Hi there could you elaborate on the concentration test please?You will take two tests. One is a comprehension test, read the passage and select the correct answer from below, multiple choice and quite easy just take your time and read it properly. The other is a concentration test, it will be lines of symbols. You will be asked to go through them one line at a time and score out a predetermined one. You will then go on and score out a predetermined one and the first one of every line, but only on that line.
Read over your practice material, I also advise to try find some similar tests online and give them a go.
Hope this helps and best of luck.
Its a test of concentration and the ability to follow instructions. You'll be asked to mark/score off a certain shape or symbol in each line on a page full of different shapes.Hi there could you elaborate on the concentration test please?
I'd we're talking about a SCAAT, online or paper, they both seem to be exactly the same. You get three sections, with three pages per section. You are told when to go to the next page if on paper, or the website shows the next "block" once it is time if done online. The test last roughly 45 minutes if memory serves right.Do you remember how many questions you had to answer and what was the time limit given?
Was the concentration test, paper based or computer based and how many sheets and what was the time limit?
Many thanks and Happy New Year!
