Xenophon PCDGS
Bow Brickhill
@Whistler40145 is correct in saying that London St Pancras is treated as only one station, whether the Low Level or High Level, and any specification of which level is used should be ignored, and moves may be made that use either part of the station from a post that specifies.Thank you—I sometimes see it specified that the LL platforms are used if the route comes up from DC land though.
North Wembley is a win.This does not proclaim that it is a win, but if confirmed that the above is indeed a win, the next leg should start at Tolworth.
Motspur Park@Whistler40145 is correct in saying that London St Pancras is treated as only one station, whether the Low Level or High Level, and any specification of which level is used should be ignored, and moves may be made that use either part of the station from a post that specifies.
Malden Manor
Thank you for the clarification; further to the original question, can complexes like Bank/Monument (did it come up when we allowed LUL here?) or Hackney Central/Downs be considered the same station?@Whistler40145 is correct in saying that London St Pancras is treated as only one station, whether the Low Level or High Level, and any specification of which level is used should be ignored, and moves may be made that use either part of the station from a post that specifies.
Malden Manor
Hackney Central and Hackney Downs are counted as separate stations. I'm not aware of LU being allowed in this game (at least it hasn't in my time here), so there has never been an occasion on which that has needed to be decided, though I would assume they would be two separate stations.Thank you for the clarification; further to the original question, can complexes like Bank/Monument (did it come up when we allowed LUL here?) or Hackney Central/Downs be considered the same station?
Worcester ParkMotspur Park
