SWR Cancels Saturday Salisbury-Waterloo & Bristol service
This is only going to push more customers onto GWR s Portsmouth services.
To be fair though, if it actually caused problems on the Portsmouth services it would improve the business case to do something about it and the SWR services wouldn't be blocking the paths.
I doubt that the demand is enough to justify any enhancement of Bristol to Salisbury services in practice.
HamworthyGoods
15 Jan 2019
Yes that’s the intention but these trains have all been strengthened in formation in recent years so don’t have the capacity issues they used to.
Techniquest
19 Jun 2005
Nowhere Heath
Strongly beg to differ.
As do I. Yes it is often better than it used to be, based on my limited experience of the route, but it is certainly not wonderful on the Cardiff to Portsmouth route.
I last used said route between Newport and Salisbury in early July 2021, I don't have a need to go that way too often and it's a rather expensive journey to do. Solo 166 in both directions, travelling in the middle of the day so bang in the middle of the off-peak.
It certainly wasn't that much nicer than the days of 2 car 158s, especially on the way back. Bearing in mind this was still before the leisure travel market had really come back as much as it has now, with current passenger numbers the trains would have been difficult to board at all.
In short, I'm in no rush to use the Cardiff to Portsmouth route any time soon, and the capacity increase is not as big as some people say it is. I would almost go as far as to say I'd prefer to do Hereford to Southampton via Oxford and Basingstoke!
The exile
31 Mar 2010
Somerset
Pre COVID the capacity increases on Portsmouth - Cardiff certainly made a difference, but those units now seem conspicuous by their absence. Removal of the early morning SWR Salisbury - Bristol has left what is for that time of day a very large hole in the timetable. That train was well used by school pupils - who are definitely not wfh!
Parallel
9 Dec 2013
It's the approx 22:25 Bristol - Salisbury service that is a big loss IMO. Usually relatively well loaded being the last train back from Bristol/Bath down to Salisbury, running at the usual time the Cardiffs to Portsmouths run.
The direct Waterloo services from Bradford-on-Avon, Trowbridge, Westbury and Warminster are relatively popular from my observation. There are also some excellent deals to be had with advance fares. I've paid about £6 before from Trowbridge to Waterloo or about £9-11 first class. It's a shame that GWR/SWR couldn't come to some sort of joint arrangement of running the service together, a bit like Northern and Scotrail on some services via Carlisle. I'm not sure how well loaded the journeys are from Yeovil Junction to Waterloo/Salisbury via Frome are but they seem to have taken priority, maybe due to being more poorly served. SWR regularly seem to chuck a 2 car 158 on Bristol services too these days, which seemed very rare under SWT.
The Cardiff to Portsmouth route is very popular. Although it's rare to see the trains so rammed that you cannot board these days when they run as 5 coaches, certainly on weekends it can be challenging to find a seat.
TEW
16 May 2008
The services via Frome also serve the purpose of retaining route knowledge to enable Waterloo to Exeter services via Westbury. If they were withdrawn there would still be a requirement to run ECS moves that way so there's not so much potential to save money.
HamworthyGoods
15 Jan 2019
It’s been mentioned a few times in other posts but from the Dec 21 timetable the last journey opportunities are being covered:
On Monday to Fridays the 21.30 Cardiff to Bristol is extended to Frome departing Bristol TM at 22.25 with a connection at Westbury for Salisbury.
This actually provides a later service from South Wales towards Salisbury as the 21.30 currently doesn’t connect at Bristol with the SWR service.
On Saturdays the current 22.09 Bristol to Westbury is re-timed later to 22.15 again with a connection at Westbury for Salisbury.
baza585
1 Aug 2010
Frankly the SWT incursion into GW land was mainly an ORCATs raid by Stagecoach on a First franchise.
It is not necessary therefore in the DfT view it should cease, and the resources used to bolster existing services in the area which are under pressure.
Logically the Salisbury 6 services should be run by commuter stock (150s or Turbos) and the 158s used to bolster key peak services on Portsmouth-Cardiff line.
Awaits incoming......
vikingdriver
11 Mar 2010
Do the Devon metro plans on to SWR land need knocking on their head too?
HamworthyGoods
15 Jan 2019
You could conceivably argue that actually west of Axminster the local service fits far better being resourced from Exeter than Salisbury.
Having to ‘pass’ traincrew down from Salisbury to Exeter to work the evening Axminster peak working meant it was incredibly liable to cancellation.
The local service fitting with the Exeter local operator and allowing the longer distance service from Waterloo to be sped up is far more logical.
Back in the run up to the 2017 franchise, there was a spreadsheet version of the train service specification published, and the Salisbury-Bristol service group was separated out with a caveat that it was only required until 2018. Suggests that withdrawal was already on the DfT back burner…
DorkingMain
25 Aug 2020
London, UK
The Romsey services are definitely not suited to 158s, a lot of short-hop journeys made with people piling in and out of narrow carriage-end doorways. Longest journey anyone is likely to make on there is Salisbury to Southampton / Eastleigh, which is around an hour.
As far as I can tell, there's 3 westbound and 3 eastbound trains being withdrawn here -
The 1352 ex-SAL, which runs 10 mins behind a GWR service at 1342
The 1801 ex-SAL, which runs 19 mins behind a GWR service at 1742, and with a Westbury SWR service at 1823 after it
The 2057 ex-SAL, which runs 15 mins behind a GWR service at 2042
The 1550 ex-BRI, which seems to create the biggest gap - there's a Westbury service at 1544 but that has no onward connections, or a GWR to Salisbury at 1522 / 1622.
The 1935 ex-BRI, which runs 13 mins behind a GWR service at 1923
The 2225 ex-BRI - it looks like a Cardiff - Bristol service is being extended to Frome to make connections with an ex-Yeovil service for this, as mentioned above.
anthony263
19 Aug 2008
South Wales
Dont forget though the service was handy for customers travelling from Bristol, Keynsham Bath, Trowbridge a direct service to south London.
This service has been going for years,indeed even wales and borders ran some services to London waterloo and these were always popular according to staff who worked them.
I think it needs to be re looked at and the 0850 from Bristol TM should be reinstated at the least as passenger focus have said themselves deferring the withdrawal till December 2022 will allow us to see how passengers numbers recover in post covid world
HamworthyGoods
15 Jan 2019
The current situation that has led to the early withdrawal of some services shows the traincrew difficulties experienced in running the current service let alone adding additional services in - what SWR diesel services would you propose reducing instead to facilitate the extra trains you suggest?
Removing trains on the Salisbury to Bristol corridor where there are alternatives seems a better choice than removing trains between Salisbury and Exeter where there is no alternatives.
Drivers sadly don’t grow on trees and SWR’s Salisbury depot is incredibly short staffed but is the key depot for diesel services.
30907
No doubt, but that's a pretty niche market.
Assuming the half-hourly Salisbury-Waterloo service is reinstated in December (which I would consider a better use of scarce resources) it is only travellers to/via Clapham Jn who are seriously inconvenienced - everyone else gets a comfortable hourly connection at Salisbury (which is cross-platform eastbound).
DorkingMain
25 Aug 2020
London, UK
The connections at Westbury are better towards London than trudging up the SWML anyway.
Parallel
9 Dec 2013
Westbury is local to me and I’d argue is not a particularly friendly station to interchange at. The trains to London are infrequent with some tight interchange times, I’ve had a couple of occasions where I’ve had to spend close to two hours there because of delays on the regional lines and connections on the intercity services not being maintained plus usually many platform alterations. As a regular user, I think Westbury or Trowbridge to London is usually better via Melksham and Swindon if there is a Transwilts service running at that time.
Salisbury is definitely another useful interchange station, because of the usual 30 minute frequency and because of the connections to the rest of the SWR network on services from there. It means you can avoid the underground or the slow Reading - Waterloo route.
spyinthesky
17 Aug 2021
Bulford
I always had the problem at Westbury connecting to the South West whilst planning an ALR. Always either a tight connection or a long wait.
AlbertBeale
16 Jun 2019
There's a petition opposing the ending of the Waterloo-Salisbury-Bath-Bristol though service. I've found it useful in the past to have through trains linking stations on the London-Salisbury route with ones on the Salisbury-Bath route. I've used that service one in a while over many years.
Seems it has now become political with the Chippenham MP (whose constituency covers West Wiltshire, and people using stations like Bradford-on-Avon) from losing their direct trains to Waterloo
(ignore the irrelevant picture of a 701, presumably couldn’t find stock photo of a 159)
Probably usual trying to look good, Michelle Donnelly MP doesn’t have best record at rail improvements for her constituents, no electric trains at Chippenham, no reopened station at Corsham etc.
miklcct
2 May 2021
Cricklewood
I don't see the value of having such through service. The primary service between Bristol and Salisbury is the GWR Cardiff - Southampton service, which can connect to Exeter - Waterloo service at Salisbury and Weymouth - Waterloo service at Southampton. A timetable coordination between the lines is enough to replace the through service.
AIUI the problem is the timetable coordination is usually for the Exeter to Southampton flow, and vice versa. You can’t have connections for both changing/connecting flows unless one of the services sits in Salisbury for maybe 10 minutes, blocking a platform
Then connections at Southampton into Waterloo trains are of little use if that isnt a permitted route. Salisbury to Waterloo via Southampton isn’t permitted nowadays, although I think it might have been a few years ago that we had a thread about its removal.
Kite159
27 Jan 2014
West of Andover
The current GWR services between Cardiff & Portsmouth connects well with the Salisbury - Basingstoke local SWR services. Although with those cut back to Basingstoke anybody from London wanting Warminster & stations beyond trying to save money with a "route Salisbury/Warminster" fare will have a longer wait at Salisbury [unless they fancy sitting at Basingstoke for 30 minutes as the last connection from London to the Salisbury local is the Exeter service, effectively making London - Salisbury (and Andover) 1tph.
Deepgreen
12 Jun 2013
Betchworth, Surrey
Yes - it is better, but by no means fixed. On top of that, GWR has announced the internal refurbishment of their Turbos this autumn and winter, presumably meaning at least one unit out of service at any one time.
The Bristol service that was going to be removed going forward in the next timetable (or 2022)?
No, going backwards.
Horizon22
Jobs & Careers
8 Sep 2019
Any service cuts and everyone and their dog gets involved. Despite the fact that in the broader picture it can actually be beneficial to more passengers if the rolling stock can be utilised better elsewhere or if a service is already lightly used. Not saying this particular change is right or wrong, but local user groups (understandably) rarely look at the bigger picture
I have no issue with people aiming to protect well patronised services and campaigning for services that have been removed temporarily for "Covid reasons" or are still not back (or not returning in December) or looking to build service improvements like new stations and the like, but other times it seems that the railway can never adapt accordingly to changes without one group being up in arms. Timetable change always brings issues because what one local group wants might competely negatively affect another user group.
AndyPJG
29 Jun 2012
For info:-
BBC News item
Bristol to Waterloo train: Campaigners fight to save service​
Published2 hours ago
Share
Arterio train
During the pandemic, the government stepped in to underwrite the cost of railways amid fears that rail companies would fold
Several campaign groups are joining forces to fight plans to scrap direct trains between Bristol and Waterloo.
South Western Railway said axing the route would avoid duplication of services with Great Western Railway.
Graham Ellis, who has organised a meeting about the change, claimed the decision was made "on poor and incorrect data".
An online petition opposing the end to the service on 12 December has received nearly 3,000 signatures.
Great Western Railway currently provides services from Bristol to London Paddington.
'Well-used service'​
Claire Mann, managing director of South Western Railway, said: "We have sought to identify areas of duplication across the network where the removal of services would reduce the burden on the taxpayer.
"We are confident the withdrawal of our services will not materially impact key flows of commuter or school traffic and agreed with the Department for Transport to realise the cost savings as soon as possible."
Mr Ellis added: "This is a well-used service. It provides the only through trains from London to Trowbridge, Bradford-on-Avon, Oldfield Park and Keynsham and from Bristol and Bath to south London.
"There has been no thought to people travelling for business, leisure, to see family or reach doctors appointments or court."
He said on the new timetable people will have to switch trains in Salisbury and face a 59 minute change, which "is not a 'connection'."
"Even Transport Focus, the Department for Transport's own passenger watchdog, has suggested that the service should be retained until properly consulted and appropriate alternatives provided," he said.
A meeting will be held in Trowbridge on Wednesday and streamed on Zoom.
Jim
11 Jun 2005
Wick
I don’t think the service reduction actually removes any direct services to London but obviously reduces frequency:
Keynsham still has some direct IET services
Bath and Westbury have regular IET services to London
Bradford on Avon and Trowbridge retain the morning IET service to London
Warminster still has the SWR services which have run via Frome and continue to London
I'd hardly find an 05x service from Bradford/Trowbridge to London at full anytime fares a comparison to the good value direct services daytime for leisure travellers.
