Recent Northern Trainee Driver Advertisement - Leeds
2 Dec 2020
No, 2 strikes and you’re out. The tests are there to assess your natural aptitude for learning and doing the job, which is unlikely to change over time.
Maybe you’re correct. However, there is quite a buzz around Leeds mess room lately regarding the above for guards who have failed the psychometrics previously.
Who knows
LCC106
16 Nov 2011
A lot gets said in mess rooms that should be taken with a VERY BIG pinch of salt.
16.19
2 Dec 2020
Indeed. All I’m saying is don’t be too shocked when you start seeing some quite big changes in the near future.
Peace
LCC106
16 Nov 2011
Section 2.7.2 of the latest version of RSSB Rail Industry Standards for Train Driver Selection states that someone who has failed more than once will not be reconsidered unless there are extenuating and well documented circumstances. You need a login to access the document.
Spincity
23 Nov 2019
What date is this latest version. My colleague sat a retest only this week and he was definitely told that it’s 2 failed attempts at the assessment?. It’s always been 2 goes at the process from what is on this and other forums so can see it’s suddenly changed
Sheridan
11 Jan 2012
The document quoted above doesn’t contradict that, it’s just worded slightly differently.
LCC106
16 Nov 2011
Correct. If you’ve failed more than once then you’ve failed twice, like I said in reference to section 2.7.2. (The wording I used about failing more than once is lifted from the document). You can, of course, sit and pass the tests as many times as you wish, but once you fail twice that is it.
Driver068
31 May 2017
Tests are done by the OPC. Its industry wide assessments not TOCs/FOCs. You carry out the tests set by them with certain companies wanting there own pass rate. Regardless of if a TOC/FOC sets up their own training establishment the criteria is set by them. For the 2 set rule to be reset, the OPC would have to amend or change their tests as 4/5 years ago where i believe peoples attempts were reset.
Unless this has changed please post response.
Also what makes you believe that this is the case with Northern???
Stigy
6 Nov 2009
As has been said, the 2 strikes rule will still apply here, regardless of whether a TOC takes the tests in-house. The only way they will be reset is if there’s another big shake up with the assessments with the RSSB as happened back in 2013. In which case, any previous attempts will be wiped.
LokiB
3 Feb 2020
The vacancy has being closed. Guessing they have filled the role with internals.
JRE
11 Nov 2016
Just got an email saying York has been pulled ?
Hello both.
Had you sat the interview and OPC assessment centre before being told that the vacancy was no longer available, or had you only gone as far as submitting an application for the role?
Cassy j
15 Jun 2019
Hello both.
Just application for me
16.19
2 Dec 2020
Absolutely correct.
juniorwilks11
16 Mar 2021
Just wondering if anyone has heard back from the September advertisement for trainee drivers at Leeds yet? Had the two emails late September but nothing since:
Dear $¥€$¥
Thank you again for your application for the above role.
Your application is now under consideration and is being screened.
Please bear with us as we work through all of the applications that we received. We will be in contact again with an update for you as soon as we have one. Rest assured, we will be in touch either way, to advise if your application has been progressed to the next stage in the recruitment process.
Kind regards
The Northern Recruitment Team​
Lumpa6259 - how did you get on with this application?
I’ve been reading the Manchester trainee driver roles have now been pulled, looking ominous for this Leeds driver recruitment. Thanks.
Mattydo
27 Mar 2020
I’d check your application portal. Leeds and York were both pulled I believe.
juniorwilks11
16 Mar 2021
Thanks for your post. No, still awaiting course start dates last updated from HR end of Feb. But starting to think these will be pulled at some point, or 9 months will elapse.
skyhigh
14 Sep 2014
Have you done the psychometrics? I take it you're an external candidate?
Mattydo
27 Mar 2020
Okay I’m assuming this is from a much earlier recruitment or qualified recruitment drive ?
The trainee Leeds role from around October 20 was definitely withdrawn.
skyhigh
14 Sep 2014
It definitely wasn't fully cancelled. I know of several internal applicants from that round who are waiting for start dates.
Mattydo
27 Mar 2020
Indeed, the email that went out stated that “the position is no longer available and has been closed” so we can assume it was filled with internal candidates perhaps?
skyhigh
14 Sep 2014
I suspect that is the case, yes.
Mattydo
27 Mar 2020
Thanks both of you for your info. Yes I am external and had passed everything, will just have to keep waiting for the right opportunity I suppose. All the best.
If you’d done everything including mmi and dmi you might still be on their books as it were. If a suitable vacancy comes up you’ll more than likely get an email out of the blue.
It really is a case of nothing being certain until you’ve done the medical and have an unconditional offer in your inbox. Good luck!
