Bham International? How did they load the cars?
Side loaded off the platform adjacent to the surface car park.
Although invited by Sir Nigel to travel on what became the world record run, C J Allen was otherwise engaged that day, so was unable to be present on that famous journey.Cecil J Allen, inveterate longstanding old school train timer right through from the pre-grouping era to the 1970s (he was on board Mallard's 126mph), and long used to steam and then Class 40 performance out of Euston, took his first run in 1966 in the week the mainstream Liverpool/Manchester service started. His heading in his Modern Railways column was "93mph at Willesden - Going Down!". He felt it was like something from a parallel universe.
Not all Motorail services offered that, although I think most did, but some were Sleeping Cars only which and some of these on the longer journeys included a TSO in the formation so that passengers had somewhere to sit - and perhaps to consume tray meals - until bed time .Interesting to read - so even if overnight on motorail you could choose (subject to payment) seated carriages or sleepers. I was certainly unaware of that. Thanks for posting it.
First time I ever saw or was hauled by an electric was an 84 (001 I think) in 1976 when I travelled from Bristol to Manchester for my brother's wedding.It’s not surprising that Class 84s made rare appearances on top link InterCity services
Thanks - interesting to read about that.Not all Motorail services offered that, although I think most did, but some were Sleeping Cars only which and some of these on the longer journeys included a TSO in the formation so that passengers had somewhere to sit - and perhaps to consume tray meals - until bed time .
I had an idea there were some where the same set worked one way overnight and the other way daytime (with the sleepers out of use) but making efficient use of the car carriers but I am struggling to trace such a train.
In this Andrew Martin claims CJ A declined because it was a sunday, implication it was faith related choice.Although invited by Sir Nigel to travel on what became the world record run, C J Allen was otherwise engaged that day, so was unable to be present on that famous journey.
if you use the 'edit' function you can cut and paste as (and if) you feel necessary. It took me a few tries to work this one out!The forum has automerged my last three posts, jumbling three distinct comments. Hope they can still be made sense of!
Afraid I can't help on that element, unless you delete and reload in the required locations. Others may know a better way?Thanks for the tip. I can see the desire for forum tidiness, but when you are replying to distinct comments and the responses get thrown together, it looks like you're all over the place.
Pictures are still all at the end though, can't be separated out though?
Then I would suggest quoting a post you want to reply to, add your reply. Then quote the next person and add the reply to that and so on.Thanks for the tip. I can see the desire for forum tidiness, but when you are replying to distinct comments and the responses get thrown together, it looks like you're all over the place.
Expect the oil in the transformer overheated and ignited. Seems to happen more frequently as locos get older and maintenance ignored. Look at the French 25500s, quite a few went the same way in last couple of years as SNCF got a few more years out of them as cheaply as possible. Must admit I am speculating here.Does anyone recognise this?
What happened here?
Nothing unusual for that class, that's what happened there!Does anyone recognise this?
What happened here?
What happened here?
85001 was damaged by fire on the 13th October 1985 whilst in charge of the 16:15 Euston-Manchester service. Repair costs were deemed to high and it was withdrawn four days later finally succumbing to the cutters torch at MC Metals, Glasgow, in April 1989.
85s usually seemed to be the better class among the 'roarers', unlike the 84s which seemed to go bang fairly regularly.I've found a photo of a tarpaulin-covered 85001 under tow on Flickr, is it the same loco?
https://www.flickr.com/photos/21611052@N02/6123392182
Caption:
That sort of fire happened more frequently?Expect the oil in the transformer overheated and ignited. Seems to happen more frequently as locos get older and maintenance ignored.
What happened here?
That has to be a good contender! slightly OT but the caption mentions stopped on the down slow, doesn’t that track it’s sat on look just a little bit below par for a piece of WCML slow line or is it just my eyes?I've found a photo of a tarpaulin-covered 85001 under tow on Flickr, is it the same loco?
Caption:
I hate it when that happens!Oh dear, someone left the toast in too long...
It's also jointed, I thought part of the WCML electrification works also saw off the last of the jointed stuff on the mainlineThat has to be a good contender! slightly OT but the caption mentions stopped on the down slow, doesn’t that track it’s sat on look just a little bit below par for a piece of WCML slow line or is it just my eyes?
I did think "Wolverton" when I saw it, attached is a track plan dating from around 1966 (put it this way, from before Hanslope Junction for sure).If it's at Wolverton, it must be in the sidings on the up side of the slow lines - these gave access to the stone terminal. The up slow must be the track with concrete sleepers on the extreme left.
But my memory is that there was only one track on the stone siding, and I don't recognise the background as looking like Wolverton.
Ah, good, thank you. That's just about where I'd got to also, so the number of lines and type of sleepers looks about right.Thanks for that. My memory of the works sidings was that they were between the down slow and up fast, but the map corrects me they were between the down and up slow. So the down slow is the concrete sleepered track on the left and the up slow the most distant track.
behind the Shark on the main line. Maybe the guard is unhappy; also the back brake hose doesn't seem to be on the stop...
What happened here?
