TPE Nova 3 (Class 68 + Mk5s) updates and withdrawal from service
43 302
25 Oct 2019
68028 "Lord President" + TP09
1F48 0554 MCV - LIV
1E25 0654 LIV - SCA
1T60 0957 SCA - YRK
1T29 1100 YRK - SCA
1F66 1234 SCA - LIV
1E45 1654 LIV - SCA
68032 "Destroyer" + TP12
1F54 0634 SCA - LIV
1E35 1154 LIV - SCA
1F72 1534 SCA - LIV
1E51 1954 LIV - SCA
68034 + TP11
1F56 0734 SCA - MCV
5H56 1001 MCV - Longsight
5E43 15 0 Longsight - MCV
1E43 1631 MCV - SCA
1P92 1934 SCA - MIA
5H90 2243 MIA - Longsight
68034s last day for TPE, getting ripped tonight for 68031
25 Oct 2019
68032 "Destroyer" + TP12 - Loco East End
1T60 0932 SCA to YRK
1T29 1100 YRK to SCA
1F66 1234 SCA to LIV
1E51 1952 LIV to SCA
68028 "Lord President" + TP09 - Loco East End
9M05 0922 MCV to LIV
1E35 1152 LIV to SCA
1T72 1534 SCA to YRK
1T43 1800 YRK to SCA
1P92 1934 SCA to MIA
Jamesrob637
12 Aug 2016
19/7/20
Are there only ever two on Sundays even under normal circumstances?
CW2
7 May 2020
Crewe
The earlier COVID Sunday timetable had 4 diagrams on Liverpool - Scarborough, 2 68s and 2 185s. The updated timetable from a few weekends ago reinstated the Manchester - Redcar services at the expense of the Scarboroughs, so now there are only 3 diagrams, with a lot less content. The two 68 diagrams are timed in such a way that bashing them becomes very difficult on a Sunday.
Jamesrob637
12 Aug 2016
Thanks for the clarification. I can't remember the last time I used the trains on a Sunday. Maybe once last year but certainly not this year prior to lockdown. They're just too patchy even under normal circumstances.
J-P_L
7 Sep 2017
68034 currently still on TPE work:
68034 + TP07:
1E25 0654 Liverpool to Scarborough
1T60 0957 Scarborough to York
1T29 1100 York to Scarborough
1F66 1234 Scarborough to Liverpool
1E45 1654 Liverpool to Scarborough
5E45 2005 Scarborough to ScarboroughTMD
CW2
7 May 2020
Crewe
According to RailCam data, 1E43 16:41 Manchester Victoria - Scarborough (68028) was cancelled at Victoria due to failure - not known whether loco or set. By diagram this should have worked 1P92 19:34 Scarborough - MIA. I would hope TPE will find a 185 from somewhere to run that train. So 68031 and 68034 should finish at Scarborough tonight.
J-P_L
7 Sep 2017
185128 picked up 1E43 from York (split off 1P81 1540 MIA-RCC) and will work 1P92.
43 302
25 Oct 2019
68023 "Achilles" + TP09 - West End
1F48 0554 MCV - LIV
1E25 0654 LIV - SCA
1T60 0957 SCA - YRK
1T29 1100 YRK - SCA
1F66 1234 SCA - LIV
1E45 1654 LIV - SCA
68031 "Felix" + TP11 - East End
1F54 0634 SCA - LIV
1E35 1154 LIV - SCA
1F72 1534 SCA - LIV
1E51 1954 LIV - SCA
68034 + TP07 - East End AM / West End PM
1F56 0734 SCA - MCV
1E43 1631 MCV - SCA
1P92 1934 SCA - MIA
43 302
25 Oct 2019
68033 is replacing 68023 at Longsight tonight. Will post diagrams once confirmed. Likely 1F48 etc.
43 302
25 Oct 2019
31/7/20: A Glorious Sunrise!
68033 "Glorious?!" + TP08
1F48 0554 MCV - LIV
1E25 0654 LIV - SCA
1T60 0957 SCA - YRK
1T29 1100 YRK - SCA
1F66 1234 SCA - LIV
1E45 1654 LIV - SCA
68034 + TP07
1F54 0634 SCA - LIV
1E35 1154 LIV - SCA
1F72 1534 SCA - LIV
1E51 1954 LIV - SCA
1F56 0734 SCA - MCV
1E43 1631 MCV - SCA
1P92 1934 SCA - MIA
Dodrzet
17 Jul 2020
York
Could anyone confirm which locomotive is working which diagram? 1F56 was not 34, could have been 31.
palmersears
20 Sep 2011
A question asked having not commuted for 5 months now (o_O); is it still hit and miss as to which end the 68 is on? Looking back through the diagrams posted recently it seems to be a mixture of east and west ends. I ask as I fancy heading out to photograph them and a last minute ajustment over a bridge isn't ideal!
43 302
25 Oct 2019
It is hit and miss unfortunately. Not much can be done about it either apart from getting the "end gen" on the day.
43 302
25 Oct 2019
LT701: 68023 "Achilles" + TP09 - East End
5F54 0615 SF - SCA 0620
1F54 0634 SCA - LIV 0932
1E35 1154 LIV - SCA 1451
1F72 1534 SCA - LIV 1833
1E51 1954 LIV - SCA 2249
5E51 2305 SCA - SF 2310
LT704: 68033 + TP08 - West End AM / East End PM
5F56 0715 SF - SCA 0720
1F56 0734 SCA - MCV 0951
5H56 1001 MCV - XML 1021
5E43 1514 XML - MCV 1619
1E43 1630 MCV - SCA 1851
1P92 1934 SCA - MIA 2222
5H90 2243 MIA - XML 2359
LT709: 68032 "Destroyer" + TP12 - West End
5F48 0440 XML - MCV 0532
1F48 0554 MCV - LIV 0634
1E25 0654 LIV - SCA 0945
1T60 0957 SCA - YRK 1046
1T29 1100 YRK - SCA 1151
1F66 1234 SCA - LIV 1603
1E45 1654 LIV - SCA 1951
5E45 2005 SCA - SF 2010
SF - Scarborough TMD
SCA - Scarborough
YRK - York
MCV - Manchester Victoria
MIA - Manchester Airport
LIV - Liverpool Lime Street
XML - Longsight
CW2
7 May 2020
Crewe
The "end" issue is that the set coming off Longsight to work 1F48 to Liverpool gets turned each day. (If the loco leads the ECS coming off Longsight, it is trailing when it enters service at Victoria). So if you know what happened yesterday you can predict which way round they are today - but the best bet is to watch this thread for the gen (for which, many thanks).
EDIT:
Thinking about it, the issue lies not with 1F48 but with this diagram:
1F56 0734 SCA - MCV
5E43 1514 Longsight - MCV
1E43 1631 MCV - SCA
Whereas 5H56 runs via Castlefield, 5E43 runs into the main station at Piccadilly then runs via Philips Park to Victoria - probably a useful route retainer as well as keeping the stock away from the Castlefield corridor in the evening. So that's where / how it gets turned.
L+Y
4 Jul 2011
Is there any indication of when more diagrams might be run as Mk5 stock- or has training now totally ground to a halt?
37201xoIM
29 Apr 2016
Training has now effectively ground to a halt - the problem is still the national one about how to have two people in the cab safely.
xotGD
4 Feb 2017
If you watch the York rail cam at the right moment you can see which end is the 'front'.
Jamesrob637
12 Aug 2016
19:34 Scarborough to Manchester Airport is showing full under social distancing on Journey Check but nothing to suggest that it's not a Nova set
Must have been loads going to Scarbados today!
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
I was on 1F72 1534 Scarborough to Liverpool Lime Street today between York and Leeds and that was around 1/3 full - I even managed to bag my pet seat.
