Station Names on Platform Lights
The exile
31 Mar 2010
Somerset
There was a time when platform lights incorporating the station name were a common sight - at least in certain areas. (I particularly associate them with the Kings Cross outer suburban area - but obviously they weren't confined to there!) There are clearly one or two survivors (like this one, assuming it's still there - and I came across two preserved as a "feature" at Braintree the other week), but when did they cease to be "common"? Does anyone know what the last "full survivor" was - and when? (ie - the last station to feature a full set as main platform lighting)
SargeNpton
19 Nov 2018
Used to be seen across the whole country. It was perhaps moving to sectors from regions when they ceased to be fitted. My memory of Network SouthEast doing a wholesale replacement with red lampposts was when I started to notice that they were getting less and less on the routes I used on a regular basis.
These mostly, perhaps totally, pre-date the corporate identity of the mid-60s. In the example above the typeface is Gill Sans, or something very similar, as used on the "sausage" nameboards. I can't think of any station lamps that had names on using the "Rail Alphabet" that came in at that time, though there may have been some and I suspect I'm about to be inundated with postings about them!
The exile
31 Mar 2010
Somerset
I do remember some including lower case letters (so presumably Rail Alphabet) but no idea where. As with most things that were once common, you tend not to notice them until they are not there (however illogical that may sound).
I would imagine that their demise will also have had quite a lot to do with improvements in lighting technology - I'm sure I remember they were good at collecting water, which doesn't usually go very well with electricity
61653 HTAFC
18 Dec 2012
Another planet...
There were some at Leeds pre-2001 rebuild with "LEEDS CITY" on them. I have some vague memory that one survived for a short time after the refurbishment, but that may be a false memory.
alistairlees
29 Dec 2016
I’m sure there were also illuminated running in boards at places like York that let off a lot of light (even if their primary purpose was not actually lighting).
Trackman
28 Feb 2013
Lewisham
There's still one at Manchester Oxford road, it says 'Oxford road' don't think it lights up though!
The exile
31 Mar 2010
Somerset
From what I remember the old ones (Enamel in Regional colours - that went with the double sausage totems) were externally illuminated (sort of railway equivalent of anglepoise lamps on the top). I remember being struck (not literally) by the huge one at West Ruislip in about 1987.
Intercity introduced internally illuminated running in boards in the late 1980s, iirc. - guess there are plenty of them still around.
alistairlees
29 Dec 2016
Yes I’m thinking of the internally illuminated white ones with black lettering. 1970s or 1980s
The ones at Diss were being used as platform flower beds up until a few years ago.
We had them on the Southern Region as well.
Aictos
28 Apr 2009
Just to confirm that you are right in saying that the font Gills Sans was used as it was previously used by the LNER and then upon nationalisation was used by British Railways.
Rail Alphabet as a font wasn't used at all for the station lamps.
There were some very large internally illuminated running in boards with Rail Alphabet names, dating from sometime in the 70s I think, some on platforms and some on signalboxes. I think the West Coast Main Line had some but I wouldn't like to try to remember where.
The Intercity ones were later and smaller. Some of them were later re-branded after privatisation and there may still be a few around.
Yep, pretty much all the former Intercity routes still have stations with the internally illuminated boards. Some, as at Coventry, still have the old Intercity Swallow logo (or remnants thereof) on one of the pillars:
I always think the lit up InterCity running in boards look particularly modern.
CarltonA
22 Apr 2012
Thames Valley
I'm not sure it can be called a "full survivor" but Stratford Upon Avon has several of these lights. They have been retained after a recent refurbishment of the main building. I don't think they are on the island as this has old GWR style lanterns (not sure if those are repro' or original).
tom1649
5 Jul 2010
The last time I was at Chester there were some 1960s survivors with the station name on. They were under the canopy on the disused bay platform next to platform 1.
I've definitely seen at least one at another station within the last 3 years. I remember being surprised to see it lit up!
Dstock7080
17 Feb 2010
West London
until it was re-lit in the early-2000s EAST HAM still had one on the eastbound platform with green lettering, just beyond the passenger environment.
Ken H
11 Nov 2018
N Yorks
the type in the OP's pic were everywhere. Think they were standard kit. There were ones on concrete posts, and ones on brackets affixed to awnings or platform buildings.
Some were obtusely set with the lamp at right angles to the platforms. Helpful for alighting passengers!
Pretty rubbish lights too, but probably as good as it was in the 60's. Probably a maintence liability, as they would need regular cleaning.
I assume the design was passed by the BR design panel.
Welby
12 Dec 2014
Yes I have seen the ones at Chester, they look good in a bunch. Also the ones at Thorpe-Le-Soken. Back in the 70'd they had them at Folkestone Central and 2 of them on (the then) down-platform were blank, but you could clearly see Leeds City where they had not been cleaned.
MadMac
13 Jun 2008
Moorpark, CA
Glasgow Queen Street High Level had lower case.
32475
2 Nov 2019
Sandwich
Glossop Central had an illuminated platform sign (in the style of post no. 1) on brackets over the front entrance. I think it stayed in situ until somewhere around 2010.
Parallel
9 Dec 2013
There is definitely one on Platform 4, and it still works/is maintained as I saw it on a couple of weeks ago - It hangs down where the lift is, if I remember correctly (towards the Piccadilly end of the platform). I can't remember if they are also by the lift on Platforms 3/2 as well though.
I think there are also some on the disused ends of the platforms on one of the North Wales Coast stations - Possibly Rhyl? Can't remember if they actually have the station name on them though.
Oxford Road being listed as an outstanding example of 60s station architecture may account for their survival here. Are there any at similarly protected stations like Coventry?
colchesterken
When the Liv st inner suburban was rebuilt in the 40s the station name was printed in the strip light lampshades and back lit by the strip light
dont know what happened to them, I emigrated up here
NorthBritish
25 Aug 2020
Ponteland
Here's a couple of the Chester lightboxes - there is a long line of them running along the disused platform - a nice blast from the past and long may they remain!
Committee man
21 Jun 2014
Chester has, I think 23 in total, all on the disused (to passenger trains) platform 1.
They all look well maintained, not seen them after dark so not sure if they all work but presumably they do.
There are 3 at Manchester Oxford Road, all attached to the lift shaft towers at the Piccadilly end of the platforms.
