhaps an ex-Departmental loco?
@xotGD gets the biscuit if right.
