Aylesbury to Calvert/Claydon is token working. The token machine at the southern end used to be in Aylesbury station, but when the new Aylesbury Vale Parkway station was built, the token machine(s) were moved to the Aylesbury North loop. There's a machine at the north end of the loop for drivers to collect the token, then a machine at the south end to return the token to - and each week, the local S&T staff personnel exchange the full cassette of tokens from one machine with an empty cassette from the other.
Bodmin & Wenford: Annetts keys used as tokens; red for the Bodmin General to Bodmin Parkway line; blue for Bodmin General to Boscarne Junction. Different key configuration, so the keys can't fit in each other's machines. The keys are then used to release the ground frames at the remote terminii for the loco run-rounds. Also, the red key unlocks the Walker Lines ground frame on the Parkway line. The paint is rubbing off the keys due to how much they've been used since the signalling was made operational in 2011, so it's probably just as well that the line names are etched deeply into the key body.
